RTi12
tophatjohnny
tophatjohnny Posts: 4,189
edited June 2014 in Speakers
Planning on snagging a pair of these babies and hoping my Parasound 1200 HCA will do the job?? Moving away from my SDA 1B's not for any reason other than lack of ear bleed capability, and still love my SDA's for that quality vibe. Please don't try to talk me out of getting the 12's as my heart is set on it. I love the look and have heard after the break in period they will do what I want them to do...(kick my but) lol
Post edited by tophatjohnny on
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited June 2014
    OK Brother I will start you off.Are you out of your frickin mind?Maybe one to many drum sticks to the head? :-)
    Johnny whatever floats your boat.
    I think you should hang on to the 1Bs,at least in the closet for a while to be sure.
    Dan
  • tophatjohnny
    edited June 2014
    Dan, much love for ya (you know that) and I doubt the SDA 1B's will sell, so question was poised at weather or not the Parasound 1200 HCA will serve well with the new towers?? I love my SDA 1B's and with the upgrade tweets, dynamat and Larry rings, they sing great. Just not ear shattering enough. I have the RT2000i's in the living room and they achieve the volume I like. I will hang on to my 1B's, and will not give em away. Thanks again Dan, you are a true brother to me.
  • B Run
    B Run Posts: 1,888
    edited June 2014
    I love my Rti12's! That amp will power them but like with anything, going bigger wouldn't hurt either. I'm running them with an SC-35 and while I know that's on the lower end of the power they need, it still sounds great.
  • Oldfatdogs
    edited June 2014
    I think you will be OK at 200 watts.Or you could always up your power a bit,just trying to help you spend some of your money. :-)
    Maybe those SDAs would put a smile on a young Marines face as a welcome home from Mom and Dad when he comes back home.
    Dan
  • Geoff4rfc
    Geoff4rfc Posts: 2,832
    edited June 2014
    Okay, since you're guessing they won't sell, you could send them my way :)
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
    F1nut Posts: 51,751
    edited June 2014
    I believe you will be disappointed if shear volume is your goal.
    Your amp is rated at 205 wpc @ 8 ohm and 315 @ 4 ohm.
    The 1B's are 4 ohm nominal with a 92dB efficiency rating and the RTi12's are 8 ohm with a 90dB efficiency rating, which means the 1B's will play louder. Approximately 117db for the 1B's and 113dB for the RTi12's.
  • tophatjohnny
    edited June 2014
    Geoff4rfc wrote: »
    more like I'm guessing I wont well the 1B's. I still love em!!
    When we took the RT2000i towers up to the bedroom to check out the volume difference it was night and day, with the RT's just killing the 1B's in volume, so why wouldn't the RTi12's do just as good if not better with the volume??
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited June 2014
    I would set the bar a little higher for amplification to drive the 12's. All those woofers suck a LOT of power, I ran 325 wpc into mine and they still wanted more.
  • deronb1
    deronb1 Posts: 5,021
    edited June 2014
    Johnny, I had the 12s and they will slam. You could always power the bottoms with the parasound and power the tops with the Onk and see what you think
  • tophatjohnny
    edited June 2014
    Thanks D. doing that is waaay above my head, and in doing this, would it hurt anything?? other than that, already looking at a more powerful amp. Don't see how I'd control the volume if I separated the parasound and the onk to do this?? Wouldn't the onk only control the tops??
  • deronb1
    edited June 2014
    Nope, the onk will control both. I did this with mine using a Kenwood Basic M2 (220wpc) for the bottoms and the Pio for the tops. Bottom end really came out. Are you bi wiring now?
  • tophatjohnny
    edited June 2014
    more like I'm guessing I wont sell the 1B's. I still love em!!
    I meant sell...oh well?//lol
  • tophatjohnny
    edited June 2014
    deronb1 wrote: »
    D, I am in the dark as far as (bi wiring goes) and not to sharp with any of it..you know that. I just like it sounding good, and good and louder than the 1B's is what I'm after. sending you another PM
  • thsmith
    thsmith Posts: 6,082
    edited June 2014
  • tophatjohnny
    edited June 2014
    thsmith wrote: »
    Goodness..to rich for my blood, although we just hit on a pick 5 50 cent ticket, so we may have some extra dough here this morning?? headed over to Krogers to see what we won as soon as our Granddaughter is picked up at 10am. wish me luck, never won before.
  • Geoff4rfc
    edited June 2014
    I first ran my A9's on an Emotiva XPA-2 stereo amp, 300wpc, I'm now running them off a pair of those in bridged mode which supplies 860wpc..............I must say, it's very nice.
    Set up:
  • Sea
    Sea Posts: 317
    edited June 2014
    I have a set of RTi12's. I have amped them two ways, both using 2 Carver TFM-35's. I have powered one speaker with each amp. This would provide 700 watts to each speaker and I currently have them bi-amped which provides 250 watts to the HF and 250 watts to the LF. I am not sure I understand the reasons but I think the bi-amped sounds better and gives more detail. I never get my Carver C-11 pre higher than about 25% but the volume is substantial.
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • tophatjohnny
    edited June 2014
    struck out on the lotto ticket. The numbers were not in order and it was a straight to win. Wife punched it in the computer and it said we won something?? Notta ! oh well.
    F1nut Posts: 51,751
    edited June 2014
    Then something is wrong with your SDA's.
  • teekay0007
    teekay0007 Posts: 2,289
    edited June 2014
    Johnny, did you ever get anyone to look into those "faulty" SDAs you had? The ones that didn't even have any wires to the big woofers at the bottoms of the cabinets.
    That might be the problem right there. ;-)
  • tophatjohnny
    edited June 2014
    teekay0007 wrote: »
    no, still no wires hooked up to them big woffers at the bottom, but the SDA God'd mysteriously send a booming sound through both of those faulty holes anyway?? Can't figure that one out for the life of me??
    F1nut Posts: 51,751
    edited June 2014
    It seems the tweeters are shutting down in the 1B's at higher volume levels. The polyswitches are shot and need to be replaced with new RDE090A's or jumped or replaced with a .5 ohm resistor.
  • tophatjohnny
    edited June 2014
    Trying to figure that out and will get on it
  • Geoff4rfc
    edited June 2014
    Dude, I know you want those 12's especially at such a great price point, God knows I enjoy jamming on my A9's 2ch style....BIG TIME!!! But if those SDA's of yours are as bad a$$ as I think they are and as everyone else here is implying.......dude, put the money into fixin those bad boys and strap in. Twice the midrange, twice the tweeter, those things (when in full operating status) have got to be fa-reaking awesome.
    Do it for me or I will hunt you down and take them from you :)
    Kidding of course but dude!!!!!
    Set up:
  • tophatjohnny
    edited June 2014
    Geoff4rfc wrote: »
    Yes, I am making plans to upgrade the crossovers, but still getting the 12's before I do that! The 1B's are here to stay!!
  • tophatjohnny
    edited June 2014
    Ok, came to my senses and after some research, I am off the RTi12 idea, but now thinking of LSi 25's will be more my thing in a few months here?? Trying to get my 1B's upgraded all the way first. Back to earth...if that's possible??
  • deronb1
    edited June 2014
    The 25s have been noted as having a more laid back sound. 4 ohm i believe. Modding is always a good idea, but it wont change the sound signature. It brings out a speakers full potential. Try and get your ears on the 25s and 12s. Only way to be sure what is going to work for you. Just my .02
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited June 2014
    Depends on the size of your room, but You'll need moar power if you want ear bleed status. Unless by ear bleed you mean a strained, compressed sounding music that is NOTHING but loud.
    200wpc is the entry point where the 12/9's start to really sound good, but anything above 90db in my room at the MLP they started to sound strained with the Parasound HCA-2003a and 220wpc. Moving to the HCA-3500 with 350wpc and a dump truckload more current got me to about 104db before the music started sounding strained and compressed, but dear God, listening to them regularly, hell no. 85-90db is rocking out pretty good.
    Keep in mind I have a 17x35 main listening area, smaller room will produce different results.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
    F1nut Posts: 51,751
    edited June 2014
    Do you have a dedicated 20 amp line running to your amp?
  • Tronman
    Tronman Posts: 72
    edited June 2014
    Don't forget 3dB is twice as loud or 1/2 as loud depending on which way you go on the dB scale - I definitely think a bigger amp is in order ;-)
