Floor model lsim707 $2k. Should I?
124»
    F1nut Posts: 51,770
    edited August 2013
    Some of you are missing the point.
    For Eclypse to say he doesn't know what another amp could offer after moving from an AVR to adding an amp, whatever brand it may be, is not someone speaking from the expereince of trying different amps. While he may be content at this time how does he know he's truly content since it's his very first experience with a power amp. His position is no different than someone moving from a Ford Pinto to a Ford Fusion and then proclaiming that they don't know what another car could possibly offer without ever driving any other cars.
    F1nut Posts: 51,770
    edited August 2013
    Ocezam wrote: »
    It's a modified pair of JD502P. Among other things, they're running KT120s paralleled. And yeah, they're right at 140w each.
    Getting 140 wpc out of an amp designed for 60 wpc is impressive. Did you have the trannies changed too?
    Of course there's a difference. Mainly the Dragons and Jolidas are warmer and softer. They ALL provide excellent sound.
    Three very different amps and they all sound excellent? Call me skeptical.
  • eclypse
    eclypse Posts: 595
    edited August 2013
    :) I'm very glad that spending a little money on some cheap amps was enough to make me happy. I'm sure theres better as there always is something better but in the end it comes down to my ears and what pleases them. There happy and i'm very happy with them.
    Sad that the people bashing these emo most likely never gave them a chance.
    With the 30 day trial and large fan base that's happy with them and the transferable 5 year warranty that helps keep the resale up on them, there pretty safe to try for oneself.
    If I can hear the HUGE difference in high res audio over HD radio/CD/MP3s then they must be doing something right by my LSIM speakers.
    Probably would make a EMO hater cringe that I almost went back to emotiva and bought up a XDA-2 and a XSP-1 just to see how much better my music could be.. wife wouldn't let me pull the trigger. I Guess eventually i'll grab a XMC-1 receiver whenever that comes out and I can afford it.
    Like many hobbies if one has 10k to blow they will make something for you.. glad theres good amps for everyones budget.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
    F1nut Posts: 51,770
    edited August 2013
    You missed my point, again! It's not what amp you bought, it's your comment,
    Not idea what one would want that the emo don't offer.. its dead silent and plenty of power when needed. Amplifies the signal as expected..
    Of course, you don't know as you've never tried any amp before.
    Sad that you think someone is bashing when they are not. Besides, you don't know that I haven't heard products from that company.....I have, but again, you're missing the point.
    It's not the amp, it's the format. Hello!!!
  • plainoledave
    plainoledave Posts: 408
    edited August 2013
    Holy freakin' thread jack!
    I didn't buy them, btw.
    F1nut Posts: 51,770
    edited August 2013
    Sorry Dave. Were they not in good condition?
  • Ocezam
    Ocezam Posts: 52
    edited August 2013
    Not really so impressive. You can take that amp bone stock, run it paralleled (bridged) and it's a 120watt mono. The transformers are stock I believe. Mine simply take advantage of the bigger KT120s. From what I understand, if the transformers are upgraded, you can get close to 200w out of them.
    OK, you're skeptical...
    I don't have the time or the inclination to expand on the differences of the four amps I mentioned but I could live with any of them long term. That said, I believe I'll keep my Jolidas for awhile.
    "The ear is not a microphone, the brain is not a tape recorder, and measurements are limited in describing subjective quality." Nelson Pass
    2 Channel:
    XDA-2, Modified Jolida JD502P (2 ea), Polk LSiM705
    Theater:
    Onkyo TX-NR3009 with 9 active channels, Emotiva XPA-5, MartinLogan Encore TF Center Channel, Polk M70 Mains, M40 Wides, M30 Heights, FXi A4 Surrounds, Custom built 18" sub, Mitsu 73" DLP
  • plainoledave
    edited August 2013
    I wasn't really mad. Just messing with you. They didn't sound very good, bass was sloppy. Probably just the receiver? They had some light scuffs on the bases, also. I want 705's and I want them in black.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2013
    $1800 and you can have mine.:cool:
  • leroyjr1
    edited August 2013
    Polk doesn't make black 705's.
  • D_M
    D_M Posts: 175
    edited August 2013
    leroyjr1 wrote: »
    I suspect he means mahogany.
  • plainoledave
    edited August 2013
    D_M wrote: »
    This
    F1nut Posts: 51,770
    edited August 2013
    Ocezam wrote: »
    Interesting, I wasn't aware you could bridge that amp.
    I'm even more skeptical now. :lol:
  • Ocezam
    Ocezam Posts: 52
    edited August 2013
    Ocezam wrote: »
    I talked to Michael Allen President of Jolida several times about it before I bought them to be sure it worked as I was being told elsewhere. He assured me it did, and I can assure you now, it does. He also let me order them sans output tubes with a discount so I could provide my own KT120s. He's really a great guy to work with. I ended up with 140w monoblocks for about $2100 all inclusive w/ shipping. Pretty decent deal on pretty decent equipment IMHO.
    2 Channel:
    Theater:
