SDA SRS Cable
  • westmassguy
    westmassguy Posts: 6,850
    edited October 2013
    I believe he was referring to the upper and lower frequency drivers, not the IC socket.
    I'm aware of that. I was pointing out that what's supposed to be there, isn't always there, and since the IC Socket is on the same Binding Post Cup, he might as well check the wiring on that as well. The Hi-Pass wiring to the Binding Posts may be Clear 14 gauge wire, with color coded tape on it. The tape has a tendency to fall off.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • zingo
    zingo Posts: 11,258
    edited October 2013
    oldrocker wrote: »
    Just hooked up a connect cable I bought here and a couple quick questions? Now the cable is in and I'm not seeing a big change in sound quality.
    I had a friend do the test with me so I could be listening live while he plugged and unplugged the SDA cable. Even for good ears, it's still much easier to hear the SDA impact that way verses running to the back of the speakers to plug and unplug.
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited October 2013
    when I first got my SRS's I had a similar problem. No dimensional effect. Mine turned out to be oxidized connections in the SDA circuit. When you do get it, you will no it. You don't have to concentrate or try hard; it's right there in front of you and beside you, and many other places in the room.
    F1nut Posts: 52,062
    edited October 2013
    No, I was referring to the IC socket.
    F1nut Posts: 52,062
    edited October 2013
    No, I was referring to the IC socket and binding posts.
    F1nut Posts: 52,062
    edited October 2013
    I sure wish they would fix this forum!
  • drumminman
    drumminman Posts: 3,396
    edited October 2013
    I thought maybe you'd developed a stutter :smile:
  • oldrocker
    oldrocker Posts: 2,590
    edited October 2013
    Gentleman, thank you very much for your advice and expertise, it is appreciated!
