Speaker Cloth Replacement
stogie
What is the secret to get a nice neat corner when replacing grill cloth? I'm reclothing my 2nd set of Polks and thought I would get the hang of it by now but I'm still having trouble with the corners. When I've taken the old cloth off, I've noted how it was done at the factory but for the life of me I can't replicate it. The front looks fine but the underside is bunched up- this causes the frame to stand off some from the face of the speaker. I am using staples to attach the new cloth, if that matters. Any tips would be appreciated. Thanks, Don
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
TT: Technics SL-MA1
I use the "Butterfly" method. Staple everything taught, but leave about an inch unstapled by the corners from both directions. Now create a 45 degree crease at the corner with the fabric. Pull the fabric taught from one direction at a time, and put one staple along the crease at a 45 degree angle, then do the opposite. Now spread out (Butterfly) the cloth, flatten and pull it taught toward the center of the grill. Staple across the "butterflied" section with three staples, and trim off the excess.
Home Theater/2 Channel:
dhsspeakerservice.com/ -
Dave, thanks so much for the picture and description. I will give this a try.Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5 -
You're welcome. The cloth I use is very thin. Heavier cloth is more difficult to work with.Home Theater/2 Channel:
The cloth I have used is "Knit Ponte" from Joann Fabric- their item # 864595 ($5.59/yd on sale). It is thin, easy to work with and very musically transparent. DK mentioned it in one of his threads so I gave it a try. I'm no expert (only reclothed two pairs so far- SRS & 2B) so I'm open for ideas on other cloths cuz I know there will be more Polks in my future.Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
