Does high quality digital cables matter?
1181921232427
  • Habanero Monk
    Habanero Monk Posts: 715
    edited June 2014
    I've seen people put expensive tires and rims on junk cars. I've seen guys spend millions of dollars on whores. Just because some people do stupid things and spend money foolishly is no reason to generalize that to the mainstream.
    Well, a wise consumer should know what they are getting with a power cord and the expected benefits. Every aftermarket power cord I have purchased had manufacturer supplied information on its construction and capabilities. They also offered a full refund return policy if the cords did not perform favorably in my system. PS Audio went even further by providing return shipping.
    An electrician charged me $425 to install my dedicated AC circuits. There are aftermarket power cords at, above, and below, that price point.
    I'm not even sure that a $2300 PC will always make more of a positive difference than a $1000, or cheaper, PC. A person who has taken the time to educate themselves on power quality basics would never think that a power cord would be more effective in reducing line noise than a good power conditioning unit.
    Agreed on all points. I'm totally willing to try items out. I'm totally willing to let it be a blind process. There are a lot of places to order items from for testing and more than reasonable return policies.
    My AQ Vodka is due back by the 23rd and my curiosity is only going to run my $9 to return it. Very fair.
  • Habanero Monk
    edited June 2014
    No, they put them in to lower the noise floor, which is the main goal of all the power treatments.
    Power cords with a removable ground pin will and for some is all they need.
    Is there a power cord with a proven, measurable ability, to increase up to 12dB DR for line level electronics? Reduce inductance in the PC, remove ground loops?
    Lifting the ground at the power cable is potentially dangerous.
  • Habanero Monk
    edited June 2014
    headrott wrote: »
    Haha! You guys are absolutely rediculous! So, once again because something pointed out to you doesn't fit your agenda and so you don't want to discuss it! Too Funny!!
    If you remember correctly, we are not talking about TCP protocols, computer data transmissions, wireless routers, DSD transmissions, or anything else but digital cables correct? An ethernet cable is a digital cable is it not? After answering "yes" in your mind please read below......
    You brought up the idea that it doesn't matter what is sent through the ethernet cable because it is "just data", and that it doesn't matter what the transmission consists of, it is all "just data" and it either get's there or it doesn't regardless of what type of "data" is sent through the ethernet cable. This is the same ideoloy that villian holds.
    I then re-posted my post from page 2 to point out that it absolutely does matter what is sent through the ethernet cable and showed you why. It also matters what the cable consists of (what it's is comprised of) that will make a difference on the success or failure of the "data" tranmission as shown by my example. I switched from my self made cable to the Acoustic Revive Ethernet cable and the DSD signal transferred successfully and sounded better than any other ethernet cable I have used before or since.
    Since the context of this thread is digital cables it covers quite the gamut. Outside of telco (CAT3) and Ethernet Data (CAT5/6/7) there is no other directly prescribed use for those cables.
    Anything else is 'off label' use and something I'm not really interested in talking about. CAT5-7 is designed for computer networking. That is what I have been talking about.
    Again, I don't know if the cable you made passes spec or not. I don't know if the software stack that makes up Ethernet networking was dealing with a cable and it's short comings where the DSD software stack isn't so robust because it doesn't have the same goal as guaranteed delivery. And I honestly don't care.
    F1nut Posts: 51,778
    edited June 2014
    Dedicated lines are extremely important, but they are only part of the equation.
    Not as dangerous as walking out your front door.
  • villian
    villian Posts: 412
    edited June 2014
    drselect wrote: »
    Thanks for the reply and the article. It helps further shed light on your ability to reason.
    What exactly does that mean? You asked for an answer and you got it, the factual one. Sorry if your butt hurts, but sometimes there really isn't any Grey area.
    Too many good quotes to list..waiting for some fresh ammo. :)
  • headrott
    headrott Posts: 5,496
    edited June 2014
    villian wrote: »
    Or Grey matter usage either.
  • 11tsteve
    11tsteve Posts: 1,166
    edited June 2014
    villian wrote: »
    Nonsense? Technically most consumer "Water Filters" are useless when it comes to filtration or treatment of water. They simply make water more palatable (Changing the taste and odor). They do nothing to filter or treat the water, and can in fact cause lower quality water to be output than what was input. The things they do remove, while sounding great on paper (Heavy metals, calcium, etc) are not really all that inclusive considering the big picture, and are often times desired. Water stripped of all outside content is unhealthy, and impossible to obtain in a home environment. That is unless you happen to have a home RO rig, which I very much doubt is the case for 99% of Americans.
    Amazing what you find when you look beyond the advertising stickers..Isn't it?
    actually, home R.O. filtration systems are more common than you think. The problem with RO water being that it is acidic and has a lack of minerals. However, remineralization/ionized water filters can be used to counteract this effect. These systems are quite
    popular.
    http://www.hawkeyeculligan.com/at-home-or-work/water-systems/q-culligansupregsup+drinking+water+systems-88
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • drselect
    drselect Posts: 664
    edited June 2014
    villian wrote: »
    "When you understand the nature of a thing...you know what it's capable of."
    "Never go in against a Sicilian when death is on the line"
  • drselect
    drselect Posts: 664
    edited June 2014
    ZLTFUL wrote: »
    Inconceivable!
    "You keep using that word. I do not think it means what you think it means."
  • villian
    villian Posts: 412
    edited June 2014
    headrott wrote: »
    Do you guys actually read and understand what is posted?? I am to say that the data was not transmitted accurately enough by the ethernet cable to pass the DSD signal. I know this for a fact because I then switched to the Acoustic Revive Ethernet cable and the DSD signal was successfully transitted from my modified denon player to my same (unaltered) self-built DAC.
    I don't see how that proves that certain data is "Harder" for a cable to transport than other data. IF that were true then you'd have to test and see the results in a different way than what you've experienced. Something like this..
    Cable A ---> Playback 2ch audio (PCM Bitstream 300kbs) ---> Success
    Cable A ---> Playback 7ch mixed audio/video (20Mbps total) ---> Failure
    Instead of your experiment of..
    Cable A ---> Fail
    Cable B ---> Sucess
    I don't know how you concluded that something is "Harder" or more strenous for a cable to transport when your results were obtained with 2 different cables...
    11tsteve wrote: »
    popular.
    Overall (Total US households) they're extremely rare. I've seen plenty, but even if I've seen hundreds that's nothing compared to the millions of households in the country. Either way my point was exactly what you just said..that minerals are stripped and added back in after filtration.
    Just don't get why some people here would be total dicks after answering their question. I guess they want some grey area where there isn't. I'm sorry but a molecule of water is only so small, and that happens to be larger than many contaminates...therefore you can't filter out those contaminates. Square peg, round hole. If they can't understand that they should probably just go ahead and deactivate their Polk account.
    tonyb Posts: 33,072
    edited June 2014
    Well said....lol ^^^^
    tonyb Posts: 33,072
    edited June 2014
    This thread is just too funny. Digital cables to water filters....LOL.
    Whats not sinking in is....if you can't hear a difference in cables, nobody gives a hoot. Rock on and enjoy what you have then. The problem always comes in with those who profess others who can hear a difference must suffer from some sort of placebo effect. The same ones who never go outside their own comfort zone and experience stuff for themselves. They are glad to tell you what you can or can not hear, but when you question their abilities and lack of experience they get their panties all twisted.
    Audio need not be as complicated as it appears by some of these threads. If your happy in your own little world audio wise, cool....rock out with your c@@k out. If not, there is plenty of ways to expand your horizons.
  • Habanero Monk
    edited June 2014
    tonyb wrote: »
    Toss in Ocean going ships, cars, car parts, and of all things absurd: Cake ingredients.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited June 2014
    Look in a mirror and consider the biggest absurdity of all: "Taking issue" with what someone else said they could hear to the point of devising an elaborate "proof" exercise.
    When you take the dubious step of saying it does X/Y/Z to the sound vs another competent CAT6 cable then I have to take issue since I understand how packet switched networks operate.
  • headrott
    edited June 2014
    I'm sorry you didn't learn anything from the analogies.
  • headrott
    edited June 2014
    villian wrote: »
    Cable A ---> Fail
    Cable B ---> Sucess
    Go back and re-read the post from page 2 again. I refuse to post it a 4th time. I used the same cable for two different "data" types and got different results...........
  • villian
    villian Posts: 412
    edited June 2014
    ZLTFUL wrote: »
    Pot, meet Kettle. Talk about a spade calling a spade. Why don't you follow your own advice? You can be a "Polk enthusiast" without being a "dick" but that concept evades you in a most glorious fashion. You can't come into a conversation without spewing troll cooties all over the place. Maybe if you actually debated a point instead of the inane name calling and flame baiting, you would find the "dicks" as you call them more receptive to your point of view.
    As my grandfather said, you catch more ants with honey than you do pouring gasoline on the ant hill and tossing on a match.
    And where exactly have I been a dick and name called others? Needless to say that I don't think I've been the least bit unprofessional..unlike you and a few others making snide remarks. That said, I'm all for debating BUT I'm not going to debate things that don't need to be debated. Some things are factual, and those things that have long since been proven have no need for debate. IE: What's to debate in water filtration? NOTHING.
  • Habanero Monk
    edited June 2014
    headrott wrote: »
    LOL. The Ship and Car analogy didn't quite work out the way the person making the analogy wanted so they abandoned the hot iron they were shown to have grasped and moved onto.... wait for it.... Cakes. Not sure chocolate or some other flavor.
    I STILL haven't seen a riposte to when I took that analogy to it's proper conclusion: The person driving the assembled car has not a clue that the ships arrived 4 hours apart.
    When you are shipping parts you are shipping parts. When you are shipping cars you are shipping cars. Parts to not the cars make
    Part of the make up of a car is the LABOR(buffering, bitstreaming, CODEC) that goes into the assembly and not only the transport of parts in the analogy that DK provided.
    I've never seen vehicles self assemble outside of a Michael Bay film.
    That fact that you haven't even figured out that even if entire, assembled cars were being shipped, the person that is driving the car off the showroom floor doesn't know if it was 4 hours ahead or 4 hours behind another same identical car. But I digress because that is not how packet networking works. Which is the only thing I am concerning my self with or willing to speak to: CAT5/6/7 used for on label use.
    So parts being put into shipping containers (actually cars disassembled into it's constituent parts) = packetization process (on a fixed frequency carrier and digital data)
    Time to port = 10/100/1000 (on a fixed fequency carrier and digital data)
    Ethernet standard packet (doesn't matter size 1500/4096/8000/9014: The ships
    Assembly= the assembly of data in buffer/CODEC/ bitstreaming to the sound device. Still digital data (just pulled out of packets and buffered).
    Driving= Listening to it on your speakers (analog data and multi-frequency)
    I mean for pete's sake I had to point out we aren't even doing this stuff on RTOS's. Not to be confused to ROES's :biggrin:
    So when you download your favorite album from HD tracks on a $60 router and a $1000 router is there a difference. Would you want to stake some money on that. Say the price of a really nice DAC?
  • DarqueKnight
    edited June 2014
    Go back and carefully read posts #614 and #644. I realize you think you are making a lot of sense, but when you think things through you might come to a correct conclusion.
    Again, the time of arrival of parts is irrelevant. What happened to the parts in transit and the accuracy with which the parts are reassembled are the relevant concepts.
    Tell me this. Assume you are going to ship your diassembled vehicle to Europe. Would you insure it as an automobile or as a collection of parts? If the ship sinks, would you want to be reimbursed for the value of the parts or for the total value of the car?
    You saying all this does not obscure the fact that you do not understand that a digitally encoded signal is still multi-frequency and wideband. The bandwidth and frequency relationships are still maintained in digital form, otherwise the signal could not be accurately converted back to analog. I'm assuming you are not being purposely obtuse, therefore I'll take one more stab at it.
    If a car is disassembled for shipping, some marking of parts had to occur so that the relationship between the various parts can be properly reassembled. Such a shipment would not be seen by taxation authorities and shipping authorities as a shipment of raw parts, such as those to a factory, but rather as a complete vehicle shipment, although the vehicle is in disassembled form. The receiver on the other end did not order a bunch of parts, they ordered a complete automobile.
    In other words, the labor that went into first assembling the car must be coded while in shipment so that the assembly process can be replicated at the delivery end.
    Not sure why you said this as I never explicitly stated or alluded to such.
    The bizarre thing is that you can't grasp that, for a non-isochronous process, packet time of arrival is irrelevant. What is relevant is what happened to the packet in transit and how the associated packets were reassembled into a complete data file.
    Again, you are assuming that the transport and reassembly experience of the two cars was the same. Mishandling and damage of some sort could have occurred in shipment. Errors and damage could have occurred in reassembly.
    You are assuming that:
    Each ship and shipping route is identical.
    Each assembly team will do an identical job.
    If there are shipping damage and assembly errors, no drivers will be able to perceive them.
    I am not sure why you keep asking me if I want to make a bet on a perceptual exercise that I have no training or experience in. Perhaps you think doing so makes your point seem more valid. I have already advised you twice to seek out those individuals who are claiming to hear differences in Ethernet cables. My position is that it is possible.
    I have asked you several times to provide the article you mentioned where some sales reps from either AQ or MIT met with Jim Salk and they could not pick out their company's cables in a blind test. Do you have proper citation for this or were you just parroting something you read on the Internet?
  • Habanero Monk
    edited June 2014
    For amplitude derived digital data absolutely not. There is a peak and trough threashold for starters. Once the peak or trough hit's the demarcation point for a solid 0 or 1 it's done.
    I understand your point. You are making the wrong one.
    You are saying that there is a potential for an AQ or Chord Ethernet cable to some how via what ever modulated method used is somehow potentially better at this than another certified cable that is well above spec.
    That's pure rubbish.
    First you have to prove that there is going to be a difference in error rate. If both cables pass the modulated signal with out error, the nano-scale measured timing variance doesn't matter because the computer OS isn't real time. It's NOT time sensitive on a scale that will translate into error that you can hear.
    Lets take a gross and overly simplistic example of this:
    BJC CAT6 that it's worst measurement is 200% above baseline. Well first off you have to be willing to make a hypothesis why this would introduce any significant timing errors that would produce an audible result.
    AQ Vodka 1.5 meter and assume it's no worse measurement wise an potentially better in some aspects.
    The receiving system is now at the mercy of the weakest link: The transceivers that make up the Ethernet PHY at both the NIC and the switch. Well you are kind of screwed there now aren't you? You have cables that at minimum have almost twice the performance metric needed.
    Now lets say we have JRiver setup and using the Play Back from RAM feature. That is 1GB of RAM is MMU'd off and the entire album is transferred with out any packet error. Just some nano-scale timing varience. You are going to sit there tell people here that a file that took 7.0001 seconds on cable A and Cable B took 7.00189 to transfer into RAM, then decoded, then bitstreamed to a DAC is going to have differences?
    If you can relate that to packet data let me know.
    It's not far as the cable is concerned. On the wire it is just DATA. You are having a failing to understand that this can all be turned into a mathematical equation. It's a construct. The only time is is purely still multi-frequency and wideband is the time it hits the microphone and is analog to the A/D and the time it hits the D/A and is again analog. Every thing in between is a simulacrum of the analog realm.
    You show me a O-Scope measurement of 250Mhz Ethernet where I can see if it's 20Hz or 20Khz then we can talk. I mean you are showing me a true 'analog' signal at that point.
    We are going to have to agree to disagree on that point. You certainly haven't made yours.
    If I 3D image your head, save it to a file, send it to a resin 3D printer 3000 miles away, is the signal still 3 dimensional and wideband as it goes through 28 hops? or is it just data?
    If the resultant bobble head is 5 inches by 8 inches did the cabling that sent the file have to be 6 by 9?
    If it goes through a $60 dollar router do you gain a funny mustache and goatee and if it goes through a $1000 router do you look like an uncanny rendition of George Clooney?
    You do realize that you are stretching the analogy. If you want to continue on that tangent I'm willing to entertain it provided you can find me a large scale auto manufacturer that assembles their cars, then disassembles them, ships it, then re-assembles.
    Because that is what data networks do all the time.
    What is bizarre is you still have yet to answer the simple question of if I sent a 24/192 encoded file of some well mastered music do you think anyone could tell me after playback if it landed on the computers HD via a $60/$1000/$58,000 router?
    Actually I made myself quite clear on this where MD5 Hashes are quite the rage for verification of file integrity.
    You are assuming more errors would happen on one vs another cable. You have brought nothing to the table data wise that would leave me no other choice then to line up with your anecdotal POV.
    You have to show me the actual error in order for me to see it.
    Absolutely not.
    Absolutely not. CRC of SMB/CIFS at the session layer, TPC at the transport layer, custom protocols at the session through application layer, is there for a reason including both benign and malign problems.
    Now once that file has hit my HD and plays back with out issue I am guaranteed delivery.
    My position is that it's not possible. I have actively put this out there at some other forums. A position that I would like to find a way to actively exploit people and the money they like to seemingly be fleeced of.
    Because if they think there is a night and day difference between two Ethernet cables that pass spec and are willing to pay hundreds of dollars. Well it's immoral to let a sucker keep his or her money.
    You could ask several more...
  • DarqueKnight
    edited June 2014
    Since you have convinced yourself that your hypothesis is infallible, then others may also become convinced that there is no point in participating in your "research". You present yourself as someone hell-bent on proving that people are either deluded or lying rather than someone interested in learning about network audio perception.
    A true scientist forms a hypothesis with the understanding that experimentation and observation may prove or disprove the hypothesis, or the experimental results might be inconclusive.
    In the scientific world, the burden of proof is on the challenger of a theory. For example, when someone said they invented ABX in 1977, I did not get in his face and ask him to prove his claim. I researched the topic and found that the ABX test was invented 27 years earlier, by Peryam and Swartz in 1950. The outside observer could then choose whichever source of information they deemed most credible.
    When a group of people claimed that the ABX and other blind tests were the only way to mitigate bias in stereo equipment evaluation, I did not get in their face and ask them to prove their claim. I researched the topic and found credible scientific evidence of consumer debiasing methodologies in addition to credible scientific evidence from the field of sensory science that said descriptive tests, rather than discrimination tests, are appropriate for the multi-dimensional sensory stimuli presented by a stereo sound stage. I left it up to the outside observer to choose whichever source of information they deemed most credible.
    People will be more inclined to take you seriously and assist you if you approach them in the spirit of honest and sincere scientific curiosity and inquiry rather than with a chip on your shoulder and a vulgar attitude of arrogant entitlement. No one owes you their time. Someone who has proven to themselves what they can hear has nothing to prove to you or anyone else.
    Ignoring a challenge does not equate to fear of the challenge. Bruce Lee, Muhammad Ali, and Mike Tyson walked away from a lot of street fights.
    That's what I thought. Thanks for the confirmation.
  • Habanero Monk
    edited June 2014
    I'm convinced how packet data works. I'm convinced transferring an entire album of 16/44.1 that is 50 minutes in human time in ~7 seconds and then playing it back from RAM all backed with the knowledge how TCP, how SMB/CIFS, works.
    I'm convinced when I downloaded both Vortex Box and FreeNAS ISO's that when I burn them to disc, insert them into a drive, boot and install those products that at the end I have exactly what was at the server that I downloaded them from.
    I understand leaving your options open. I mean try putting diesel in your car that takes gasoline. It COULD work. I guess I'll have to go and do oodles of research...
    Hey just because it doesn't work for you just means your only so so in your car driving skills. But someone else might be able to do it.
    I think it's rather telling that some major points that I have put across have still to this 18th page been totally ignored.
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2014
    Monk, it has been explained to you multiple times how jitter is introduced into musical files, and that it is possible for this to occur due to the Ethernet cable used in the final link to the hardware converting the data to SPDIF data. These packets will have no Ethernet errors, but will have musical errors. Yet you continue to ignore this. As DK said, a real scientist will have an open mind on these issues. No where have you demonstrated that the level of jitter in the musical file is the same regardless of the cable used. Instead you keep harping on irrelevent issues that DACs remove all jitter (not true), or it is inaudible. No wonder nobody takes you seriously.
    I did learn something from this thread. When a resume shows up, and the applicant states they have a Networking Certificate, it is going straight into the circular file. :rolleyes:
  • Habanero Monk
    edited June 2014
    BlueFox wrote: »
    A file transferred by BJC cable or a Audio Quest cable. Buffered entirely in RAM. You show me where the jitter is less. Show me the amount of jitter in the file.
    You do realize that jitter is in the time domain right? When I download a file from HD Tracks and it's stored on my HD jitter doesn't matter any longer. Jitter doesn't have a ringing period for petes sake.
    The next time Jitter comes up for that file is when it get's played. It doesn't matter a fig what the jitter was like on the initial transfer.
    Same as it doesn't matter what the jitter on the transfer of the file was to RAM. As long as the buffer is not under run the data is the data is the data.
    Jitter is a REAL TIME phenomenon. Windows, Mac OSX, aren't real time. This stuff gets dumped to a buffer. It's just a type of storage medium. The next possible jitter is the signalling on a stick of RAM as it's read out.
    Jitter isn't "part of the musical file".
    I didn't say DAC's remove Jitter. I said they RECLOCK the input. Jitter suppression. Jitter removal is impossible. You can only get it down to levels that are inaudible.
  • BlueFox
    edited June 2014
    Keep on digging that hole. You almost are in China by now. When you catch a clue then come on back. You have, once again, shown you have no idea what you are talking about. Ignorance is bliss.
    F1nut Posts: 51,778
    edited June 2014
    heiney9 Posts: 25,432
    edited June 2014
    DK's welcome point about transporting car parts via ship makes my point:
    You have two different ships show up 4 hours apart, they could have even come by different routes. They all get parts offloaded next day, cars assembled, trucked to show room.
    The consumer purchasing the car is none the wiser for knowing that the parts came by two different routes and 4 hours apart.
    Very poor analogy as time delay in an audio signal is detrimental, time delay in manufacturing isn't in your above analogy.
    tonyb Posts: 33,072
    edited June 2014
    Breath...wasted.
    Those that seek out nothing.....find nothing.
  • Habanero Monk
    edited June 2014
    heiney9 wrote: »
    BTW it's DK's analogy. And I did answer rather explicitly the time delay in the "manufacturing" or "assembly" process:
    In this instance the difference in arrival has nothing to do with the manufacturing. Both ships have arrived with parts in the window that they needed to arrive in. The assembly plant is still working with inventory at hand and the parts will arrive and sit there in a LILO manner vs parts already at the plant. It's a moot point.
    Look it's clear you guys are out of your native element here and that's ok. Let me finish up with ZLTFUL and then I'll move onto the rest of you.
    I'm dealing with people that believe jitter is 'Part of the Music File'. What is there really to say?
  • BlueFox
    edited June 2014
    Yeah right. You have clearly demonstrated your 'knowledge' over and over. :rolleyes:
    You are dealing with people who understand the issues related to digital music files, while you obviously do not. Go back and actually read the link you posted about jitter. Read other links about jitter. Quit thinking you know everything because you have a 'Certificate'.
    If you want to get spanked some more you can also start a thread about how you don't think power cords make a difference. :smile:
