Does high quality digital cables matter?
Sumerian
Sumerian Posts: 490
I am a strong believer of "Cables does matter" I use MIT Shotgun S3's both for my IC's and SC's.
I understand quality of cables make a lot of different wrt analog signal transfer. I hear the difference, I know the difference and there is no doubt about it.
But does this apply to digital cables like USB, HDMI etc.,?
No mater what the cable is , it just 1 and 0 's right? how does the quality of a cable effect in transferring this 1 and 0's
hope this is not a noob question but I am really curious.
Post edited by Sumerian on
«13456727
  • Speedskater
    Speedskater Posts: 495
    edited April 2014
    While digital audio does use a very robust system, once the cables get long (let's say about 40 feet) you should use a cable from a good manufacture like maybe Belden or Mogami.
    EndersShadow Posts: 17,704
    edited April 2014
    I would posit that a "good" cable from a brand like Audioquest is MUCH better than your standard USB.
    The ONLY usb cable I have seen recommended that was from a computer manufacture was Belkin.
    Otherwise just snag a Audioquest Pearl and know you haven't gone crazy price wise, but your better than your 2 dollar USB cord.
    As stated length does matter.
    What cables are you looking to know about (HDMI, USB) and what length are you looking at? That makes a difference.
    There is a thing called "jitter" that can affect digital signals. Lots of reading up on it if you want to know more, I wont profess to totally know everything on this matter so I will let the others chime in.
    tonyb Posts: 33,072
    edited April 2014
    Not as profound as the differences in analog cables, but they are there.
  • Sumerian
    Sumerian Posts: 490
    edited April 2014
    Yes I understand that with analog signal where amplitude varies and information should be preserved ... any variations wouldn't result in faithful reproduction at destination.
    But with 0 and 1 it will be 0 and 1 at the destination as it cannot become 2 or 3
    Anyways even I am not expert ...
    tonyb Posts: 33,072
    edited April 2014
    More to it than simple 1's and 0's being transmitted.
  • headrott
    headrott Posts: 5,496
    edited April 2014
    There are a fair number of "discussions" about digital cables and digital transmissions here on the forum if you do a search.
    OR, the short answer is "YES".
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited April 2014
    ^^ I think the answer is maybe, or they could. Depending on gear and application.
    txcoastal1 Posts: 13,511
    edited April 2014
    Just the quality of the build is a difference. The in-the-box generic cables such as USB/HDMI tend to separate at the connectors and you can tell the alloys used are sub par. At least do your system justice using a better quality built cable.
    Don't have to spend an arm & leg but the effect can be noticeable as you move up the ladder.
  • northernwind
    northernwind Posts: 57
    edited April 2014
    Sumerian wrote: »
    I can not speak for audio,but for movies,better hdmi certainly makes no difference what so ever..It is 10101010 after all.As long as the quality is decent,and the cable it self is not broken,you should see no difference what so ever in terms of picture quality.
    Tonyb-So what else is being transmitted?That is a very vague answer, and doesn't work as well as 'not all watt is created equal'which I concur.
    Edit-I have tried the audioquest chocolate hdmi vs my no name amazon brand,so I'm speaking from that perspective.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2014
    A wire is not just connection.
    Different wire designs must be considered.
    Cat5...not sufficient for 10GbE.
    Cat5e and Cat6 yes.
    Plug in an older Ethernet cable and expect connectivity just 'cuz its a conductor'...{eeeeee} annoying game show buzzer for wrong answer.....
    You can say 'ones and zeros' and a piece of wire is all that matters for connectivity - and you are SO wrong....
  • northernwind
    edited April 2014
    Erik Tracy wrote: »
    Cat5e and Cat6 yes.
    How does bringing up wires with different specification relate anything at all to what I said?In this case I'm talking about DIGITAL hdmi cables as I have no say,nor any experience with different ethernet cable....Why are you comparing hdmi 2.0 to 1.0?I'm making a comparison between cheap hdmi 2.0 spec vs expensive hdmi 2.0.A little reading comprehension goes a long way.
    Edit-I actually used them for myself,have you?Also just incase you still don't understand,ill repeat.This is only MY experience with HDMI cable.
  • Erik Tracy
    edited April 2014
    Cuz everything matters....
    We have done testing at our company for supposedly 'compatible' cabling within the same specification that doesn't work!!
    Just cuz some company says they are hdmi x.x whatever compatible or equivalent means NOTHING.
  • northernwind
    edited April 2014
    Erik Tracy wrote: »
    Oh wow........I'm talking about QUALITY between 2 WORKING CABLES.Not crap cable that doesn't work,while comparing it to perfectly working cables..First you compare ethernet to hdmi,now you compare working cable to non working cable....I've compare no name WORKING cables vs EXPENSIVE hdmi,and they both still do WORK.Obviously spec mean NOTHING if the cables don't work....And plenty of cheap hdmi last...Sorry for the cap,I just don't want to throw off your reading.
  • Erik Tracy
    edited April 2014
    Oh wow...one would think that in the 'pro' world that spec'd cables and interfaces would work.
    Sorry..but that isn't the real world...contrary to internet wanking.
    We found out that one vendors spec'd interface wouldn't work with another vendor...even though they claimed on paper they were...imagine that.
    What the "F" is "quality"????
    Try it and prove it - otherwise sit down and stfu.
  • Habanero Monk
    Habanero Monk Posts: 715
    edited April 2014
    Erik Tracy wrote: »
    Cat5e and Cat6 yes.
    CAT5 isn't designed for 10Gbe....
    He's not saying you can run 10GBe over a coat hanger. He specifically mentioned HDMI.
    An $89 AQ Ethernet cable is going to do no better at transmitting data than a $4 patch cable that also exceeds spec. In this case it is guaranteed that digital is digital.
  • Erik Tracy
    edited April 2014
    There is an annoying buzz...as if....ignored member......
  • Habanero Monk
    edited April 2014
    All you need to know is there are some chumps here that are all talk. All bark no bite.
    As a matter of fact I offered, while at the PETT GTG in Dayton, last summer to put together a computer with dual Radeon cards (that max out the HQV Blu-Ray benchmark) all going to a high quality display (with 2 HDMI inputs).
    The display would be calibrated for both inputs. A $20 Belden HDMI and any HDMI cable they wanted to bring. I offered up a ~$600 AQ.
    With that one could mirror the display and then simply A/B to their hearts content.
    F1nut Posts: 51,749
    edited April 2014
    The real reason is no one wanted to travel to Dayton, OH. Having been to Dayton a few times I can't blame them, so sod off with your lies.
  • Habanero Monk
    edited April 2014
    In retrospect while there were a lot of odd responses to the challenge, no one actually said they could do it (that is see the difference).
    Very much at odds with all the other HDMI cable threads when it comes to VQ.
  • agfrost
    agfrost Posts: 2,467
    edited April 2014
    ...like a moth to a flame...
    Jay
  • northernwind
    edited April 2014
    Erik Tracy wrote: »
    For a 3k plus post member,you absolutely make no sense at all.Are you ADD by any chance?You change topic on the fly,and most of the time what you say does not even relate to the what I'm saying,yet you respond to me.Sry If I knew you were special,I wouldn't even try to debate.Lastly WTF are you talking about?Pro world?I was comparing cheap hdmi to expensive hdmi.also,why would I need to prove my experience to you?Get some help please.
    edited April 2014
    nbrowser wrote: »
    Is it troll week or something ?
    Periodically a few villains tend to blow in with the northernwind
    They travel with the monks and sometimes bring ravioli
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2014
    txcoastal1 wrote: »
    LOL. On the other hand, there is some fun in watching them make fools of themselves. Especially the ones who take themselves seriously.
    F1nut Posts: 51,749
    edited April 2014
    txcoastal1 wrote: »
    Clever and witty!!! :lol:
  • ken brydson
    ken brydson Posts: 9,002
    edited April 2014
    txcoastal1 wrote: »
    Maybe I'm buzzed but this cracked me up. Well played...
    tonyb Posts: 33,072
    edited April 2014
    I knew this would turn ugly as most cable threads do.
    For the posters who claim no difference in 2 cables both meeting spec.....who's specs ? The manufacturers claims of meeting spec isn't necessarily true and there are no steps in place to verify such claims. So starting right off the bat you may or may not be comparing apples to apples. We have a few links from independent labs that did research on these spec claims and they found that alot were not up to spec.
    Assuming two different cables meeting spec, what else is there ? Quality of construction, metallurgy used...would you not say that can influence the sound ? How about the speed of the 1's and 0's ? Just a few suggestions that have something to do with the final sound. I do however still hold true to my thoughts that while sound differences in digital cables exist, they are not as profound as analog cables.
    edited April 2014
    tonyb wrote: »
    Tony here is another piece of the pie. We had ordered cables for LSAF (not mentioning the manufacterer tilll the show) one of which is a USB. They are sending an additional USB that has not been released to public but due to the metallurgy it has tested a lower noise floor.
  • Habanero Monk
    edited April 2014
    tonyb wrote: »
    IEEE.ORG
    tonyb wrote: »
    We used Wavetek 8600. All runs exceed CAT6 s
    tonyb wrote: »
    Spec is spec. You aren't going to get a cable that measures or exceeds spec and it not do it's job. Speed of 1's and 0's? I do understand you believe what you are saying.
    Does anyone want to bet on a certified CAT6 cable vs any AQ Ethernet cable you care to pick?
    tonyb Posts: 33,072
    edited April 2014
    Your arguments are valid for simple computer data transfer, however....we don't listen to data on a screen. Simply stating once a cable meets spec....or does it's job, is the be all end all in what it sounds like simply means you have not listened to any other better cables.
  • headrott
    edited April 2014
    tonyb wrote: »
    Exactly Tony. transferring and viewing computer data as 1's and 0's is "easier" for a cable than for the same cable to transmit music as 1's and 0's.
    As proof, I will offer up this: A couple years ago I bought some Belden solid copper core Cat 5e ethernet cable along with RJ45 ends to install onto the ends. I also bought some RJ45 crimpers costing $75.00 (NOT cheapies). I built the Ethernet cable and hooked it up to my router to transmit my online service to my compueter (I now use wireless). The cable worked fine. tranmitted data with no hiccups.
    I then hooked the same DIY ethernet cable up to my modified Denon DVD-1920 DVD/SACD player, which I installed an RJ45 output jack into and the other end hooked up to my (at the time newly built) DAC, also with an RJ45 input jack to transmit thepure DSD signalbetween the two.
    The result was that while the DIY ethernet cable worked between the my router and computer without hiccups, te same cable did not work between my modified DVD-1920 and DIY DAC. The data digital signal was not passed accurately enough between the Denon player and DAC (music). The digital data signal was passed between the router and computer with "seemingly" no problems.
    So, if they are just 1's and 0's and "just a digital data signal" why would one digital data signal work (between the router and computer, but not work between the Denon DVD-1920 and my DIY DAC?
    Answer: there's a lot more going on with 1's and 0's than what HabiMonk and other scoffers are admitting to and/or realise.
    Edit: I should point out that the same RJ45 jacks I initially installed in the Denon DVD-1920 and the DIY DAC are the same ones I used with a different ethernet cable and worked perfectly. Meaning the RJ45 jacks on the player/DAC were NOT the problem. It was the ethernet cable that was the problem and went away after switching to this cable: http://www.acoustic-revive.com/english/pcaudio/lan_cable.html
    Although I now use a modified Denon DVD-5910 as my DSD output player to my DAC.
