Audioquest SUB-X Subwooder Cable - 14ft.
kevhed72
Good Condition - pics coming.
40.00 shipped......thx
Post edited by kevhed72 on
Maybe a dumb question but what are the spades in the picture?
ken brydson wrote: »Maybe a dumb question but what are the spades in the picture?
For grounding the sub."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »For grounding the sub.
Never saw that on a sub cable. What do you connect them to? -
the idea is to ground the Sub to your preamp. You find a ground point on the sub amp like a chassis screw, then take to other side and do the same on the preamp or receiver. If your receiver has a Built in Phono preamp, you can use the ground terminal provided which I have done in the past for a dead silent Sub. The cable works as I have owned them myself. High quality and for the money it's a steal.
If you need a sub cable and the length here is good, grab it.Dan
I'll take it
Sold.
