Driver/Speaker rings for your vintage Polk's...
In for a set of 3.1's and 10's. Would like a set for my RTA 12c's too. Maybe my 5jr's and Monitor 12's too!HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
I'm in for a complete set for CRS+'s. I definitely want the tweeter and xover plates when they become available as well
Larry.... a thought, if you run some of the xover plates, perhaps run a couple ones for those of us with round plates.
I have a set of Trey's cup plates I havent used and I could gladly send it your way to help you measure and cut the round cup plates if you need."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Larry.... a thought, if you run some of the xover plates, perhaps run a couple ones for those of us with round plates.
Yep
DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3 -
I found the tweeter bracket file!!
May I suggest you pass along a copy to someone as a backup measure
Good news, but I have to ask - how critical are these?? Will they help as much as the driver rings?? Not being critical at all, just curious.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Let me know if you need a set for a template Tool.
You don't need to call him names.... wait, what?
I’M OFFENDED!!!! -
I’M OFFENDED!!!! -
OK so i'm in for a 2.3tl set and say 6 tweeters.
I’M OFFENDED!!!! -
vmaxer, there is no effect on the audio by using the tweeter brackets. There is a great effect (upon you) from the comfort in knowing that the screw holes won't ever be stripped out after installing the tweeter brackets.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I just checked over at the other place and none of these upgrades matter.Everything sounds the same.Always.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
brgman, I am not sure if you were being sacrastic (in general) or towards my response. I will say that I noticed a HUGE improvement in the clarity and detail produced by all SDA's I installed Larry's ring into.....HUGE.
However, I did not notice any audible improvement after installing the tweeter brackets into any of my SDA's; only what I described above I hope this resolves any issues anyone had with my response above.
I am fairly certain his comment was not aimed at you and was a veiled inference to the thread that talks about AVSForum, where all things sound the same and meant entirely in jest....
I am sure he knows they make a difference in real life.
EndersShadow wrote: »I just checked over at the other place and none of these upgrades matter.Everything sounds the same.Always.
This^^^ that's the way I took it..
Greg is dead on about the tweeter brackets though..
Yeah, my initial thought too guys. Just clarifying on my end.
Sarcasm.
Oye.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Finally, I can post!! Toolfan66/Larry I am in for a set for SDA 2B"s/studios $47.04 plus shipping."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Toolfan66,
Please remove my request for SDA 2B rings for now. Thanks, Harry"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
Larry,
I sent a note but havent heard back. In for a set for 2.3tl's, 2b' and CRS+.
Please send me payment information.
nrsheets2@gmail.com
Thanks in advance,
NathanHome Rig
SDA 2.3TL's front and center
Polk 1000p Center
Pioneer Elite SC35 Receiver (Pre/Surround
Sunfire Cinema Grand 5X200-Back in the mix.
OPPO BDP-93
Squeezebox
Stepped up to name brand Speaker Cables and interconnects!
Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
Sales Rating #1!! -
Larry,
I sent a note (at least I tried to send a note) also but haven't heard back. It could be I'm not using the new system correctly. Just when I was getting my feet wet with old system they went and changed it. Can someone explain how to send a PM using the new system or point me towards a thread that explains it. Thanks, DonSpeakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5 -
Mobile or computer??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
home pcSpeakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
Guys please give me a few to take care of the orders I have, it will make it less confusing on my end, I will get to you..
I also have more 12" rings in stock, and I will have some tweeter brackets soon..
For those of you guys that have paid me, and waiting for your orders to ship, the button head cap screws have not come in yet, I was told today they will be here on Monday so your orders will ship next week. Sorry for the delay I really thought they would be here this week, I had no idea they sent them out to be black zinc as I have never had to wait on them this long..
Thanks for being patient, and understanding, I want them shipped as much as you want them in your hands
Ring Man.. -
Ring Man..
No worries man, I am in no rush just didn't want to miss out!!
Thanks for what you do for us!!
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I need a set for a pair of 2.3 TLsMain System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis -
No rush Larry, just wasn't sure if I was using PM correctly. Think I got it figured now.Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
I haven't figured out pm's yet on the new forum. I'll need the payment info for 2.3 rings. Thanks."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Ok guys!!!
Everyone that has paid will ship out tomorrow, packed and ready to go!!!
I am ready for round 2 of orders!!!!
