CDP or transport
    edited December 2013
    I think Fred was just yankin' Jessie's chain on that remark. LOL
    F1nut Posts: 52,153
    Greg, that was a carry over from the Blu-ray Audio thread, http://www.polkaudio.com/forums/showthread.php?155039-Blu-Ray-Pure-Audio/page2
  • FTGV
    FTGV Posts: 3,650
    Smileys not showing in the right place.
  • headrott
    headrott Posts: 5,496
    Ooops. Thanks guys. I totally forgot about that thread actually..... (I guess I need to keep up now! :smile:)
  • erniejade
    erniejade Posts: 6,321
    It was the only reason why I sold my jolida. The problem after that was everything I got with sacd I kept compairing it back to the joida. That took me on an a journey to find a tube sacd player that would sound as good as the jolida did on redbook.
    To the op. Unless your going digial like flac files or sacd, with the right tubes, you will have to spend a lot more $ to better the sound. The jolida also is a great traspor and I don't think spending money and a seperate transport through your dac is going to change the sound much if at all. Is there a difference in transports? Yep. When I ran a denon into my w4s dac2 vs the pioneer d9 I had, on redbook the pioneer won hands down. The jolida running through the w4s vs the pioneer, I could not hear a difference. The transport was that solid.
  • acmf74
    acmf74 Posts: 937
    I did some careful listening to the DAC vs the Jolida. So far Jolida is in the lead by far for sound quality.
    I will let the DAC burn in a little more to see how it stacks up.
    PS the the DAC is the PS Audio NuWave.
    Do you have the Nuwave on Native ? Same IC'S going from the dac to the pre as you do the Jolida ?
  • acmf74
    acmf74 Posts: 937
    I have tried both native and up-sampling.
    yes.. the same IC's MIT CVT-2s
  • erniejade
    I bet the joida is more warm or musical vs analytic. The dac might be more accurate but the jolida is probably more friendly/musical sounding. It all depends on what kind of sound you like.
  • acmf74
    acmf74 Posts: 937
    erniejade wrote: »
    Exactly.
  • Obsession18
    Obsession18 Posts: 191
    The lead that the Jolida has over the DAC is due in part to the Psvanes tubes acmf74 is using. I was shocked at the improvement the Psvanes made in my JD-100 after I pulled out the stock Chinese tubes. I don't understand why they ship these CD players with those substandard tubes.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • acmf74
    acmf74 Posts: 937
    Plus the upgraded PC made a positive improvement.
    erniejade wrote: »
    That is the sound I like, warm and musical. Digital seems to suck both those characteristics out and lean towards the analytical side. Trick for me is how to combine both worlds together without losing the warm musical aspects. I need a tubed pre amp....bad.
  • erniejade
    Or a tube dac lol.
  • headrott
    tonyb wrote: »
    erniejade wrote: »
    Or a tube dac lol.
    Or both! :smile:
  • erniejade
    I have tube pre and a w4s dac2. it is a good combo. My sacd is tube also.
