bi amp
This is a question for Polk engineers, not a bunch of people who don't know what they're talking about. With an AVR (Denon AVR X 1100-W) if I bi-amp the front speakers (Polk Rtia5's) using the Back surround amp outputs, what specifically happens as far as impedance and amplifier power output to the speakers?
«134
Answers
  • Not much you are still using the Denon amp. To get anything of value you need a external amplifier to truly bi amp.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • Not to mention an external xover!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • you're both wrong. I spoke for a half an hour on the phone today with a Denon engineer.He said
    1-provided that I have accessed(within the receivers menu options) the "amp assign" menu, clicked on it, and selected "bi-amp", then connected two separate pairs of amp outputs(the front r/l, and the "back surround" r/l), to the speakers, (Polk Rtia5's), I AM, IN FACT, bi-amping the speakers. Each speaker is now receiving, from the AVR, twice as much power as it was before( 160 watts instead ofg 80).
    2-The crossovers in the speakers are better qualified to divide the frequency distribution to the drivers than is some yo-yo who's manipulating the frequency delivery with an external crossover.
    tonyb Posts: 33,072
    You fail to understand the basic principles of powering speakers versus marketing gimmicks.
    Most receiver makers with that option employ it as a selling point. The more speakers you add to the receiver, the less power all will receive.
    Did you know by chance that the top half of that speaker probably uses less than 15 watts anyway ? What happens to the other 65 watts out of 80 in your supposedly bi-amp configuration ?
    Please read up, look elsewhere if you like, google bi-amping. Proper bi-amping is as described earlier, not the ghetto version receiver makers want to sell you on.
  • you don't even know we're talking about. I'm not "adding more speakers", I'm taking them away. I'm adding more amplifiers.
  • voltz
    voltz Posts: 5,384
    when you buy AVR that says it has 120 wpc that is only with 2 channels driven, when you add more speakers like in a 5.1 setup your droping that way down . if you then plug speaker cables into the unused open extra rear surrounds to power the front speakers your dropping the total wpc down even further no matter what the denon rep said. that is just the facts of life and you can not change it. we have all been there and done that just to give it a go and realize why everyone warn us no to do it...
    but you are very mistaken when you say tonyb doesn't know what he talking about as anyone who has spent anytime on this forum will tell you his advance experience is way ahead of most of us and I have found him to be one of the most trusty resources for audio info I have known and a great man who loves to help people like you make better decisions and your remake is just way out of line for a man who loves to help others.
    so please do as you please with your equipment. but you missed the boat on this one.
  • teekay0007
    teekay0007 Posts: 2,289
    David7544, you should post about this one more time - at least! - maybe then you'll get the answer you're looking for. After all, isn't it "The third time's the charm!"?
    Since you know the only answer you'll accept, why do you keep asking? Didn't the Denon engineer answer all the questions you had/have? If not, what the heck were you talking with him/her about for a half an hour?
    Sounds like, from your previous post, you're very happy with your "bi-amped" RTiA5s hooked up the way you have them done. Why not just enjoy them, instead of goin' off on a lot of very knowledgeable people here, telling them that they don't know what they're talking about?
    If you did have an actual improvement in SQ after you "bi-amped" them using only your Denon AVR, I'd guess (as F1nut said) that you were just noticing the better sound from removing the less-than-top-of-the-line jumpers that were supplied stock with your speakers.
    F1nut Posts: 51,818
    If, in fact, you actually spoke to an engineer and not a customer service rep, that engineer should be fired. For starters, that AVR is not capable of providing 80wpc to more than 2 channels driven.
    In fact, here are the specs;
    80 wpc @ 8 ohms, 20Hz-20kHz, 0.08% THD, 2ch driven
    tonyb Posts: 33,072
    David7544 wrote: »
    Using the amp channels is the same thing. Your in essence using it in 7 channel mode instead of 5 channel mode by using those back surround channels.
  • David7544 wrote: »
    Your amps are bi-amped as long as they are running within the limits of the power supplies. With that said........
    What is missing is that they aren't truly separated pairs of outputs if they are derived from the same amp transformer power supply. The only way that a single piece of equipment can reach that level or separation is to have separate power supplies for each channel and most AVRs don't reach that level, so you can pseudo bi-amp anything you care to, but the results may or may not be heard.
    I will also take this a step further and state that even 2 stereo amps bi-amped, (one on top, one on bottom) isn't a truly separated bi-amp system, since most stereo amps share power supplies across the left and right channels, but most of us on this forum consider this type of setup to be acceptable since the amps are being run within their rated/intended power ratings. It is a slippery engineering slope that we choose to tread on, I believe sometimes just to pick a fight for our beliefs, but if you want to get technically accurate, there is no difference as long as the power supplies are never over tasked.
    We tend to choose our own levels of where we think ghetto bi-amping exists, since very few of us would choose to run 4 mono blocks plugged into 4 separate power circuits for a pair of speakers.
    Bi-amp away.......as long as you like the sound, that is all that matters, but if you want to brag about the added sound you have or how much louder it can get now that you are bi-amping, prepare for the lashings to commence.
    pitdogg2 Posts: 27,079
    David7544 wrote: »
    Give Yamaha a call they'll give you the right answer. Just a few weeks ago another thread asked the same thing BUT, was unprepared for the answer the Yamaha tech (engineer) gave them...The answer? Marketing babble was just what the tech at Yamaha told him. Even told him it would actually decrease the power to the speakers as the power supply only has so much to give. Ever notice how receiver's have actually gotten lighter ...yep smaller power supplies as IRON and shipping cost big bucks and NOT in they companies price point.
  • F1nut doesn't know what he's talking about. The spec in the manual reads;
    "80 watts per channel,all channels driven ,into 8ohms,20-20,000 hz,<0.08thd. 120 wpc into 6 ohms. I talked to the Denon tech again, and he said that so long as I accessed, in the receivers menu,the "amp assign" option, clicked on it, and selected "bi-amp", that each of my speakers is now receiving 80+80 watts, 160 watts per speaker. I had no idea this subject would inspire so much stupidity. I'm still listening to my system with this ( admittedly half assed) bi-amp setup I hooked up, and so far I must admit that it does not seem to have resulted in any significant improvement in the sound. I'm not sure that "marketing babble" is worse than the babble on this thread, but in any case, I'm having a good time experimenting. It amazes me that people stupid enough to believe that a high-end speaker wire "sounds better" than a less expensive wire are so offended by my humble attempt at configuring my speaker hookup. I suspect that "true" bi-amping doesn't result in any significant improvement either. Even though I'm sure someone here will tell me it does. Isn't this hobby great? It's like arguing about religion. People are absolutely convinced of things which have no basis in objective fact.
  • PSOVLSK
    PSOVLSK Posts: 5,391
    David7544 wrote: »
    Irony defined.
  • voltz
    voltz Posts: 5,384
    [quote="David7544;2084926" It amazes me that people stupid enough to believe that a high-end speaker wire "sounds better" than a less expensive wire are so offended by my humble attempt at configuring my speaker hookup.[/quote]
    hmm did you just turn your bi-amp question into a rant about speaker cables?
  • BlueFox
    BlueFox Posts: 15,251
    Good to see the trolls have found the new site. It is "The Stupid People" who make audio sites interesting.
    tonyb Posts: 33,072
    If I had a nickel.....
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited September 2014
    David7544 wrote: »
    And the manual.
  • the reason it says 2chdriven is because they are they are quoting the output for a single power amp at a time. there are 7 of them.
  • vmaxer
    vmaxer Posts: 5,120
    ZLTFUL wrote: »
    David7544 wrote: »
    "Better to remain silent and be thought a fool than to speak out and remove all doubt." - Abraham Lincoln
    Yep, here e go again. Ask for advise when you are already an expert,,,,,,or neophyte.
    Gotta love it!!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Sure miss the bozo list option....
  • I admit it;you guys are right. I made another call to Denon and crunched some numbers. There's no way my receiver puts out 80wpc "all channels driven"
    It would have to weigh 50 pounds. Denons support tech wouldn't answer the question.
  • vmaxer
    vmaxer Posts: 5,120
    David7544 wrote: »
    The folks here are usually correct. Enjoy your system!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,818
    You owe me an apology.
  • headrott
    headrott Posts: 5,496
    David7544 wrote: »
    You haven't gone by the names "Habanero Monk" or "Jinjuku" in the past have you? Alternatively, have you associated with him ("them")?
  • Msabot1
    Msabot1 Posts: 2,098
    At least you admitted it......that is a step in the right direction.....
    WRONG he owes ALL of us an apology as we were the "STUPID" people....
    Hows that crow taste David7544
  • I was all ready to apologize, but guess what? The receiver is capable of a total output of 1225 watts. And it is capable of outputing 80 watts per channel into 7 channels at the same time. Also, I emailed Yamaha, told them I was considering their receiver, and asked the same question. They say their receiver, also, is capable of delivering full rated power into all seven channels at once. The reason the spec states "2chdriven" is because the spec is quoting the output of the amplifier channels in pairs. The receiver allegedly has 7 power amps. I'm still not completely convinced I'm right, by the way. But a tech at best buy showed me the electrical diagram on a computer screen for the receiver and it specifically says '1225 wrms total output cap.'
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    The reason why they show 2 channels driven is that unlike a movie, music is a constant signal for long periods of time and most music is heard in 2 channel/stereo mode. Again, a marketing choice to show this rating and this rating should be higher than the 7 channel rating since the power supply is putting all of its power to 2 channels.
    The majority of 7 channel AVRs simply can't provide enough power to meet their 7 channel ratings regardless of the factory claims. Look for some lab or magazine reviews.
    I think you are asking good questions about what to look for in gear, but don't believe what you hear from their customer service techs as they are paid to make you happy with choosing their gear, not tell the truth.
    We are interested in helping you find the right gear, but you were the first to put an attitude forward when you didn't want to hear from anyone but an engineer. Company engineers for the most part, don't waste their times on the forums of any given company.
  • What Yamaha model are you looking at?
    David7544 wrote: »
    well then all my audio mag and reviewer's are wrong. When these are tested output at 2 ch is slightly more than their rated power. Like yours at 80wpc would be like 110 wpc but with ALL channels driven they are down to 45-50wpc. My Denon 3805 is 120wpc and one of the few that with all channels driven was still at 95wpc EVEN though it is rated at 120 x 7
    believe it or not you were right once when you stated that it would weigh 50+ pounds.
    Then again if they rate it at 1Khz then that is still not a true spec as those would be at 20hz-20Khz full range. It is very easy to say that it is such and such with such a narrow freq like 1khz
