Monitor 10A
westmassguy
This was a nice little Crossover project. Original Monitor 10As with fully functioning Peerless Tweeters. Sonicaps were chosen for the Hi & Lo-Pass, Mills MRA-12 Resistors, and new Gold Plated Copper Binding Posts were installed. Due to the size of the Lo-Pass Shunt Caps, new riser boards were installed, along with New Nylon Standoffs. All Caps were secured with 3M VHB Tape, and the large shunt caps received Nylon Wire Ties in addition to the 3M VHB tape. The existing fuse holders were cleaned, polished and treated with DeoxIT. The Peerless never sounded so good.
Home Theater/2 Channel:
dhsspeakerservice.com/
Nice!! I have a set of Monitor 10A's in my shop that has been waiting for the crossover rebuild. Have all the parts to do it, but have not gotten around to it yet. Thanks for posting these photos. They give me an idea of what to expect when I do mine.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Very nice. I should have replaced the binding posts on my 10a's when they were rebuilt.
Thankshelipilotdoug wrote: »Nice!! I have a set of Monitor 10A's in my shop that has been waiting for the crossover rebuild. Have all the parts to do it, but have not gotten around to it yet. Thanks for posting these photos. They give me an idea of what to expect when I do mine.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Pretty sure we spoke about that BruceVery nice. I should have replaced the binding posts on my 10a's when they were rebuilt.Home Theater/2 Channel:
We did. Mistake on my part!!
Do you know what VHB stands for?
I sold high performance pressure sensitive tape for many years so I know the answer LOL -
One more thing Nice work!!!
How hot do capacitors get? I know resistors get plenty hot and some adhesives won't hold up to extreme temperatures. -
Actually it means Very High BondDo you know what VHB stands for?
I sold high performance pressure sensitive tape for many years so I know the answer LOLHome Theater/2 Channel:
I doubt the capacitors even get warm, unless you approach their maximum voltage rating. As for the resistors, 12 watt Mills are more than twice the rating of the originals, and mine are soldered flat to the underside of the circuit board.One more thing Nice work!!!
How hot do capacitors get? I know resistors get plenty hot and some adhesives won't hold up to extreme temperatures.Home Theater/2 Channel:
Did you look do a search on VHB or did you know it? Just fooling with you!
One of these days I would like to hear your 901's. One of these days I will buy a nice pair so I can relive my past. -
I've been using it for years, and new back then what it meant. 3M also make UHB products as well. Fellow Polkies are always welcome, even if it's to hear an alternate and much maligned (mostly undeserved) speaker system.Did you look do a search on VHB or did you know it? Just fooling with you!
One of these days I would like to hear your 901's. One of these days I will buy a nice pair so I can relive my past.Home Theater/2 Channel:
That's a nice little project, thanks for posting the photos. I didn't know about the 3M VHB tape, looks like a better way to go than hot glue. Do you pick it up at Staples, or at a specialty store?
Thanks. Any good hardware store will have it, Home Depot, Lowes etc.That's a nice little project, thanks for posting the photos. I didn't know about the 3M VHB tape, looks like a better way to go than hot glue. Do you pick it up at Staples, or at a specialty store?Home Theater/2 Channel:
Nice work! Redoing my 10's is on the "list"! lol--Gary--
Thanks halo. I think we all have one of those listsHome Theater/2 Channel:
