RTi-A5 Blown tweeters - $300 to fix during warranty period
  • Upetr
    Upetr Posts: 13
    edited October 2013
    Now that I think about it - with a test sound around 18khz or 20khz with 2/3 volume you could easily send over 100w rms to the tweeters directly without even causing any clipping and then poof. The difference with normal sound is that majority would go to a bigger driver since almost any instrument out there and most natural sounds will cover a much bigger sound spectrum.
    pitdogg2 Posts: 27,340
    edited October 2013
    Upetr wrote: »
    Cut that out you are now making complete sense how dare you!!!! :smile:
    correct that tone would slide right through the XO with little impedance (pun intended)
  • lanchile
    lanchile Posts: 560
    edited October 2013
    Case closed!!!! even though the problem was not with the speakers but the owner that "pushed" those speakers over their limit. Here Polk Audio have proven once again that they mean business. Wonderful customer support. Hats off to Polk and their associates!!!
    Make it simple...Make it better!
