Polk 7.1 setup/advice
I have a pair of Monitor 50's as well. Is my amp so underpowered that I should consider switching my mains to those?
Probably not a bad idea. Do a search on clipping and that should give you a better idea on getting your system set up.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
How do I find out what the minimum power requirements are for my A9's, to get them out of harms way?
By the way, thank you all for your time, patience and expertise, it's greatly appreciated! -
Certainly you need a dedicated amp. I have parasound halo driving rti a9s and they sound great. Why not save up some more money (if budget is an issue at present), and buy pio sc series avr? I used to have marantz Sr 6006 (110 w per channel), and it was pretty nice. Warm sound. But recently i hooked up pio elite sc-65 and a huge difference. It also has preouts as well. Emotiva is a good economical option. Look for a good avr. Or a good preamp, but then you will need multi channel amp.
I am looking at the Pioneer Elite SC-67. It was benched by some hi-fi publication at over 110W per channel with 7 channels driven at 8 ohms if I remember correctly. That should make up a sizeable audio quality difference in my Denon as well as provide more power to the A9's.
Two channels driven continuously into 8-ohm loads:
0.1% distortion at 144.5 watts
1% distortion at 191.6 watts
Five channels driven continuously into 8-ohm loads:
0.1% distortion at 92.3 watts
1% distortion at 138.8 watts
Seven channels driven continuously into 8-ohm loads:
0.1% distortion at 90.0 watts
1% distortion at 113.8 watts
Analog frequency response in Pure Direct mode:
–0.24 dB at 10 Hz
–0.07 dB at 20 Hz
+0.93 dB at 20 kHz
–1.87 dB at 50 kHz
Satisfactory, yes? -
Your best bet is to buy a Denon 4520 CI Receiver. You will be able to run your system 7.2 without an issue.
It has the power to run 7.2, all the new hdmi connections and other whistles. They can be had for a respectable price refurbished. Thats how I bought mine. I am currently running a 9.2 system off it. I'm looking to add two more for a 11.2 system which will then require me to add a amp.
My system
Panasonic PT 7000U Projector
Denon 4520 Receiver
Polk RTi A5 front
Polk CSi A6 Center
Polk TSi 400 Front Wides
Polk FXi6 Sides
Polk RTi A3 Rear
Gonna add Polk RTi A1 Front Heights and eventually move my RTi A5 to Front wide and purchase RTi A7 for fronts.
I run it in Audyssey DSX ModePanasonic PT AE7000U Projector, Denon 4520CI Receiver, Polk CSi A6 Center, Polk RTI A5 Fronts, Polk Tsi 400 Front Wides, Polk Fxi A6 Sides, Polk RTi A3 Rear, PS3, 100" Apex Cinewhite screen.
Phil -
Saw this today Peaveydude and thought of you! This would DEFINATELY cure your power issues...
if you have your own reactor or hydro-electic dam available! 7 channels @ 350wpc!AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it -
Wow! That XPA-7 looks killer! That would solve all my issues no doubt, and inevitably lead to divorce as well! Anyway, I did what I thought was the right thing to do and addressed all my wants and needs in one go. I ordered a Pioneer Elite SC-67.
Heck yeah, I'm in the northwest, I'll just move up to Elbe, WA, theres a hydro-electric dam there. I am so in!!!Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3 -
I think the Pioneer Elite will suit your needs. It's definitely better than the average budget AVR. If I'm looking at the manual right, it can push about 85w per channel simultaneously. Seeing as how things don't typically push all speakers simultaneously, you will likely get a little more out of it than that. The only downside is what was mentioned earlier, if you want comparable quality a few years from now, you will have to shell out for another beefy AVR rather than just a processor. Still an excellent choice though. The fever may hit down the road and drive you to get a more powerful amp anyway
Hey all .. just joined CP .. i ordered an entire set of polk monitors for my 7.1 setup .. 65s for L and R, 35s for surrounds and front highs and a 25 for C .. after reading through this thread I'm afraid I'm going to damage my speakers by using my existing Onkyo ht-s5400 receiver .. I bought the HTiB about a year and a half ago and finally became unsatisfied with the sound quality .. now that i switched to the Polk's it sounds great .. just worried I'm doing something wrong..
