What is better for making a 7.2 surround sound, FXiA4 or RTiA3?
PolishDude
PolishDude Posts: 58
edited January 2014 in Speakers
I already have RTiA5 towers, CSiA6 center, FXiA6 surrounds and two Polk PSW505 subs. What is a better speaker for creating a 7.2 setup? The FXiA4 or the RTiA3? Both are the same price from Polk's ebay store. I think the FXiA4 would look better on the wall obviously than the RTiA3. And which speaker would you use as the rear versus the surround?
Post edited by PolishDude on
    Toolfan66 Posts: 18,187
    edited January 2014
    IMO,, The 3's, put them in the rears..
  • PolishDude
    edited January 2014
    Any reason for that? Thanks
    txcoastal1 Posts: 13,519
    edited January 2014
  • B Run
    B Run Posts: 1,888
    edited January 2014
    I run Fxi5's on the sides and Fxi3's for rears and like them a lot. I have the sides set to Dipole and rears set to Bipole and completely fills the sides and rear of the room with sound, i've only had it a few weeks but really like the setup.
    edited January 2014
    PolishDude wrote: »
    I like the direct firing from the rear better, like I said my opinion, I have both and have used both, and I like the 3's better YMMV..
  • rpf65
    rpf65 Posts: 2,127
    edited January 2014
    One thing you may wish to consider in you decision is the size of the speaker. The RTI A3 are pretty big. They ar about 14 inches deep. They do have one of those mounting holes, but I personally wouldn't mount them on a wall. A very steardy shelf or stand would be better choices. I have a pair of RTI A1's for rears right now, using the A3's for surrounds, but that will eventually change.
    If you have the room, go with the A3's, if not I would suggest something from the FX series or consider the RTI A1's. The A1's are probably the biggest speakers I would personally mount on a wall.
  • PolishDude
    edited January 2014
    That is why I was thinking the Fxia4s. The side surrounds have to be up about 7.5 feet in the air so the rears will have to follow suit so I doubt a stand will work so the speakers will have to be wall mounted.
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited January 2014
    Lots of great info here:
    http://forum.blu-ray.com/showthread.php?t=170720
    Another thought, you can always mount the FXi with the woofer pointing toward the listener and run them in bipole, this is what I've done and it works.
    In the future I plan on expanding to 7.1 as well, I may try using a pair of Rt35i's I have as rears and the FXiA6 as sides.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • badchad
    badchad Posts: 348
    edited January 2014
    I use a similar setup with RTi4s as rear surrounds.
    I ended up mounting my FXi's much lower than most (maybe about 6ft off the ground). I was also forced to put the RTis near the ceiling in a downfiring position. Just food for thought.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
