Tidal HiFi launched today! CD quality streaming
245
  • markmarc
    markmarc Posts: 2,309
    tonyb wrote: »
    markmarc wrote: »
    Not really a review, more so an advertising. Seems though for me anyway, the "curated" approach is a turn off.
    Tony, in all fairness, this was written after a one day experience. To call it advertising is wholly unfair. I overstepped in calling it a review, a better choice would have been a "first look".
    Former Staff Member TONEAudio
    2 Ch. System
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    Both Spotify and Tidal let you store things offline on your mobile devices so you can listen to stuff while you are on a plane. I think spotify has 3,333 songs per account that you can listen to offline..not sure of the tidal limit is
    Correct, but I believe those songs are still stored and played within their app and not available via the standard music app and able to be copied to a computer.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Correct shoulda mentioned that also... It's kinda cool but its not like your getting away with anything :)
    Garage | Polk Monitor 5B's
  • Mikey081057
    So I just added 250 albums to "my music" in Tidal searching and adding... took about 1hr.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    Tidal would be one's new "standard" music app if they're using it, no? You can't burn CD's but you CAN make it available offline and you have it on all of your devices.
  • AsSiMiLaTeD
    Sure, just wanted to clarify that though, it's not like you can copy the files to a drive and play them on a network player like the Oppo
  • coolsax
    coolsax Posts: 1,826
    Signed up for my 30 day trial today.. fairly impressed with the quality and quantity of music. having a few issues with cutting out when airplaying from my iphone to Apple TV. shame it won't likely work with the Squeezebox system.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • I'm having drop out issues as well. It takes a lot more bandwidth (not sure if this is the correct term) to stream lossless audio. Still getting a feel for it but so far besides the drop out issues, it's awesome.
  • I'm streaming from iphone and iPad to Apple TV and aiprort express without issue. I think my internet connection is only 10mb. The Apple TV is hard wired into the network but that shouldn't make a difference. The router is an Airport Extreme dual band.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • Mikey081057
    edited November 2014
    I've been streaming from my Chromebook and my android phone without issue... doesn't matter what your internet speed is if you router doesn't have enough memory to buffer efficiently.
    Bye Bye Spotify... turning you off today
  • coolsax
    pretty sure its not my router causing drop outs.. but it may be my cable modem.. the wireless router i use streams wirelessly all over the house FLAC and Hires Flac from my server with no dropout issues. but i'm having issues with Tidal. Not just airplay but through chrome and their own desktop player as well. cable modem is super old though.. it may not be fast enough probably should take it in to time warner and get an updated one.
    Main 2ch -
    TV 3.1 system -
    I'm thinking of upgrading to a dual band router myself. Internet has been slow but we have 3 iPhones connected at all times and sometimes even the Squeezebox Touch streaming in another system.
  • Mikey081057
    Yes bandwidth is important, but having a modem (docsis 3.0) and a router with the capacity (memory) to buffer the incoming stream from the ISP (who do play games with bandwidth throttling) is important. This all happens before the data oes over your wireless network. Heck it could even be effected by your neighbors hammering the bandwidth...but having a modem and router that efficiently buffer the incoming data is key. I am sure over time Tidal will make their buffering better too.
  • Yes bandwidth is important, but having a modem (docsis 3.0) and a router with the capacity (memory) to buffer the incoming stream from the ISP (who do play games with bandwidth throttling) is important. This all happens before the data oes over your wireless network. Heck it could even be effected by your neighbors hammering the bandwidth...but having a modem and router that efficiently buffer the incoming data is key. I am sure over time Tidal will make their buffering better too.
    My new dual band router shipped and will be here tomorrow. I hope the modem Cox provided is sufficient in providing what the router needs like you mentioned.
    I'm officially canceling my Spotify subscription. The difference in sound quality is well worth the price.
  • Mikey081057
    If you are renting a modem from your ISP, you should get a Motorola Surfboard docsis 3.0 for about $90 instead of paying them $6/ month for a POS modem.
    http://www.amazon.com/ARRIS-Motorola-SB6121-SURFboard-DOCSIS/dp/B004XC6GJ0/ref=sr_1_2?s=electronics&ie=UTF8&qid=1415167379&sr=1-2&keywords=motorola+surfboard+sb6141
    Thanks for the recommendation Mikey. Ordered :smiley:
  • Mikey081057
    Make sure your ISP is good with that model... they should be, but it will require a network change on their side.
    This was in the description so I think I'm good:
    • Compatible with ALL Major CABLE providers like Comcast, Cox, Charter, Time Warner, Mediacom, Bright House
  • Mikey081057
    Make sure you do before and after speetests
    http://www.speedtest.net/
    that will validate your cost.
  • BlueFox
    BlueFox Posts: 15,251
    I was just looking at it on Amazon since I want to replace my Comcast router/modem. This is nice, but it doesn't have wi-fi, so another box also needs to be ordered.
  • Mikey081057
    BlueFox wrote: »
    Correct... do you have an all in one cable modem router now?
    Here is the router I have/recommend
    http://www.amazon.com/Linksys-WRT1900AC-Dual-Band-Wireless-Anywhere/dp/B00KEK4Q5Q/ref=sr_1_3?s=pc&ie=UTF8&qid=1415169362&sr=1-3&keywords=linksys+wireless+router
  • BlueFox
    Yes. Some Motorola from Comcast. Works mostly fine for my needs, but there are two issues. One, I rent it. Two, and this does bug me, if I lose Internet access then the wireless also stops working. Since I control my file player over the home net, not having wireless makes the control app useless.
  • Make sure you do before and after speetests
    Screenshot'ed some speed tests last night :)
    Btw, here is the router I picked up. What do you think?
    http://www.amazon.com/RT-N66U-Dual-Band-Wireless-N900-Gigabit-Router/dp/B006QB1RPY/ref=sr_1_4?s=pc&ie=UTF8&qid=1415170144&sr=1-4&keywords=router
  • mrbiron
    mrbiron Posts: 5,712
    Good info Mike!...now I want to upgrade my aged 10 yo wireless router. My speed tests are **** compared to everyone else's which is odd. I might try one connected directly to the modem for comparison.
    I have 2 Motorola surfboard 3.0s collecting dust at the moment. I bought the first one and all was well. Then my internet got choppy so I bought a second to replace the first. Charter tells me its still not them, its the modem. So now I have a charter modem for the sole reason of being able to put the blame back on charter. Come to find out, I had a bad wire and both my modems are fine. Anyone need a modem(s) :P
    I'm going to give the Tidal trial a shot tonight although I am hesitant at the cost/month. I barely have the time now never mind when I'm paying for a service.
  • voltz
    voltz Posts: 5,384
    the Motorola SB6141 and such are great cable modems. then you just need a good router go with it. now if your having problems it could be the Modem or the router or the line..
    Wow, pretty substantial download speed increase by just switching out the old router! New modem gets here today too so I can't wait to swap that in. I think my internet service plan doesn't let me get higher upload speeds which sucks because I'm uploading huge files to Vimeo every day.
  • Mikey081057
    Wow nice improvement... Yeah the new routers can give you much better download speeds.
  • Mikey081057
    mrbiron wrote: »
    So what speed are you paying for / getting?
  • mrbiron
    With the price I pay, I should be getting a terabyte/sec. :-P
    I'd have to check when I get home but my speed tests are around 8mb/s. I think I pay for 20.
