Anyone hooked up two subs for different freq response?
z28chrismac
I have two psw650's, I am running full range into sub1 RCA input; sub1 crossover set to ~45hz, then have the high-pass output of sub1 going into sub2; sub2 crossover set to ~80Hz...I tried it and it sounded amazing!
Thoughts?
Thoughts?
___________________
350" 1080p 3D Mitsubishi projector
AVR: Yamaha RX-V2700
Mains: T90e's (bi-amped)
Center: CSiii
Surrounds: 2x T90e's
Subs: 2x PSW650
Center: CSiii
Subs: 2x PSW650
Post edited by z28chrismac on
If it sounds good to you, enjoy!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
jhonkidward4 reportedIf you can't hear a difference, don't waste your money.
Hmmm, interesting idea...if it sounds great then kudos!
Similar to the idea of the Mid Bass module the HSU Research offers: http://www.hsuresearch.com/products/mbm-12mk2.html
The use a driver better suited for upper mid-bass.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
What is your system? Is it theater or 2 channel?
I never use 2 subs running different frequencies as I don't see any point doing so. Most of the time , Subwoofers are running 80hz and below. This is not a lot of Frequencies for a sub to get jumbled or lose timing etc.
What 2 subs do in a room is cover more areas with even bass. They work together to smooth out the room.Dan
- I get 2 subs to smooth out the room.
- I get the HSU idea of a sub in the corner and a light cone low inductance driver midbass module closer to the listener
-It sounds like the OP is trying to do a little of both? I guess the questions are...where are the subs placed in the room? How much different does the different crossover points sound vs. both at the same crossover point? The psw650 is not a "true" low end monster. I think the Tom Nousaine measurement has it at ~ 105.9dB (35hz). While a couple of other moderate sized subs measured at SVS 20-39cs ~ 109.5dB (25hz), Hsu vtf-2 ~ 107.1(25hz)
IMO, using something like the Polk or HSU MBM playing higher close to the listener then adding something like the "True Subwoofers" HSU or SVS or a large 15"-18" true 20Hz monster in the corner would support the split frequency idea better.
...but if the op already has two Polk subs then by all means use them and enjoy them!2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Doc Earl Geddes has been doing some interesting things with multiple subs.
http://www.gedlee.com
You need the PowerPoint to follow the video.
http://www.gedlee.com/downloads/Optimal%20Bass%20Playback%20in%20Small%20Rooms.pptx
Video Presentation
http://www.ustream.tv/recorded/28637776/highlight/319149 -
Good stuff there...2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Yes i did it the simple way. I used a y cable (a good one) on a sub out from the receiver i've tried mixing and matching but matching the freqs seem to give it a smoother sound to me but it's all about user preference.
