Using 2 sheets mdf for small sub box
LONG TIME BUYERLONG TIME BUYER Posts: 112
edited May 2014 in Custom Fabrication
Will be making a new sub box for a 8 inch mm840 polk audio subwoofer. The size box 0.35 cu ft,which polk audio states. If i made it using 2 sheets 3/4 mdf board,would it distort the sound or would it be more detailed?. Would love to hear answers back.
Post edited by LONG TIME BUYER on
  • LONG TIME BUYERLONG TIME BUYER Posts: 112
    edited November 2011
  • decaldecal Posts: 3,171
    I don't really understand what you are asking, can you be a dit clearer?
    Why would you need 2 sheets of mdf to make a .35ft3 box?
    I made my sub box a hair to small, if i put 1 more sheet of mdf on 3 sides,it will fit perfect,and it will be easy to do. So today i did it and smoothed it all out.you would never know. At this point my subwoofer has not got here yet. Ordered it. So now did i change the sound of the box? I guess when the sub gets here i will find out.
  • VitalVital Posts: 747
    hhhmmmm...okk....
    2008 Nissan Altima
    Kenwood DNX 5140
    Arc Audio IDX and XEQ
    Polk Audio SR6500 active and SR124-dvc sealed
    Polk Audio PA500.4 and PA1200.1
  • nguyendotnguyendot Posts: 3,587
    Not sure what you're asking man. Please choose your words carefully and clarify what you are asking.
    Main Surround -
    edited December 2011
    Very simple. If you read it. If you doubled the box with 2 layers of mdf board what would it sound like? Too simple. I can answer it myself now i already build it. It sounds more tighter and detailed than my other box. I wasnt sure if it would,and i was thinking that someone out there might have tryed this before i did it. Thanks anyway.
  • tommyt21tommyt21 Posts: 685
    I'm glad your subwoofer sounds better in the new box. I think the confusion came in your original post. If you had phrased it as, I plan on doubling the thickness of the subwoofer enclosure by using double layers of MDF. You may have gotten the appropriate responses you were looking for.
    Have a good one dude
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
  • 20hz20hz Posts: 643
    edited January 2013
    it threw me off too , I read two sheets I was thinking of standard 4x8' sheets , not just building it double wall .
    I am surprised that small a box benifitted from a 1.5 vs .75 wall , I would figure if it helped it it would be more detailed
  • Anthony HintonAnthony Hinton Posts: 107
    edited February 2013
    doubling the wall thickness should stiffen the box, no negative effects.
  • kickkick Posts: 10
    edited September 2013
    The thicker the better is the answer
    edited October 2013
    I cant see a 8" being effected , I put a brace every six inches
    IMHO internall braces are easier and more effective than double walls
    A kick said thicker is always better
  • EocuphEocuph Posts: 75
    edited October 2013
    With an enclosure that small, its a waste of mdf to add a second layer all around. You should hear any difference. If you are worried that the internal dimensions are too small, you can add some poly fill inside the enclosure.
    edited May 2014
    thats crazy .35 cu is to small for any positive gains of a dual wall !
    Dual wall is just for rigidity my rule is a brace every 6 inches , if you dont the cabinet will make noise .
Howdy, Stranger!
