Suggest a power cord
ROHfan
As I get along in this hobby certain things confound me. My field is testing and certification of copper cable and fiber optic cable so it's difficult at times to separate the myriad of meter readings from perceived sonic differences. Every so often something that, on paper, shouldn't sound different winds up doing just that.
I'd like to try a new power cord for my Emo UPA-200 because I love this thing and want something better for it. What would anyone recommend for around $50? I was going to make my own cable with good quality ends and some Techflex but I figured it would probably run me over $50 anyways so that's where my price cap is for buying one. I'm curious to see if there's an actual difference in sound even though my core tells me it can't be. So please, if you're of the "power cables don't matter" camp, ignore this thread. Thanks!
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
PM pepster and see what he can do for ya lol.
If not check out audiogons used selection. Pangea comes to mind.
How long do you need?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »PM pepster and see what he can do for ya lol.
I haven't used pepsters but I've heard good things about his work. I'm using Pangea and like them... -
You are not going to find much new at $50 that is useful. Spend $150 and get a new Shunyata Venom. When I added them to my amps I was so impressed that a month later I bought two Shunyata Python cables at 1k each.
http://www.musicdirect.com/p-9670-shunyata-venom-3-power-cable.aspxLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Im with endersshadow on this,Pepster makes nice cables.
Dan -
I may let go the tara labs PC I just bought for a 50. While I like it, I already have upgraded power cords and the Tara Labs is about on equal ground with the ones I have so turned out to be a lateral move for me. Pm me if ya want.HT SYSTEM-
lsi 9's -
Pangea or signal cable magic power for new but with as much used stuff on the form, you might be able to get a better cable used and broken in already for close to the same price.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Just a FYI, Endershadow has contacted me already about the Tara Labs power cord. Just want to set the record straight here in case the OP mentions something in this thread.HT SYSTEM-
lsi 9's -
Yup, to continue on that ideal, I discovered the powercable I thought would work for my M1.0t isnt long enough and I have been kicking myself in the rear for passing on the Tara Labs one the first time."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
PM sent.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
President of Club Polk -
Used pangea ac9
EMO carries a PC as well why not give them a try..as they made your UMC..As I get along in this hobby certain things confound me. My field is testing and certification of copper cable and fiber optic cable so it's difficult at times to separate the myriad of meter readings from perceived sonic differences. Every so often something that, on paper, shouldn't sound different winds up doing just that.
I'd like to try a new power cord for my Emo UPA-200 because I love this thing and want something better for it. What would anyone recommend for around $50? I was going to make my own cable with good quality ends and some Techflex but I figured it would probably run me over $50 anyways so that's where my price cap is for buying one. I'm curious to see if there's an actual difference in sound even though my core tells me it can't be. So please, if you're of the "power cables don't matter" camp, ignore this thread. Thanks!ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Check ou audioadvisor for pangya cable. They are known for their quality.
Who or what is Pepster?
A Club Polk forum member that makes power cords and interconnects and sales them. He will make custom make them to certain lengths using whatever connectors you want..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
