expensive speaker jumpers
when i saw this i could not believe it. why would you pay this insane amount for jumpers. for this price you could get super speaker cables.
http://app.audiogon.com/listings/speaker-jorma-design-prime-speaker-jumper-lead-set-2013-11-29-cables-australia
Puritan PSM156
Puritan PSM156
Post edited by marvda1 on
The suitcase cost more than the jumpers...ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
The suitcase says 'Made in Sweden'. Isn't that the home of Coconut Audio?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Yea that is just a bit over the top.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
Uh...those are the good ones with the clear plastic thumbscrews. He should store them crossed at 90 degrees to prevent the co-valent convolution capacitance reduction.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Those jumpers provide a significant improvement over stock jumpers. You might say the difference is like "night and day".Do you hear that buzzing noise?
Those are $320 worth of connectors alone."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I think you'd be better off to buy the bi-wire speaker cables for $12,500.
http://app.audiogon.com/listings/speaker-jorma-design-prime-biwire-speaker-cables-2m-pair-2013-11-19-cables-australiaSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Maybe so....but they ain't worth spit without some white woody gunk from Coconut oil slobbered all over 'em. LOLHT SYSTEM-
lsi 9's -
What is really sad is someone will pay it. Some of the stuff in this hobby is pure snake oil.2-Channel System
Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
Spkrs: Tyler Acoustics Linbrook Signature Systems -
I don't think that applies here. Overpriced? Maybe. Will it make a difference if you're using plates? Don't see how it wouldn't.
Bingo!Political Correctness'.........defined
President of Club Polk -
don't get me wrong, jumpers do make a difference from the cheap metal bars included with speakers, i just don't think jumpers priced this high will make that amount of difference to justify the price.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Checkmate!>
poker night, send me the address again, age you know. might see if my son wants come.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
The cost is literally chump change for some in this hobby, on par with the rest of their system for others and 3X the amount of what some others have in their entire system. For those of us who want to keep their system to the utmost of playback capabilities, if one can afford it, the cost is negligible because the end result as to what hits our ears is the only thing that matters.
With that said, they may not be worth the cost even to those who can afford these because they may not react the way the user intended. You know, synergy and all. This may cause said user to go looking for ones that cost even more to find that audio nirvana. For some gear listeners with unlimited wallets, these may be considered a "trial" or "experiment" just to see if something they read somewhere works in their system or not.
Point is, they may be considered expensive to some. That's not unreasonable. They aren't snake oil though, just because they come with a higher price tag than some are used too.
If one thinks they cost too much, one doesn't have to purchase them.If you can't hear a difference, don't waste your money.
To some, you mean to most!Point is, they may be considered expensive to some. That's not unreasonable. They aren't snake oil though, just because they come with a higher price tag than some are used too.
Come on Tom, how could any sane person justify those. At most, that's only $400 worth of material(without the case)...which is still pretty ridiculous if you think about it. This is coming from someone who also uses the same brand connectors(WBT)."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Face wrote:To some, you mean to most!
To most who are not in our hobby? Absolutely. To those who only have that much invested in their entire system system? Yes. To those who are die hard audiophiles with the best of systems trying to reach the last 3% of their system? No, I said some and I meant some. Had you told me decades ago that I would one day have a set of IC's that cost as much as they did, I would have laughed and laughed real hard. Thing is, it was those IC's that made my system and since then I have more of them because I know what they do for the end result. You know full well that their are many in this hobby [and some within this forum] that 1.5K, while still a sizeable chunk of change, is really nothing compared to what they have spent over the years as a result of this hobby.
Mr. DSkip has a point. Most here are not the target customer. For the market they are targeting, 1.5K for something that is not a component [although to some in that market, they are considered just that] may just make or break a system. They wouldn't bother to make it unless there was a market for it. If I had the money right now, I would be in the market for this. Well, that is until I could afford a pair of Transparent OPUS MM2 Speaker Cables.
When you look up the price of those, how could any sane person justify them? Some have and some will.
WOW!!! The overall presentation is most excellent!!! I would pay that and double......then throw the jumpers away and keep the case....then pretend I'm James Bond
Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
