Black Rubber Stick-On Feet
sgtmick63
Yesterday received my lsi7 speakers I got from ebay. I plan on vr3 mods doing the crossovers this spring. They appear in pretty good shape except for the home depot type stick on feet. Does anyone have a solution on how to remove these feet without damage?
Goo gone and a brand new razor blade, pull it up just a smidge, spray some goo gone sparingly, and let it sit a minute, use the razor to scrape it off, use a soft cloth or paper towel to clean remaining goo gone and adhesive off, then another dry cloth or towel to buff it.2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
The razor is for if you screw up.
Haha, that's why you use a new one, you want a good clean edgerednedtugent wrote: »The razor is for if you screw up.
I have both in the house. I'll give it a try this afternoon.
I decided to try it out now. I used a q-tip and the contraption I use to remove my car registration with. It worked like charm. I had all 8 off in less than 10 minutes with no scratches. Thanks for the advise.
what is this contraption of which you speak?I disabled signatures.
It looks like a thing-a-mabob? How's that.
I'm guessing a razor blade window scraper2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
That's is it.
haha, nice. 'cause window scraper is too difficult to say
