Cleaning speakers
I use a lint free cloth to buff up the natural shine on some speakers or use natural orange oil to add some shine and smell.
But what do you use on the rubber surrounds to keep them soft and shiney?
I've found that nothing works better here - and on the MW drivers - than ORIGINAL Windex. Just spray a little on a microfiber cloth and wipe in a circular motion. Not too much pressure and don't ding the dust caps.
The only thing I do is wipe down the cabinet. The grills stay on all my speakers so they don't get dusty on the inside. Several year ago I took them off to clean them and it proved un-necessary to do so.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I find that some heavy metal at high volume will definitely clean the dust of the speakers
Living Room
Parasound Model 2250v2 amplifier
Parasound P5 preamp
Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
Schiit Mani Phono Preamp for Turntable 2
Oppo UDP-205 CD/SACD USB and FLAC duties
Technics RS-1500US reel to reel
Polk SDA SRS (2nd Gen) fully modded -
You would be shocked at how much dust gets inside those grills...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Original Windex on the drivers and surrounds. My tops have been stained then cleared so many times all it takes is a damp cloth and there's not a lot you can do to the fabric sides and grilles but some very light vacuuming.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
What type of finish are you referring to?or use natural orange oil to add some shine and smell.
Get yourself a bottle of mineral oil, add some mineral spirits along with some orange scent and you can make your own, but ask yourself, is that really something I want to put on my speakers/furniture? I know I don't.But what do you use on the rubber surrounds to keep them soft and shiney?
I think the best advice is to do as little as possible. Clean the surrounds with original Windex if they look oxidized, but that's it.
teekay0007 wrote: »But what do you use on the rubber surrounds to keep them soft and shiney?
What...your Greek ?HT SYSTEM-
lsi 9's -
nooshinjohn wrote: »
Maybe so on the new models but the grills on mine have a fairly tight seal. I have only cleaned them once in the 25 years that I have had them and that was only about 10 years ago and the cloth came away clean!
Now looking at the grills on my FXi3s there is probably dust galore on them since they are open on all sides of the speakers. But so longs as they still play that's fine with me.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
On my Casta's they are finished with a clear coat so I just use a dry lint free cloth to rub of any finger prints and yo buff up the shine.or use natural orange oil to add some shine and smell.
I use Howard's Orange Oil Excellent reviews on finished and unfinished woods and Veneers.But what do you use on the rubber surrounds to keep them soft and shiney?
Ok I'll try Original Windex I figured the Ammonium would be bad for rubber..
ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
What...your Greek ?
Very funny movie
What...your Greek ?
Sorry...didn't catch the reference there, Tony. Little help?
teekay0007 wrote: »teekay0007 wrote: »But what do you use on the rubber surrounds to keep them soft and shiney?
What...your Greek ?
My big fat Greek wedding.....Windex cures everything. lol
lsi 9's -
If it were me on the high gloss black I'd use a micro fiber cloth with a little water or Windex as a lubricant to help prevent fine scratches caused by dry cleaning.I use Howard's Orange Oil Excellent reviews on finished and unfinished woods and Veneers.
Here's the MSDS info on that product;
~Petroleum distillates, hydro treated heavy paraffinic 60-100 percent (that is mineral oil, a lot of it)
~Solvent naphtha (petroleum), heavy aliphatic 15-40 percent (I said mineral spirits, a close relative)
~Oils, orange, sweet 1-5 percent (does nothing but add scent)
~Methanone, (2-hydroxy-4-methoxyphenyl)phenyl- 0.1-1 percent (not sure what this is and didn't look it up)
So, like I said you can make the stuff yourself. Regardless, speaking as a professional, applying what is not much more than the mineral oil you can buy at the drug store is NOT something you want on your speakers or furniture. Excellent reviews? Sure, from people that bought the hype, have no idea what the stuff really is and don't realize what a waste of money it is.Ok I'll try Original Windex I figured the Ammonium would be bad for rubber..
Yeah, it probably wouldn't be good to use it all the time. I've cleaned the surrounds on my SDA's once since 1989. Might clean them again ten years from now, if they need it. -
Would something like this be bad for rubber surrounds?
A glycerin, aloe vera and coconut oil rubber conditioner
http://www.amazon.com/Zymol-Seal-soft-seal-Conditioner/dp/B003ANPY8C
When you live in a very dry climate, such as the mountains of CO, how can you preserve the surrounds?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I'm not a rubber expert, so I can't answer that. I will say a good number of these Polk drivers are 30 years old and I don't recall anyone reporting issues with the surrounds.
I do exactly this, and works great. I also use orange oil on ebony side panels for a little shine. I don't use it for cherry, I use the windex/micro fiber method.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
In different brands of cars, flooring may differ in the type of material and pile. The coating often gets wet, especially during rains or snow. Cleaners suitable for one machine may not be suitable for others. Therefore, if it was not possible to remove the dirt the first time, you just need to apply an alternative method. Can you advise the best car carpet cleaner you have ever tried?
I use a belt sander to remove finger prints.
And a 12ga to kill mosquitoes? Have to admit, both would be very effective...So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
I wouldn't dare use the sander on the speakers I use it on people's fingertips.
