One Day Interest/Sale Thread - Jantzen C Coil 16MH SDA Inductor
VR3
VR3 Posts: 29,630
edited October 2014 in DIY, Mods & Tweaks
Jantzen 16mH 14 AWG C-Coil Toroidal Inductor Crossover Coil
Introducing new Jantzen C-Coil inductors, specially engineered for bass, sub-woofer and amplifiers. These inductors utilize a toroidal iron core design providing extremely low resistance and high power handling. The core is epoxy coated to secure against short circuit even at very high load. Power handling is massive at 700 watts RMS, making them perfect for high power passive crossovers
Specifications: • Inductance: 16.00 mH • Wire gauge: 14 AWG • DC resistance: 0.164 Ohms • Power handling: 700 watts RMS.
$77.50each + $13 shipping.
6-8 Week Lead Time
  • vmaxer
    vmaxer Posts: 5,121
    edited August 2014
    VR3 wrote: »
    Jantzen 18mH 14 AWG C-Coil Toroidal Inductor Crossover Coil
    6-8 Week Lead Time
    What speakers and where are these used?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    VR3 Posts: 29,630
    edited August 2014
    Oh my...
    Quite a few...
    I want to say every SDA in your signature! :p
    So, the 1.2TL - 1C is a match
    Also the $13 shipping is regardless of quantity
    These are the large inductors that is usually mounted underneath the board
  • vmaxer
    vmaxer Posts: 5,121
    edited August 2014
    At the moment I have the following SDA's:
    1C's 3 sets
    2B- 1 set
    CRS + 1 set
    1.2 TL's 1 set
    Is this the inductor I have read about that helps the low end? Sorry for my ignorance.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    VR3 Posts: 29,630
    edited August 2014
    Yes this would be for all of your speakers replacing the largest inductor. This it's one that helps with bass response. This inductor has extremely high power handling and ultra low dcr and is very well damped while remaining affordable
    F1nut Posts: 52,156
    edited August 2014
    Is the 18mH a typo?
    VR3 Posts: 29,630
    edited August 2014
    Yes, I tried to edit it but it wont let me...
    16MH :)
  • jonicont
    jonicont Posts: 283
    edited August 2014
    How difficult is this mod. Does your amp need to be able to handle a 2 ohm load to use these?
    DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • headrott
    headrott Posts: 5,496
    edited August 2014
    As well as the question above, does it matter how many are ordered? That is, does it make a difference in price if we order more? Thanks Trey.
    VR3 Posts: 29,630
    edited August 2014
    Double post
    VR3 Posts: 29,630
    edited August 2014
    I would prefer orders of two.
    the order goes through tomorrow. :-D
    The inductor would need to be mounted to substrate and attach to the enclosure wall or fastened some other way then either connected via male disconnects to the old connectors or soldered with new wires, I would give it a 2 out of 10 on the difficulty scale... :)
    As far as amp loads, I think as long as your amp is capable of handling a 4 ohm load and is handling your speakers currently without problem you should be ok.
    As far as quantity discounts... hmmm, I think it is quantity of 10 is 10%
  • jonicont
    jonicont Posts: 283
    edited August 2014
    Ok. I'll take two
    VR3 Posts: 29,630
    edited August 2014
    Please email me at Vr3mods@gmail.com with the quantity you would like - please include your paypal email
    I will send invoices tonight or tomorrow before lunch and the order will go through before 530 EST
  • dhlogic
    dhlogic Posts: 26
    edited August 2014
    VR3 Posts: 29,630
    edited August 2014
    Also, I will special order any other inductors you guys may need at the same time, just want the order going through tomorrow before 530 -
    So .4 MH (22 awg AC), 1 MH (18awg AC), 2 MH (20 awg AC), .7 MH (25 awg, AC), whatever! :P
    2 x 16 MH C Coil are spoken for!
    VR3 Posts: 29,630
    edited August 2014
    4 x 16 MH C Coil are spoken for
    If we hit 10 I will inquire about a discount and send refunds accordingly...
    I don't believe the 10 quantity will qualify on special order coils but it does not hurt to ask.
    VR3 Posts: 29,630
    edited August 2014
    Up to 6 * 16mh inductors
    Will close this at 12pm today
    Thanks!
  • nspindel
    nspindel Posts: 5,343
    edited August 2014
    This should be a great upgrade. I replaced my inductors with Solens already, or I'd be all over this.
    For those of you with CRS+ or 2B crossovers, you should think about taking Trey up on the offer to get the other inductors, because Jantzen have parts that are exact matches for these crossovers. Nothing to measure or unwind, just use them in stock form:
    nspindel wrote: »
    For the board inductors, you can order them from parts express. When I bought them it was a bit over $40 for the six inductors, shipping included.
    Here is the link to all the Jantzen air-core coils:
    http://www.jantzen-audio.com/wp-cont...18-11-2013.pdf
    You'll want these:
    0.4mH 22GA - index #000-1489
    1.25mH 20GA - index #000-1137
    2.5mH 20GA - index #000-1695
    VR3 Posts: 29,630
    edited August 2014
    Have had two folks order those, no problem
  • nspindel
    edited August 2014
    Awesome.
  • vmaxer
    vmaxer Posts: 5,121
    edited August 2014
    I just sent an email.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • gimpod
    gimpod Posts: 1,793
    edited August 2014
    Just to clarify a few things for people getting these inductors.
    1. This 16mH inductor will only work on these 4th & 5th gen SDA's, CRS+ (1987+, maybe being an iron core inductor there may not be enough room to mount it far enough away from the driver magnets so they wont interfere with it working right), 2B's, 1C's, SRS 2.3TL and SRS 1.2TL. It's the wrong value for the other SDAs Here a link to an updated table of Inductor Values
    2. This inductor having such a low DCR of 0.164 Ohms ver's the stock 2.8 Ohms will cause these speakers dip really low impedance wise (maybe < 1 ohm), We all ready know that stock SDA's can and will drop to 2 Ohms or less impedance wise. Just keep an eye on your amps temperature. As long as it doesn't get much hotter than it does now you should be fine.
    Not meaning to scare anyone off or thread crap.
    VR3 Posts: 29,630
    edited August 2014
    Thanks Anthony,
    This inductor has a little less resistance than the Suoer Q (.50 ohm) so I would not suspect anyone to have any problems. Like you said, just be smart about their use and use it like you normally would.
    Zltful,
    Shoot me an email bud and lets see what we can work out
  • agfrost
    agfrost Posts: 2,482
    Hey Trey, any ETA on these?
    Jay
    Jay
    VR3 Posts: 29,630
    Was told they should be here by October 20th, they would ship out shortly after that.
    I appreciate everyone's patience.
    It is best to direct inquiries to my email vr3mods@gmail.com
  • agfrost
    Thank you for update!
    Jay
  • vmaxer
    vmaxer Posts: 5,121
    VR3 wrote: »
    Great, looking forward to this. Now I need to get busy on the cable - just been on the road too much for the last few months...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • PolkieMan
    PolkieMan Posts: 2,446
    I will be interesting to see what results that you guys get with these.
    VR3 Posts: 29,630
    These should ship this week. Will keep everyone posted!
    Thank you for your patience!
  • agfrost
    Cool. Any thoughts on how you'd choose to mount this in a pair of 2B's?
    Jay
  • TNTsTunes
    TNTsTunes Posts: 751
    Any extras available? I could use two pairs... at some point in time at least.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
