power cord burn-in question
bthogan
Just got my McCormack DNA-1 back, with Silver upgrade and some other stuff. Bought a Shunyata Venom 3 (with extension cord) as a homecoming gift, to show it how much I love it.
Sounded not-so-good at first blush, as expected (the cords, not the DNA-1). Now I want to burn those cords in. I can't hook the power cord up to my fridge or AC - they don't have removable cords or IEC sockets. So I've stuck them both on my computer, with its super-overkill power supply (1200w), overclocked/over-volted cpu, and seriously over-volted dual GTX 580s. But I don't leave my computer on all the time.
My question is...I know some things, like caps, need an on-off cycle to burn in properly. But I've seen some info that suggests that a constant current is best for power cords. Is that true? For optimum burn-in, should I try to plug the cords into something that's constantly running?
That's all. Thanks for help.
Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables
Post edited by bthogan on
I just plug them in and let them burn-in while in use. I figure they are adapting to the gear they are running, and at some point reach an equilibrium where they work best with a particular piece of gear.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I burn in all my cords with the Plasma tv
Thanks very much for reply...You know, normally, I actually like hearing the burn-in. It's cool to audibly hear equipment going from ok to great. Unfortunately, in this case, I just don't have the patience to wait for the Shunyata to at least sound as good as the burnt-in cord it's replacing. And I gotta say that the Venom 3 really didn't sound very good for the first few hours. Mid-range presentation really dropped out, or rather, fell back - quite noticeable.
I'm confident that the cords' sound will improve - I'm hoping it will - but they really don't sound too good right now, and for the first time, I don't want to sacrifice listening pleasure to the burn-in process. The DNA-1 already sounds uh quite good with the burnt-in cord I have. It won't break my heart (or my wallet) if the Venom 3 doesn't end up surpassing the cord I already have; this is my first baby-steps foray into audiophile PCs, and it's a journey and I dig it...but man I love hearing that DNA-1 sing!
So that's my problem. I hear you...oughta just suck it up...but losing the amazing quality of that remastered Cars Complete Greatest Hits...or Spirit of Eden...even just for a few days (weeks?)...that's a tough one.Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables -
Please excuse double post...Unfortunately, I don't have a plasma TV...just an "old" Sony CRT w/out removable cord, and a Samsung LED monitor for the computer. I assume the computer itself will burn the cords in faster than the monitor. I'm actually thinking of leaving the computer on overnight and turning the monitor off.Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables -
Just get it burned in and don't worry about the process, its not like if you burn a set of speakers in with certain music then they are going to sound best playing that type lol. I have taken the advice of 200 hours burn and find that number works good
I use the fridge for burn-in, just connect the power cord and let it run for a few days. I use an IEC to NEMA-15 adapter on the amp end, to accommodate the fridge plug.
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
I thought about that, may give it a try. Thanks for tip.Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables -
Just leave the cord in place and leave the stereo on for a few days, low volume of coarse.
Aside from the power cable, what I really want to know is how the McCormack sounds.HT SYSTEM-
lsi 9's -
It sounds great. I mean, really lovely, no matter what I play. Not sure if the LSi9s could sound any better.
Went from an Adcom GFA-545 to the DNA-1, and learned what these speakers are capable of. Then I got the upgrades...I really like these LSi9s, but I'm extremely excited about the speaker upgrades in my future. I can't wait to hear what this amp is capable of. I'll be building around it for a while.
I'm thinking of starting a thread just to show off its innards. Mr. McCormack's work is a joy to behold, as well as to listen to.Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables -
Cool man, I also love their amps. The DNA 500 is a monster.
If you like the sound of what tubes bring to a midrange, higher frequencies, and still love that bass slam of SS, McCormack amps are a great amp to share some of each camps attributes.
Don't let some of their lower wattage amps fool you either, they have current to spare.HT SYSTEM-
lsi 9's -
He could use his stereo as one normally would and at some point the cables will all be burned in. No strenuous measures needed. -
Are you kidding? a power cord is not a capacitor!!!! if someone tells you to do the "burnig time"...He or She know $hit!...IT IS JUST A WIRE!!!!Make it simple...Make it better! -
Will all this crap of power cord "burning time" change the "reciprocal siemens" in the power cord? Check it and let me know!. Maybe I am wrong like all the time. or maybe my Fluke gears are bad.Make it simple...Make it better!
The burn in debate is a bit comical since by definition of any significant use of ones system means the cables are 'burned in'. Now the question begs: Do they un-burn in?
the OP clearly states he does not wish to listen to the burn in and so is seeking an alternative route.
He also clearly states he has one burned in cable and the amp sounds great, and one non-burned in cable, which sounds horrible. So I am pretty sure there is no "burn in debate" for him.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
if ANYONE can hear a difference (if there is one) between "same cables", one used (burned in) and the other one brand new...that person must be out of this world. I wish I find those kind of people around here where I live, that way I can sell them regular power cords and "WASH" their brains (if they have some) with all this non-sense crap and make big money. I can tell them I have special power cables that can only produce True R.M.S power from their amps. I bet you, they will believe me hehehehehehehe
These people that say they hear a difference in the sound....Have they ever used any kind of equipments to measure and can prove they are right?. I do not think so!...all that is in their WASHED little brains.Make it simple...Make it better! -
i believe he clearly states he used his ears, which is the only device possible to measure whether he can "hear" a difference. and i am sure he is the only person who needs proof, since it is his ears, his system, and his audio experience.
so, really, there is no argument to be had.Polk Lsi9
Keces DA-131 mk.II
I guess you are right! if He is happy and "convinced" that a used power cord sounds better. He should just enjoy it!!! in my case I use my ears and then I go for my equipments to confirm if I was right (most the time I am). I would not just believe whatever other people say specially in electronic staff ...unless of course I know it comes from a well "educated" electronic guru.Make it simple...Make it better! -
i completely agree. I have read here for quite a while, and I have tried out many pieces of advice given, from cables to speaker mods, to differing pieces of gear. Some have panned out, some not, and some definitely go against the grain of what is said. All of it was worth spending money on, because I am curious, and I love to play and find out things for myself. But none of it is worth a shouting match.... it only comes down to what goes on in my little room.I guess you are right! if He is happy and "convinced" that a used power cord sounds better. He should just enjoy it!!! in my case I use my ears and then I go for my equipments to confirm if I was right (most the time I am). I would not just believe whatever other people say specially in electronic staff ...unless of course I know it comes from a well "educated" electronic guru.
of course, as always, this is just my personal opinion.Polk Lsi9
Keces DA-131 mk.II
Hey 11tsteve! if you really like electronics, you should check Diyaudio.com. You can learn a lot there and have fun at the same time. I am a member there since 2008. all these years I have build many amplifiers and pre-amps. They have a lot of excellent amp's schematics, also Nelson pass is there too. I used to work in an electronic repair shop for many years so I have all the hands on training and know how they work. I have spent crazy money in my Fluke equipments. But I feel good when you can count on a accurate reading all the time. Money well spent!Make it simple...Make it better!
Are you kidding? a power cord is not a capacitor!!!! if someone tells you to do the "burnig time"...He or She know $hit!...IT IS JUST A WIRE!!!!Will all this crap of power cord "burning time" change the "reciprocal siemens" in the power cord? Check it and let me know!. Maybe I am wrong like all the time. or maybe my Fluke gears are bad.if ANYONE can hear a difference (if there is one) between "same cables", one used (burned in) and the other one brand new...that person must be out of this world. I wish I find those kind of people around here where I live, that way I can sell them regular power cords and "WASH" their brains (if they have some) with all this non-sense crap and make big money. I can tell them I have special power cables that can only produce True R.M.S power from their amps. I bet you, they will believe me hehehehehehehe
Any more words of wisdom? :rolleyes:
It always amazes me how the people who know the least then talk the most to reinforce their ignorance.Lumin X1 file player, Westminster Labs interconnect cable
Hehehehe...are you one of those "brain washed" too? and you are right... I do not know anything about electronics!Make it simple...Make it better! -
President of Club Polk -
lol...more brain washed on the road?... unbelievable! I guess there will be more coming soon. Let's wait and see!Make it simple...Make it better!
Well I think everyone should have a good time and do what they want and or can afford.
I read these posts with interest and ascertain that in some cases they do make a difference
they sure do look impressive.
But with my income I look for something that will work well that I can afford.
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
The opposite can also be true, correct? That is, people who believe that meters can tell one everything there is to know about a signal can also be brainwashed into believing this is true. A meter can only measure what it's designed to measure. Even then, there is a tolerence that the meter has and cannot measure beyond that threshold. Have you considered that what needs to be measured cannot be measured by a meter? Also, have you considered that the meter cannot measure in a fine enough scale to measure what needs to be measured? Something to think about...........
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I had not realized until this thread your level of ignorance on the subject matter. Thanks for exposing yourself.These people that say they hear a difference in the sound....Have they ever used any kind of equipments to measure and can prove they are right?. I do not think so!...all that is in their WASHED little brains.
While I firmly believe there is nothing better than the human ear for determining differences in audio related matters, forum member DarqueKnight has shown time and again that the process of burn in is real by posting scope readings clearly showing the differences.
In conclusion, take your insults and your ignorance somewhere else, it isn't welcome here.Political Correctness'.........defined
Time for the popcorn and beer.,,.,Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Please quit trolling. All you are doing is thread-crapping. We all know there are believers and non-believers re: all kinds of audio related issues. To start a war like this every time is worthless and amounts to nothing more than you being a jerk. If you want to start your own thread to re-hash these extremely worn-out arguments feel free, but what's the point other than to stir up a bunch of hate and dissension? Go to some other forum if you want to act like a condescending and superior little punk. We don't go much for that senseless and immature drivel here.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
dragon1952 wrote: »Please quit trolling. All you are doing is thread-crapping. We all know there are believers and non-believers re: all kinds of audio related issues. To start a war like this every time is worthless and amounts to nothing more than you being a jerk. If you want to start your own thread to re-hash these extremely worn-out arguments feel free, but what's the point other than to stir up a bunch of hate and dissension? Go to some other forum if you want to act like a condescending and superior little punk. We don't go much for that senseless and immature drivel here.
Well said!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
