convert wma to flac?
i know there's probably a bit of discussion on this, but busy and dont have time to sort it out. what is the consensus on a good, simple way to do this? free is better but not opposed to a paid service. sorry for my being absent and noncontributing lately, between vacation, school, and preparing for deployment, not much ability to be on much. that an what i have for music is 4 cd's, a laptop with a handful of wma lossless(and lots of compressed of various type), and a windows phone full of mp4, a cheapo bluetooth speaker or 2, and a pair of klipsh and a pair of senheisser earbuds. just got an hp tablet though, and it wont recognize most of my music as it is various qualities of wma. so, looking to put any and all of it that is lossless into flac, to move to my tablet. thanks in advance for any help guys, have a good weekend.
  • eor
    eor Posts: 28
    Audacity is free, multi-platform, and will convert files to flac at up to 192k/24bit. To open WMA you have to download an additional driver (Edit/Preferences/Libraries). Open the target file then File/Export and choose flac.
    Might be able to do it in batch mode, but I haven't tried.
  • Thanks
    heiney9 Posts: 25,053
    edited September 2014
    nm
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,722
    I use dbPowerAmp for all my ripping and converting needs, not free but has lots of features and produces the best results I've heard.
  • will try db, audacity wont open wma
  • i guess i downloaded the wrong plugins for it, tryinf the FFMPEG, i dont understand what most of this junk is though,
  • ok, so i downloaded and installed, LADSPA, FFMPEG, and LAME plugins, and still cant open or import WMA to audacity
  • eor
    eor Posts: 28
    All I did was download the FFMPEG library, install it, then go into Edit/Preferences/Libraries and Locate it. After that I was able to open the WMAs I had.
    Or use dbpoweramp. Or MediaMonkey.
  • It says they're located, but still won't open them, I downloaded an app to play WMA from an SD card for now
  • The easiest program I've used, is Easy CD-DA Extractor. It can convert almost any audio file type to another file type, and can rip, convert and create a playlist from any CD with a few clicks. Not cheap, but does exactly what you want it to do
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Thanks, I'll keep it in mind
