SDA CRS+ Inductors
audiocr381ve
audiocr381ve Posts: 2,588
edited June 2014 in Vintage Speakers
I've been busy with audio lately. I'm diving into another project already. My minty CRS+'s have already been TL'ed but I'm replacing the Solen's in the high pass (trying to sound like I know what I'm talking about) with Sonicaps which should be here tomorrow.
I was just wondering where to order new 16 mH inductors and which ones I should get? I know DarqueKnight had the NorthCreeks and then switched to Solen's. I also noticed Trey replaces the inductors on the boards as well. Does anyone know where I can find those?
Thanks!
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited June 2014
    I think Trey had some inductors for sale a while back.Not sure if they were for your CRSs but cant hurt to ask him.If he doesn't have them he could point you in the right direction.
    Dan
  • westmassguy
    westmassguy Posts: 6,849
    edited June 2014
    Are you set on air-core? If not, the Erse SuperQ Laminated Steel would be your best choice. They don't make a 16mh, you'll have to buy a 17mh or 18mh and unwind it.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Stew
    Stew Posts: 648
    edited June 2014
    ...or use a 15 mh Erse super Q. Sounds great in my 2b's.
    SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
    1000VA Dreadnought
    Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
    Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
    RTiA3, Onkyo TX-SR605
  • audiocr381ve
    edited June 2014
    Toolfan66 wrote: »
    I have the Solens in my 1.2tl's, and the Northcreek in my CRS+'s. The Solens IMO are too large for the CRS+'s. I have always wanted to try the Erse SuperQ's maybe someday I will..
    Shane, I think for the price, and the positive reviews here you should try the SuperQ's, also the size of them would be perfect, but I think asking Trey if he has a full set of inductors for the CRS+'s is worth asking as well..
    You can't go wrong either way IMO. You have come a long way since being here, how's that new sub blending in??
    Haha this is true Larry. The sub is exactly what I needed for the Totem Hawks. The sub I had before did just fine for a $300 sub, so buying the new one was more about matching finishes (and curiosity). I'm having a hard time picking up the differences between the two and I really thought I would. Other than SPL & how low each one digs, I can't pick up any difference in tone or definition.
    These are the ones right? https://www.parts-express.com/erse-super-q-17mh-16-awg-500w-inductor-crossover-coil--266-956
  • audiocr381ve
    edited June 2014
    Should I go with the 15 mH or the 17mH?
    Whatever ever gives me more bass the better ;)
  • westmassguy
    edited June 2014
    If you want to do it properly, buy the 17 or 18mh and unwind it to the proper value using an LCR Meter.
  • nspindel
    nspindel Posts: 5,343
    edited June 2014
    I used a Solen, it does fit.
  • nspindel
    edited June 2014
    For the board inductors, you can order them from parts express. When I bought them it was a bit over $40 for the six inductors, shipping included.
    Here is the link to all the Jantzen air-core coils:
    http://www.jantzen-audio.com/wp-cont...18-11-2013.pdf
    You'll want these:
    0.4mH 22GA - index #000-1489
    1.25mH 20GA - index #000-1137
    2.5mH 20GA - index #000-1695
  • westmassguy
    edited June 2014
    The 22 gauge would be special order. They only stock up to 20 gauge.
  • nspindel
    edited June 2014
    Correct. They take a while. You might want to consider a nice Dueland resistor upgrade, another Europe special order, while you're waiting for the inductors.
  • drumminman
    drumminman Posts: 3,395
    edited June 2014
    I was pleasantly suprised when I replaced the factory inductors on the board of my 2.3TL's with the Jantzen. I just did it out of curiosity, but the speaker smoothed out top to bottom, especially noticeable in the mids. The kind of thing where I didn't think improvement was necessary or possible, but there it was.
    I had already rebuilt the boards with Sonicaps and Mills.
  • nspindel
    edited June 2014
    Shane, are you using Tony's boards or stock?
  • Stew
    Stew Posts: 648
    edited June 2014
    The 15 will give slightly more mid bass. I'm very happy with the results in my 2b's. I don't know whether or not the CRS+ would benefit from a touch more mid bass. There are somd old threads on this if you search for "Erse". I don't remember the details but I think someone unwound a 17 until it sounded right ... and ended up close to 15.
    1000VA Dreadnought
  • Stew
    Stew Posts: 648
    edited June 2014
    I found an old thread that says Erse will make a 16 mh for $10 extra. That might be an option. Has anyone actually compared a 15 and 16 mh in a CRS+ or 2b?
    1000VA Dreadnought
  • audiocr381ve
    edited June 2014
    nspindel wrote: »
    You'll want these:
    Ah perfect! Thank you for the link & index numbers. I'm using the stock boards but I do have Tony's boards collecting dust. I honestly just don't want to deal with mounting them.
    For the big inductors, are these the ones to get?
    https://www.parts-express.com/erse-super-q-15mh-16-awg-500w-inductor-crossover-coil--266-954
    They are 16 awg. I remember someone saying there is a 14 awg (I could be wrong) but I can't find it.
  • audiocr381ve
    edited June 2014
    Stew wrote: »
    That sounds good to me. I'm a big fan of mid bass :)
  • westmassguy
    edited June 2014
    You can purchase the 14 gauge directly from Erse. I would still recommend purchasing the 17 or 18mh inductor, and unwinding it to the proper value. Polk didn't choose 16mh out of thin air, the value was chosen for a reason. You'll be changing the crossover frequency for the dimensional woofer, and altering the design.
  • audiocr381ve
    edited June 2014
    Thanks westmassguy. I'm now working with Trey on this and he's going to grab all the parts for me. I'm sure he'll be using the correct values.
  • westmassguy
    edited June 2014
    No problem, good luck, Trey will get you squared away
