expensive speaker jumpers
marvda1
marvda1 Posts: 4,945
edited November 2013 in Speakers
when i saw this i could not believe it. why would you pay this insane amount for jumpers. for this price you could get super speaker cables.
http://app.audiogon.com/listings/speaker-jorma-design-prime-speaker-jumper-lead-set-2013-11-29-cables-australia
Puritan PSM156
Post edited by marvda1 on
  • Jhayman
    Jhayman Posts: 1,548
    The suitcase cost more than the jumpers...
  • BlueFox
    BlueFox Posts: 15,251
    The suitcase says 'Made in Sweden'. Isn't that the home of Coconut Audio?
  • Phasewolf
    Phasewolf Posts: 514
    Yea that is just a bit over the top.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • Polkersince85
    Polkersince85 Posts: 2,883
    Uh...those are the good ones with the clear plastic thumbscrews. He should store them crossed at 90 degrees to prevent the co-valent convolution capacitance reduction.
  • Monster Jam
    Monster Jam Posts: 919
    Those jumpers provide a significant improvement over stock jumpers. You might say the difference is like "night and day".
    Do you hear that buzzing noise? :confused:
  • Face
    Face Posts: 14,340
    Those are $320 worth of connectors alone.
    SCompRacer Posts: 9,112
    tonyb Posts: 33,072
    Face wrote: »
    Maybe so....but they ain't worth spit without some white woody gunk from Coconut oil slobbered all over 'em. LOL
  • Obsession18
    Obsession18 Posts: 191
    What is really sad is someone will pay it. Some of the stuff in this hobby is pure snake oil.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
    F1nut Posts: 51,766
    DSkip wrote: »
    I don't think that applies here. Overpriced? Maybe. Will it make a difference if you're using plates? Don't see how it wouldn't.
    Bingo!
  • marvda1
    don't get me wrong, jumpers do make a difference from the cheap metal bars included with speakers, i just don't think jumpers priced this high will make that amount of difference to justify the price.
    Puritan PSM156
  • Polkersince85
    marvda1 wrote: »
    Checkmate!
  • marvda1
    poker night, send me the address again, age you know. might see if my son wants come.
    Puritan PSM156
    treitz3 Posts: 19,992
    The cost is literally chump change for some in this hobby, on par with the rest of their system for others and 3X the amount of what some others have in their entire system. For those of us who want to keep their system to the utmost of playback capabilities, if one can afford it, the cost is negligible because the end result as to what hits our ears is the only thing that matters.
    With that said, they may not be worth the cost even to those who can afford these because they may not react the way the user intended. You know, synergy and all. This may cause said user to go looking for ones that cost even more to find that audio nirvana. For some gear listeners with unlimited wallets, these may be considered a "trial" or "experiment" just to see if something they read somewhere works in their system or not.
    Point is, they may be considered expensive to some. That's not unreasonable. They aren't snake oil though, just because they come with a higher price tag than some are used too.
  • decal
    decal Posts: 3,205
    If one thinks they cost too much, one doesn't have to purchase them.
  • Face
    Face Posts: 14,340
    treitz3 wrote: »
    To some, you mean to most!
    Come on Tom, how could any sane person justify those. At most, that's only $400 worth of material(without the case)...which is still pretty ridiculous if you think about it. This is coming from someone who also uses the same brand connectors(WBT).
    To most who are not in our hobby? Absolutely. To those who only have that much invested in their entire system system? Yes. To those who are die hard audiophiles with the best of systems trying to reach the last 3% of their system? No, I said some and I meant some. Had you told me decades ago that I would one day have a set of IC's that cost as much as they did, I would have laughed and laughed real hard. Thing is, it was those IC's that made my system and since then I have more of them because I know what they do for the end result. You know full well that their are many in this hobby [and some within this forum] that 1.5K, while still a sizeable chunk of change, is really nothing compared to what they have spent over the years as a result of this hobby.
    Mr. DSkip has a point. Most here are not the target customer. For the market they are targeting, 1.5K for something that is not a component [although to some in that market, they are considered just that] may just make or break a system. They wouldn't bother to make it unless there was a market for it. If I had the money right now, I would be in the market for this. Well, that is until I could afford a pair of Transparent OPUS MM2 Speaker Cables.
    When you look up the price of those, how could any sane person justify them? Some have and some will.
  • Geoff4rfc
    Geoff4rfc Posts: 2,838
    WOW!!! The overall presentation is most excellent!!! I would pay that and double......then throw the jumpers away and keep the case....then pretend I'm James Bond :mrgreen:
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
