Found product for butyl rubber surround repair
drumminman
drumminman Posts: 3,396
edited August 2014 in DIY, Mods & Tweaks
Was looking around for something to repair a 1/4" split in the surround of an MW in the CRS+ I just acquired. Found in a google search that some had success using bicycle inner tube patch glue sans patches.
Started reading up on chemical vulcanization, which this stuff claims to do, and found many bike riders swear by this product: http://www.amazon.com/gp/product/B002CO6T7K/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
So I bought some. I put one coat on each inside edge and three each on the inside and outside of the surround brushing it about 1/2" past the tear in both directions. Let it dry for 30 minutes and it would not come apart when pulling. Best of all, the flexibility of the rubber feels unaffected and it seems to soak into the rubber so that it doesn't make a thicker part where the repair is.
Only $5 with free shipping.
Post edited by drumminman on
  • fluffy
    fluffy Posts: 71
    edited August 2014
  • westmassguy
    westmassguy Posts: 6,850
    edited August 2014
    For a split that small, you could have used a toothpick, and some cyanoacrylate (super glue)
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • drumminman
    edited August 2014
    I've used the Loctite super glue gel before, and it worked pretty well, but this stuff seems to soak into the rubber instead of sitting on top. Like I said above, it didn't change the pliability, whereas super glue felt brittle.
  • Simplyrandom
    Simplyrandom Posts: 119
    edited August 2014
    I had read about that stuff before as well but just had not gotten around to ordering it. I like the fact that its a vulcanizing compound and it stays pliable.
  • westmassguy
    edited August 2014
    Just be very careful whatever you use, the Polk rubber surrounds are paper thin compared to most others I've serviced.
  • drumminman
    Update: I have 200 plus hours on my modded CRS+, including the MW repaired per above. Just had a look at the repair and it's holding without issue while remaining as pliable as the rest of the surround. Good product!
  • lawdogg
    lawdogg Posts: 470
    Thanks for following up on this. I have the same kit sitting waiting for me to use on a torn MB Quart 6.5" car speaker I have. Will go ahead and do it with peace of mind!
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • ROHfan
    ROHfan Posts: 1,014
    Really good find, Drum, I'll definitely keep this in mind.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • scotvl
    scotvl Posts: 88
    Thanks for the info, will come in handy to fix the surround I punctured with a screwdriver while installing the speakers on my boat.
  • stogie
    stogie Posts: 230
    I too have used the Rema cement and it seems to be holding up fine. See before and after pics
    Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
    Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
    Power Amp: Sunfire Architect's Choice Series II
    Preamp: Adcom GFP-750
    SACD/CD: Oppo BDP-95
    Tuner: Sansui TU-717
    TT: Technics SL-MA1
    Phono Pre: Emotiva XPS-1
    Music Server: Mac Mini w/JRiver - iPad w/JRemote
    DAC: Eastern Electric MiniMax Plus
    Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
  • drumminman
    scotvl wrote: »
    Been there, done that :s
  • Polkie2009
    Polkie2009 Posts: 3,834
    Thanks for the rema patch tip drumminman!
