12v Trigger
deronb1
deronb1 Posts: 5,021
edited May 2013 in Electronics
I am trying to hook up a 12 v trigger from my avr to my amp. I used bare wire phone cable from my pre to my amp and it worked great. The avr has a 3.5 mm plug in so i took a 3.5 mm to rca cord and cut off the rca ends, stripped the wires and hooked it up. Getting a 12v trigger error message on the avr. Any suggestions?
Post edited by deronb1 on
  • deronb1
    edited May 2013
    Bump. Could use some help here. Stumped
  • adb3da
    adb3da Posts: 507
    edited May 2013
    You need to use a mono wire not stereo. I had to order one as they aren't easy to find in stores. Buy on that has 3.5 mm connectors on each end and cut one off. There is a wire within the wire and that one is the positive. The wire outside of that is the negative. That will make more sense when you cut the wire and see what I'm talking about.
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2013
    Got mine at Radio Shack.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • PSOVLSK
    PSOVLSK Posts: 5,433
    edited May 2013
  • deronb1
    edited May 2013
    Ok. Thank you gentlemen!
