lism speakers out of phase, says yamaho recevier. Help
  • drumminman
    drumminman Posts: 3,396
    edited September 2013
    I didn't like the sound when I used the auto calibrate function on my Yamaha receiver, so I set it up manually. M-u-c-h better!
  • Mikey081057
    Mikey081057 Posts: 7,127
    My old yamaha avr did the same thing... it was annoying, it did it on my rear surrounds which are bipole/dipole which I can understand... but my Marantz with Audessy doesn't do it. It must be the way reflections are hitting the microphone, and nothing to worry about as long as they are wired correctly, and that the speaks themselves are wired correctly. Did you check the yamaha site... I recall doing that some years ago when I had mine.
    Garage | Polk Monitor 5B's
  • sk88
    sk88 Posts: 159
    With my pioneer, I repeated several times all with same results - out of phase when connected with correct polarity, no out of phase when connected with reversed polarity. So for whatever reason the mic is picking up from room reflection, it's real.
    My question is that if that's how my room reflection turned out to be, shouldn't I keep the two speakers both reversed in polarity (both + to - and - to +)? This would mean that they would be out of phase to the other speakers in terms of how the wires are connected but may actually be in phase with the other speakers as a result in terms of actual listening. Which way I should do?
    • Online - Focal Solo6 BE, Polk PSW10, Focusrite Saffire Pro 24 DSP, Lenovo x220t
    • Music/HT - Lsi25, Lsi9 (Vr3), Lsi7, LsiC, Pioneer SC-68 & BDP-62FD, PS3
    tonyb Posts: 33,072
    which way sounds better to you ?
  • sk88
    sk88 Posts: 159
    I'll have to listen to some multi-channel music to find out. But, let's say I find it sound better with reversed polarity on the two front speakers, is there any negative that I leave it that way long term?
  • BlueFox
    BlueFox Posts: 15,251
    Aside from the phase cancelation resulting from reversed speaker cables causing the end of life as we know it, there shouldn't be any issues.
    tonyb Posts: 33,072
    Agreed, aside from the dog and cat starting to get along and the possibility of the wife turning into a zombie, I see no other issues associated with it.
  • Jhayman
    Jhayman Posts: 1,548
    He's running YPAO and I've had the same issue with out of phase.
    Christper2000 how big is your room and how close are the speakers to the walls?
    The YPAO is reading a lot of room reflections just ignore it, it's fine..
    Nightfall wrote: »
    That is pretty funny.
    If it says it's in phase, you're good to go. If it says it's not in phase then ignore it.
  • JimAckley
    JimAckley Posts: 1,138
    I got the same "out-of-phase" error message from my SC-37 when I was reviewing the 703s and 707s. Everything was wired correctly.
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • sk88
    sk88 Posts: 159
    Thanks for all the "comforting" words! :)
    Didn't want to hihack this thread. I beleive OP is using YPAO and I am using MCACC, but I think this is all relavant information.
    I played more over the weekend reversing speaker polarity and run tests. Surprisingly, MCACC was able to tell me each wire that I have reserved or reversed back. At a time there were 4 speakers reversed and the other 3 did not. So, I think it's measuring something on each speaker individually in addition to the relative phases among the speakers.
    I don't know if this is true or not but I think LSiM must have wider dispersing angles than LSi speakers. That would lead to different room relections patterns. And that must be why I didn't get this out of phase messages with LSi while everything else remains identical.
    The reason the AVR says to ignore the message if the wires are connected correctly is becasue the auto adjustment will try to compensate group delays for phase controls (at least that's the case on my model). So, at the end, I decided to leave all wires connected corretly as they should be and ignored the message as many people have suggested.
    Dog seems to like the result, and wife likes it too. No cats.
  • leftwinger57
    leftwinger57 Posts: 2,917
    I also had an out phase reading on my RX-V665 and checked and rechecked my wires.I used banded bananas w/ striped wire so I knew for sure all my polarity issues were right.I didn't also like the YPAO set up w/ the mic w/ the rears never to be heard so I also did it manually after I was sure all was ok w/ the set up.What I do like is going through the setup on screen tv which is a thousand times easier than reading the LED on the avr it's self..
  • pretzelfisch
    pretzelfisch Posts: 160
    edited October 2013
    I reran YPAO in my office yesterday for the first time after the 1.8 upgrade and it told my my lsim 703 are out of phase. This seems like it's a bug in YPAO, since this room previously ran without any warning and nothing has moved.
  • nhhiep
    nhhiep Posts: 877
    edited October 2013
    same with my denon AVR saying my RTi setup is out of phase. I trust my eyes with the + and -
  • Msabot1
    Msabot1 Posts: 2,098
    edited October 2013
    Guys I'm a little confused here....how can signal reflection cause a piece of equipment to display a message that the output load is out of phase? The internal wiring of the speaker or the amp would have to be crossed assuming the correct polarity is maintained between outs of amp and ins of the speakers? Never had this problem as described....interesting!!
  • nhhiep
    nhhiep Posts: 877
    edited October 2013
    from what i read, it's the xo inside the speakers that sometimes confuse the avr
  • sk88
    sk88 Posts: 159
    edited October 2013
    Msabot1 wrote: »
    My understanding is this. If the soundwave from each speaker all arrive at the mic at the same time, then none of them would be out of phase. When soundwave from a speaker arrive late (meaning there is a delay between when the test signal is generated and when the sound is picked up by the mic), then that speaker may be considered out of phase. It is a matter of delays in sound traveling and room reflections can cause that to the measurement.
    Those soundwave frequencies are measured in Hertz, which means the dealy would be in thounsands of a second. Quite subtle for the mic to pick up and measure. Make sure the mic is stationed with a tripod. It needs to be perfectly leveled and facing the ceiling without obstruction and positioned right at the normal listening positon where your ear would be.
    In my case as I mentioned, there is nothing wrong with my speaker wiring. However, I can reverse polarity on any speaker and the system would flag that one as out of phase. I tried it on several speakers and each time the system flagged it correctly. So I am quite sure it's a result of delays caused by reflections. I don't know about YPAO (mine is pioneer) but a quick seach tells me that it can compensate for phase shift by adjusting speaker distances. That's why it says to just ignore the message if the speaker is wired correctly.
  • all4usa
    all4usa Posts: 4
    edited October 2013
    Same exact thing happened with my 707LSiMs and yamaha a2010, after doing same research you did here I just left them connected correctly (albeit out of phase according to ypao) and everything is fine. Good luck. BTW 140wpc 2ch driven from my yamaha wasn't enough for me so I just picked up a used sunfire 5ch x 200wpc which I'll comment on after I demo it for a while. Good luck
    yamaha rx-a2010
    parasound 2250
    sunfire cinema grand
    polk LSiM 707 towers
    polk LSiM 706c center
    polk F/XiA6 surrounds
    polk 65-LS rears
    polk DSWmicroPRO 3000 front sub
    polk DSWmicroPRO 2000 rear sub
    bluejeans cabling
