Monitor 5B crossover help
New here and just acquired a nice pair of Monitor 5Bs. So far I don't mind the SL2000 tweeters, but we'll see how I feel after the crossover rebuild. I'm getting together parts to replace the caps/resistors, and need some guidance on a couple things:
1) Polyswitch - should I remove it? If so, is it best to add a resistor in place, or just a jumper wire and then replace the original 2 ohm resistor with a higher value? Is the polyswitch the component just above/right of the resistor in my picture?
2) I have used Mills resistors and Solen caps in the past for other speakers, and planned to do the same on these - unless there is another preferred option?
Thanks in advance
