Cleaning speakers
Jhayman
Jhayman Posts: 1,548
I use a lint free cloth to buff up the natural shine on some speakers or use natural orange oil to add some shine and smell.
But what do you use on the rubber surrounds to keep them soft and shiney?
  • teekay0007
    teekay0007 Posts: 2,289
    Jhayman wrote: »
    I've found that nothing works better here - and on the MW drivers - than ORIGINAL Windex. Just spray a little on a microfiber cloth and wipe in a circular motion. Not too much pressure and don't ding the dust caps.
  • cfrizz
    cfrizz Posts: 13,415
    The only thing I do is wipe down the cabinet. The grills stay on all my speakers so they don't get dusty on the inside. Several year ago I took them off to clean them and it proved un-necessary to do so.
  • pongshi
    pongshi Posts: 376
    I find that some heavy metal at high volume will definitely clean the dust of the speakers B)
    Living Room
    Parasound Model 2250v2 amplifier
    Parasound P5 preamp
    Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
    Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
    Schiit Mani Phono Preamp for Turntable 2
    Oppo UDP-205 CD/SACD USB and FLAC duties
    Technics RS-1500US reel to reel
    Polk SDA SRS (2nd Gen) fully modded
    nooshinjohn Posts: 25,932
    cfrizz wrote: »
    You would be shocked at how much dust gets inside those grills...
  • Original Windex on the drivers and surrounds. My tops have been stained then cleared so many times all it takes is a damp cloth and there's not a lot you can do to the fabric sides and grilles but some very light vacuuming.
    F1nut Posts: 51,805
    Jhayman wrote: »
    What type of finish are you referring to?
    Get yourself a bottle of mineral oil, add some mineral spirits along with some orange scent and you can make your own, but ask yourself, is that really something I want to put on my speakers/furniture? I know I don't.
    I think the best advice is to do as little as possible. Clean the surrounds with original Windex if they look oxidized, but that's it.
    tonyb Posts: 33,072
    teekay0007 wrote: »
    Jhayman wrote: »
    What...your Greek ?
  • cfrizz
    edited February 2015
    cfrizz wrote: »
    Maybe so on the new models but the grills on mine have a fairly tight seal. I have only cleaned them once in the 25 years that I have had them and that was only about 10 years ago and the cloth came away clean!
    Now looking at the grills on my FXi3s there is probably dust galore on them since they are open on all sides of the speakers. But so longs as they still play that's fine with me.
  • Jhayman
    Jhayman wrote: »
    On my Casta's they are finished with a clear coat so I just use a dry lint free cloth to rub of any finger prints and yo buff up the shine.
    I use Howard's Orange Oil Excellent reviews on finished and unfinished woods and Veneers.
    Ok I'll try Original Windex I figured the Ammonium would be bad for rubber..
  • tonyb wrote: »
    teekay0007 wrote: »
    Jhayman wrote: »
    What...your Greek ?
    Very funny movie
  • teekay0007
    tonyb wrote: »
    teekay0007 wrote: »
    Jhayman wrote: »
    What...your Greek ?
    Sorry...didn't catch the reference there, Tony. Little help?
    tonyb Posts: 33,072
    teekay0007 wrote: »
    tonyb wrote: »
    teekay0007 wrote: »
    Jhayman wrote: »
    What...your Greek ?
    My big fat Greek wedding.....Windex cures everything. lol
    F1nut Posts: 51,805
    If it were me on the high gloss black I'd use a micro fiber cloth with a little water or Windex as a lubricant to help prevent fine scratches caused by dry cleaning.
    Here's the MSDS info on that product;
    ~Petroleum distillates, hydro treated heavy paraffinic 60-100 percent (that is mineral oil, a lot of it)
    ~Solvent naphtha (petroleum), heavy aliphatic 15-40 percent (I said mineral spirits, a close relative)
    ~Oils, orange, sweet 1-5 percent (does nothing but add scent)
    ~Methanone, (2-hydroxy-4-methoxyphenyl)phenyl- 0.1-1 percent (not sure what this is and didn't look it up)
    So, like I said you can make the stuff yourself. Regardless, speaking as a professional, applying what is not much more than the mineral oil you can buy at the drug store is NOT something you want on your speakers or furniture. Excellent reviews? Sure, from people that bought the hype, have no idea what the stuff really is and don't realize what a waste of money it is.
    Yeah, it probably wouldn't be good to use it all the time. I've cleaned the surrounds on my SDA's once since 1989. Might clean them again ten years from now, if they need it.
  • Nightfall
    Nightfall Posts: 10,084
    Would something like this be bad for rubber surrounds?
    A glycerin, aloe vera and coconut oil rubber conditioner
    http://www.amazon.com/Zymol-Seal-soft-seal-Conditioner/dp/B003ANPY8C
    When you live in a very dry climate, such as the mountains of CO, how can you preserve the surrounds?
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,805
    I'm not a rubber expert, so I can't answer that. I will say a good number of these Polk drivers are 30 years old and I don't recall anyone reporting issues with the surrounds.
  • mikeyb128
    mikeyb128 Posts: 2,885
    I do exactly this, and works great. I also use orange oil on ebony side panels for a little shine. I don't use it for cherry, I use the windex/micro fiber method.
    2 channel:
    Theater:
  • In different brands of cars, flooring may differ in the type of material and pile. The coating often gets wet, especially during rains or snow. Cleaners suitable for one machine may not be suitable for others. Therefore, if it was not possible to remove the dirt the first time, you just need to apply an alternative method. Can you advise the best car carpet cleaner you have ever tried?
  • Willow
    Willow Posts: 11,233
    I use a belt sander to remove finger prints.
  • polrbehr
    polrbehr Posts: 2,842
    Willow wrote: »
    And a 12ga to kill mosquitoes? Have to admit, both would be very effective...
  • Willow
    I wouldn't dare use the sander on the speakers I use it on people's fingertips.
