12v Trigger
deronb1
I am trying to hook up a 12 v trigger from my avr to my amp. I used bare wire phone cable from my pre to my amp and it worked great. The avr has a 3.5 mm plug in so i took a 3.5 mm to rca cord and cut off the rca ends, stripped the wires and hooked it up. Getting a 12v trigger error message on the avr. Any suggestions?
Post edited by deronb1 on
Bump. Could use some help here. Stumped
You need to use a mono wire not stereo. I had to order one as they aren't easy to find in stores. Buy on that has 3.5 mm connectors on each end and cut one off. There is a wire within the wire and that one is the positive. The wire outside of that is the negative. That will make more sense when you cut the wire and see what I'm talking about.
Got mine at Radio Shack.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
http://www.amazon.com/Hosa-Cable-CSS103-Interconnect-Cables/dp/B000068NYF/ref=sr_1_4?ie=UTF8&qid=1369685748&sr=8-4&keywords=12v+trigger+cable
Different lengths availableThings work out best for those who make the best of the way things work out.-John Wooden -
Ok. Thank you gentlemen!
