silk audio mc 100b tube integrated review
well my review of the silk audio mc-100b kt88 based tube integrated amp is up at stereomojo. listening to the amp as i type.
http://www.stereomojo.com/SILK MC-100B Tube Integrated Amp review/SILKMC-100BTubeIntegratedAmp.htm
Puritan PSM156
  • boston1450
    boston1450 Posts: 7,758
    I thought it was a great review with a tad bit of humor. I know some of YaQin manuals come with diddly squat for info too. Overall i liked your impressions on the unit. Well said-to the point. Didnt hold back on small details. I think its a beautiful unit & would love to get my ears on it
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Faustin
    Faustin Posts: 1,151
    Nice write up. Curious as to how you use the Silk as a power amp with a separate pre? When I inquired about doing that Ray told me no and I also asked the Yaqin distributor from Canada the same question and he also said no.
  • boston1450
    edited February 2015
    What are these on front for ? just curious - i know what the switch is forpcpicz8ry27e.jpg
    Maybe a quick connect to add source
    Randy-Maine
    by David WMG
  • marvda1
    marvda1 Posts: 4,963
    boston1450 wrote: »
    the manual calls them the power amp inputs, when the switch is set to 0.0v only the front inputs work and you can use a preamp.
    Puritan PSM156
  • marvda1
    Faustin wrote: »
    yes, even in their manual they call it the "power amp mode selector"
    i used it with my belles pre and there are a lot of owners using it as a power amp.
    Puritan PSM156
  • Faustin
    "yes, even in their manual they call it the "power amp mode selector"
    i used it with my belles pre and there are a lot of owners using it as a power amp."
    That was what I thought as well but thought I would make sure before I screwed something up. Wonder why I was told no? Any thoughts as to how the amp sounds bypassing the internal pre and using an external?
  • voltz
    voltz Posts: 5,384
    Nice Review Marvin!
    I'm now using the Audio art Power cable I got from you with mine. was listening to it when I read your review B)
    I tried the Mc100b with my Dared preamp and you still have 2 volume controls, so I open the Mc100's volume control a bit and used the preamps volume control to control the volume since it had a remote.
  • Jhayman
    Jhayman Posts: 1,548
    Nice Review Marvin..
    I was actually looking to pick up one of these as my buddy from Finland has one and was telling me you can mod these quite easily with upgrade parts..
    Seems like a reasonable price as well..
  • boston1450
    Thank you for clarifying the front hook up
    Post edited by boston1450 on
    Randy-Maine
    by David WMG
  • sounds like a good update to the article... (mode 30/60)
  • marvda1
    Faustin wrote: »
    You still get the dead silent background plus whatever qualities your pre imparts on the sound.
    the front switch is the power amp mode switch and the switch(one for each channel ) on the top of the amp in front of the caps is for triode/ultra linear mode (30/60 watts)
    Puritan PSM156
  • erniejade
    erniejade Posts: 6,321
    Great review as well as one heck of a good looking unit.
  • Faustin
    May have to try my Dared pre amp with the Silk to see how that sounds. Currently have the Silk powering rebuilt RTA 12c's. Nice open sound with nice highs. Did not care for the Silk with my SDA 1c's. Seemed like they never really opened up.
    DSkip wrote: »
    It might take different tubes with different speakers.
    Absolutely....one of the reasons I dumped full on tube gear, especially amps.
  • I was considering purchasing this amp but haven't found any seller information anywhere.
  • marvda1
    rprats wrote: »
    silk.audio.products@gmail.com
    the publisher forgot add the contact info.
    Puritan PSM156
  • marvda1
    edited March 2015
    just put in a quad of eh kt90eh tubes. out the box these are keepers, airy highs, el34 mid range and tight bass. i hope all this will improve with burn in. biased them at 0.6.
    the silk mc 100b now consists of eh kt90, tung sol reissue 6sn7, and new production tung sol 12ax7.
    i will try the mullard reissue cv4004.
    kept going back and forth on whether to get the kt 90 or gold lion reissue kt88. the kt90's are little cheaper.
    the mid range detail on these eh tubes are out of sight (hearing) :D
    Post edited by marvda1 on
    Puritan PSM156
  • voltz
    voltz Posts: 5,384
    Nice! sound like you made the right call!
    I'm current using the Mullard cv4004 and like them a lot better then the stock tubes.
  • marvda1
    voltz wrote: »
    are you using nos or reissue mullards?
    Puritan PSM156
  • voltz
    voltz Posts: 5,384
    reissue mullards and my 6sn7's are the Tung-sol new production.
  • marvda1
    i may try this tube, heard nothing but great things about it and it's cheap.
    https://www.tubedepot.com/products/sovtek-12ax7lps-preamp-vacuum-tube
    Puritan PSM156
  • Mikey081057
    Mikey081057 Posts: 7,127
    I found a NIB matched pair of Tesla E83CC's... Worth every penny... and there are not many around... beware of knock offs but if you can find a pair from a reputable reseller they are a 12ax7 that is hard to beat IMHO.
    Garage | Polk Monitor 5B's
  • marvda1
    did you compare the treasure kt88's to gold lion reissues?
    Puritan PSM156
