Having issues with a RTA 11T
ipsullivan
I just noticed one of my RTA 11Ts seems to have lost power. Both drivers sound like they are drowning and lack any clarity and the tweeter doesn't seem to have any output at all. It's brother is not having any issues, so I switched the channels to make sure the amp isn't the problem, and it is definitely the speaker.
Any ideas as to what the problem is?
I am using a Yamaha HTR-5860 as a pre-amp and an Adcom GFA-5500 to power them.
Thanks for any help,
Ian
Ian
Post edited by ipsullivan on
Hello Ian,
In all likelihood the 6.5" drivers and the tweeter are defective and would have to be replaced. You can confirm this by exchanging these components from one speaker cabinet to the other. If the bad sound follows the components then you've tracked the problem down. Replacements can be purchased from Polk's CS department at: 1-800-377-7655 or via email at: polkcs@polkaudio.com. Be sure to mention your CP membership for reduced parts prices.
Best regards, Ken -
Either the polyswitch has gone bad and/or you've cooked the tweeter. When the tweeter isn't playing the drivers will sound as you described. Just swap the tweeters, leave the mid-drivers alone and report back.Political Correctness'.........defined
President of Club Polk -
I'm gonna guess here and say a crack in the crossover board...Too much **** to list....
One or both of the spade.connectors could have come off the tweet as well
Thanks for the input guys. Looks like I'm going to tear the speakers down and see what it is for sure.
Confirmed that the tweeter is gone. I think I'm going to pick up a pair of SL2000s on eBay(for a spare). I have been reading mixed thoughts on the new replacements Polk offers.
Thanks for the help,
Ian -
Call Polk and order the RDO-194's instead. As a Club member you will get them for 48 bucks each and free shipping. You will thank me later.
I would then upgrade the crossovers. Buy the time the updates have been completed, you will think you bought new (and much better) speakers.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
what John said....
their good... the replacements I mean. at least in mt RTA11T's... I just pulled out a pair of 5JR's with the 2000 today that I haven't listened to in a coon's age, and after so long with the RDO-194's, the shortfalls of the SL2000 are much more obvious. But that is your decision.
If you really want the Sl2000 , I will sell you the pair out of my 5JR to help fund some RDO-194 for me..... And I also have the ones out of my 11T's, but they are not as good of shape. The ones in the 5JR are pretty sweet.
But the upgrade, in my opinion, is really the best choice.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Just ordered a pair of RDO-194s today. I plan on upgrading the crossovers next.
Good move, you won't regret itHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Lots of upgrade options for the crossovers, have funipsullivan wrote: »Just ordered a pair of RDO-194s today. I plan on upgrading the crossovers next.Home Theater/2 Channel:
dhsspeakerservice.com/ -
question ? Does the RDO-194 fit the same way? Or do you have to modify where their different ? Thanks. Id like to do some to mine as wellwhat John said....
But the upgrade, in my opinion, is really the best choice.Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
The RDO-194-1 is a drop-in replacement. No modifications required if you're replacing the SL2000boston1450 wrote: »question ? Does the RDO-194 fit the same way? Or do you have to modify where their different ? Thanks. Id like to do some to mine as wellHome Theater/2 Channel:
Thank you kindly for info. That makes it easy if you have never done modification-such as upgrade crossovers/tweets. Ive replaced drivers. Tweets. Crossovers. But never done any upgrades on original stock speakers. But im sure its fun and can be a little costly. But from what i read the outcome outweighs the cost in the long run
thanks again Randy-Maine
by David WMG
