SDA SRS1.2 with Erse SuperQ inductor modification
My bad, you were referring to his drawing not mine. Apologies.Love the idea, except I would look into lag bolts not wood screws, I don't think the weight of the speakers will hold up to wood screws..Home Theater/2 Channel:
dhsspeakerservice.com/ -
I have another idea... Do your speakers already have hurricane nuts? If so use ball bearings that will fit in the hole!!!
That might work, and get you as close to a spike as you can get.. -
You could also drill pocket holes with a forstner bit, and install the hurricane nuts and machine screws like my original drawing. Make them deep enough so the tip of the spike, and a puck could fit. I believe the 2Bs have 1 1/2' thick bottom, or close to it.Home Theater/2 Channel:
Thanks for all the suggestions guys. It has been months since I looked under the bottom side of these 2Bs. To be honest I don't remember exactly what they sit on other than remembering it is a small dome shaped plastic button. I don't know if they are held in place with a threaded hole or not. I will check it out after the holidays and let you know.
Merry Christmas to everyone!- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Probably the glides I spoke about. Merry Christmas buddy, and to everyone elseThanks for all the suggestions guys. It has been months since I looked under the bottom side of these 2Bs. To be honest I don't remember exactly what they sit on other than remembering it is a small dome shaped plastic button. I don't know if they are held in place with a threaded hole or not. I will check it out after the holidays and let you know.
Merry Christmas to everyone!Home Theater/2 Channel:
