Using 2 sheets mdf for small sub box
LONG TIME BUYER
Will be making a new sub box for a 8 inch mm840 polk audio subwoofer. The size box 0.35 cu ft,which polk audio states. If i made it using 2 sheets 3/4 mdf board,would it distort the sound or would it be more detailed?. Would love to hear answers back.
Nothing yet
I don't really understand what you are asking, can you be a dit clearer?
Why would you need 2 sheets of mdf to make a .35ft3 box?If you can't hear a difference, don't waste your money. -
I made my sub box a hair to small, if i put 1 more sheet of mdf on 3 sides,it will fit perfect,and it will be easy to do. So today i did it and smoothed it all out.you would never know. At this point my subwoofer has not got here yet. Ordered it. So now did i change the sound of the box? I guess when the sub gets here i will find out.
hhhmmmm...okk....2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
Not sure what you're asking man. Please choose your words carefully and clarify what you are asking.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Very simple. If you read it. If you doubled the box with 2 layers of mdf board what would it sound like? Too simple. I can answer it myself now i already build it. It sounds more tighter and detailed than my other box. I wasnt sure if it would,and i was thinking that someone out there might have tryed this before i did it. Thanks anyway.
LONG TIME BUYER wrote: »Very simple. If you read it. If you doubled the box with 2 layers of mdf board what would it sound like? Too simple. I can answer it myself now i already build it. It sounds more tighter and detailed than my other box. I wasnt sure if it would,and i was thinking that someone out there might have tryed this before i did it. Thanks anyway.
I'm glad your subwoofer sounds better in the new box. I think the confusion came in your original post. If you had phrased it as, I plan on doubling the thickness of the subwoofer enclosure by using double layers of MDF. You may have gotten the appropriate responses you were looking for.
Have a good one dudeLiving Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels -
it threw me off too , I read two sheets I was thinking of standard 4x8' sheets , not just building it double wall .
I am surprised that small a box benifitted from a 1.5 vs .75 wall , I would figure if it helped it it would be more detailed -
doubling the wall thickness should stiffen the box, no negative effects.
The thicker the better is the answer
I cant see a 8" being effected , I put a brace every six inches
IMHO internall braces are easier and more effective than double walls
A kick said thicker is always better -
With an enclosure that small, its a waste of mdf to add a second layer all around. You should hear any difference. If you are worried that the internal dimensions are too small, you can add some poly fill inside the enclosure.
thats crazy .35 cu is to small for any positive gains of a dual wall !
Dual wall is just for rigidity my rule is a brace every 6 inches , if you dont the cabinet will make noise .
