Suggest a power cord
ROHfan
ROHfan Posts: 1,014
edited March 2013 in Electronics
As I get along in this hobby certain things confound me. My field is testing and certification of copper cable and fiber optic cable so it's difficult at times to separate the myriad of meter readings from perceived sonic differences. Every so often something that, on paper, shouldn't sound different winds up doing just that.
I'd like to try a new power cord for my Emo UPA-200 because I love this thing and want something better for it. What would anyone recommend for around $50? I was going to make my own cable with good quality ends and some Techflex but I figured it would probably run me over $50 anyways so that's where my price cap is for buying one. I'm curious to see if there's an actual difference in sound even though my core tells me it can't be. So please, if you're of the "power cables don't matter" camp, ignore this thread. Thanks!
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
    EndersShadow Posts: 17,749
    edited March 2013
    PM pepster and see what he can do for ya lol.
    If not check out audiogons used selection. Pangea comes to mind.
    How long do you need?
  • ken brydson
    ken brydson Posts: 9,085
    edited March 2013
    I haven't used pepsters but I've heard good things about his work. I'm using Pangea and like them...
  • BlueFox
    BlueFox Posts: 15,250
    edited March 2013
    You are not going to find much new at $50 that is useful. Spend $150 and get a new Shunyata Venom. When I added them to my amps I was so impressed that a month later I bought two Shunyata Python cables at 1k each.
    http://www.musicdirect.com/p-9670-shunyata-venom-3-power-cable.aspx
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited March 2013
    Im with endersshadow on this,Pepster makes nice cables.
    Dan
    edited March 2013
    I may let go the tara labs PC I just bought for a 50. While I like it, I already have upgraded power cords and the Tara Labs is about on equal ground with the ones I have so turned out to be a lateral move for me. Pm me if ya want.
  • erniejade
    erniejade Posts: 6,321
    edited March 2013
    Pangea or signal cable magic power for new but with as much used stuff on the form, you might be able to get a better cable used and broken in already for close to the same price.
    edited March 2013
    Just a FYI, Endershadow has contacted me already about the Tara Labs power cord. Just want to set the record straight here in case the OP mentions something in this thread.
    edited March 2013
    tonyb wrote: »
    Yup, to continue on that ideal, I discovered the powercable I thought would work for my M1.0t isnt long enough and I have been kicking myself in the rear for passing on the Tara Labs one the first time.
  • zingo
    zingo Posts: 11,258
    edited March 2013
    A used PS Audio power cord.
  • polrbehr
    polrbehr Posts: 2,866
    edited March 2013
    PM sent.
    F1nut Posts: 52,296
    edited March 2013
    zingo wrote: »
    Now you're talking.
  • Conradicles
    Conradicles Posts: 6,419
    edited March 2013
    Used pangea ac9
  • Jhayman
    Jhayman Posts: 1,548
    edited March 2013
    EMO carries a PC as well why not give them a try..as they made your UMC..
    ROHfan wrote: »
  • jumpindick
    jumpindick Posts: 428
    edited March 2013
    Check ou audioadvisor for pangya cable. They are known for their quality.
  • KLapinas
    KLapinas Posts: 608
    edited March 2013
    Who or what is Pepster?
  • hochpt21
    hochpt21 Posts: 5,423
    edited March 2013
    KLapinas wrote: »
    The Man, The Myth, The Legend...
    edited March 2013
    KLapinas wrote: »
    A Club Polk forum member that makes power cords and interconnects and sales them. He will make custom make them to certain lengths using whatever connectors you want...
