Black Rubber Stick-On Feet
Yesterday received my lsi7 speakers I got from ebay. I plan on vr3 mods doing the crossovers this spring. They appear in pretty good shape except for the home depot type stick on feet. Does anyone have a solution on how to remove these feet without damage?
  • seabeerob213
    seabeerob213 Posts: 1,843
    Goo gone and a brand new razor blade, pull it up just a smidge, spray some goo gone sparingly, and let it sit a minute, use the razor to scrape it off, use a soft cloth or paper towel to clean remaining goo gone and adhesive off, then another dry cloth or towel to buff it.
  • The razor is for if you screw up.
  • seabeerob213
    Haha, that's why you use a new one, you want a good clean edge
  • sgtmick63
    sgtmick63 Posts: 166
    I have both in the house. I'll give it a try this afternoon.
  • sgtmick63
    I decided to try it out now. I used a q-tip and the contraption I use to remove my car registration with. It worked like charm. I had all 8 off in less than 10 minutes with no scratches. Thanks for the advise.
    msg Posts: 10,510
    what is this contraption of which you speak?
  • sgtmick63
    It looks like a thing-a-mabob? How's that.
  • seabeerob213
    I'm guessing a razor blade window scraper
    msg Posts: 10,510
    haha, nice. 'cause window scraper is too difficult to say :)
