Why do I get no sound through Sound Bar while watching Netflix on a Smart TV?
petercraig01
I have a Sound Bar 3000 hooked up directly to a Samsung Smart TV. I have no problems using the sound bar with my DirecTV service while watching programs. However, if I switch to watching a movie on Netflix or from my BluRay player, there's no sound coming out of the sound bar system. How do I set it up so that the sound bar will operate for all three? Thanks.
Answers
It may help the members on here if you inform us of how you have it connected, pics of your connections would be awesome, also audio settings on your TV.2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
Yup, need to know what cable is running to what.
Maybe your bitsreaming to the sound bar? Try pcm decoding insid the player before you send out the signal.
Connect the sound bar with an optical cable to the TV output. Set the Samsung tv to external speakers. Set the DVD player to PCM in the audio settings.
Are you getting NetFlix from smarthub or from the DVD player?B&W CM9Classé Sigma
