silk audio mc 100b tube integrated review
marvda1
in Electronics
well my review of the silk audio mc-100b kt88 based tube integrated amp is up at stereomojo. listening to the amp as i type.
http://www.stereomojo.com/SILK MC-100B Tube Integrated Amp review/SILKMC-100BTubeIntegratedAmp.htm
Puritan PSM156
Puritan PSM156
I thought it was a great review with a tad bit of humor. I know some of YaQin manuals come with diddly squat for info too. Overall i liked your impressions on the unit. Well said-to the point. Didnt hold back on small details. I think its a beautiful unit & would love to get my ears on itRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Nice write up. Curious as to how you use the Silk as a power amp with a separate pre? When I inquired about doing that Ray told me no and I also asked the Yaqin distributor from Canada the same question and he also said no.
What are these on front for ? just curious - i know what the switch is for
Maybe a quick connect to add sourceRandy-Maine
by David WMG
the manual calls them the power amp inputs, when the switch is set to 0.0v only the front inputs work and you can use a preamp.boston1450 wrote: »What are these on front for ? just curious - i know what the switch is for
Puritan PSM156 -
yes, even in their manual they call it the "power amp mode selector"Nice write up. Curious as to how you use the Silk as a power amp with a separate pre? When I inquired about doing that Ray told me no and I also asked the Yaqin distributor from Canada the same question and he also said no.
i used it with my belles pre and there are a lot of owners using it as a power amp.
Puritan PSM156 -
"yes, even in their manual they call it the "power amp mode selector"
i used it with my belles pre and there are a lot of owners using it as a power amp."
That was what I thought as well but thought I would make sure before I screwed something up. Wonder why I was told no? Any thoughts as to how the amp sounds bypassing the internal pre and using an external?
Nice Review Marvin!
I'm now using the Audio art Power cable I got from you with mine. was listening to it when I read your review
I tried the Mc100b with my Dared preamp and you still have 2 volume controls, so I open the Mc100's volume control a bit and used the preamps volume control to control the volume since it had a remote.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Nice Review Marvin..
I was actually looking to pick up one of these as my buddy from Finland has one and was telling me you can mod these quite easily with upgrade parts..
Seems like a reasonable price as well..ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Thank you for clarifying the front hook upPost edited by boston1450 onRandy-Maine
by David WMG
sounds like a good update to the article... (mode 30/60)
You still get the dead silent background plus whatever qualities your pre imparts on the sound.
the front switch is the power amp mode switch and the switch(one for each channel ) on the top of the amp in front of the caps is for triode/ultra linear mode (30/60 watts)
Puritan PSM156 -
Great review as well as one heck of a good looking unit.
May have to try my Dared pre amp with the Silk to see how that sounds. Currently have the Silk powering rebuilt RTA 12c's. Nice open sound with nice highs. Did not care for the Silk with my SDA 1c's. Seemed like they never really opened up.
It might take different tubes with different speakers.
Absolutely....one of the reasons I dumped full on tube gear, especially amps.
lsi 9's -
I was considering purchasing this amp but haven't found any seller information anywhere.
silk.audio.products@gmail.com
the publisher forgot add the contact info.
Puritan PSM156 -
Thank you
just put in a quad of eh kt90eh tubes. out the box these are keepers, airy highs, el34 mid range and tight bass. i hope all this will improve with burn in. biased them at 0.6.
the silk mc 100b now consists of eh kt90, tung sol reissue 6sn7, and new production tung sol 12ax7.
i will try the mullard reissue cv4004.
kept going back and forth on whether to get the kt 90 or gold lion reissue kt88. the kt90's are little cheaper.
the mid range detail on these eh tubes are out of sight (hearing)
Post edited by marvda1 onAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Nice! sound like you made the right call!
I'm current using the Mullard cv4004 and like them a lot better then the stock tubes.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
are you using nos or reissue mullards?Nice! sound like you made the right call!
Puritan PSM156 -
reissue mullards and my 6sn7's are the Tung-sol new production.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
i may try this tube, heard nothing but great things about it and it's cheap.
https://www.tubedepot.com/products/sovtek-12ax7lps-preamp-vacuum-tubeAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I found a NIB matched pair of Tesla E83CC's... Worth every penny... and there are not many around... beware of knock offs but if you can find a pair from a reputable reseller they are a 12ax7 that is hard to beat IMHO.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
did you compare the treasure kt88's to gold lion reissues?Mikey081057 wrote: »I found a NIB matched pair of Tesla E83CC's... Worth every penny... and there are not many around... beware of knock offs but if you can find a pair from a reputable reseller they are a 12ax7 that is hard to beat IMHO.
Puritan PSM156
