I will be buying a DAC this week, what one should I choose?
  • FTGV
    FTGV Posts: 3,650
    edited March 2013
    Huh? If he's running lossless files with a bitperfect media player, there's hardly a better digital source.
    Agreed,loaded with flac using J River and a good USB DAC(preferably async) would make for a great source.
  • falconcry72
    falconcry72 Posts: 3,580
    edited March 2013
    I currently own (2) of the Audio GD "Big Boys" (NFB-7 and NFB-8). I will gladly put either one of them up against any of the DACs mentioned in this thread. Who's down for a shootout???
    Incase I'm being too shy...
    I will ship you one of my NFB's for you to evaluate against another DAC!
    All I ask is that you provide an honest comparison afterwards... and that you use its balanced outputs... these DAC's are meant to be run balanced.
  • falconcry72
    edited March 2013
    In case I'm being too shy...
    This offer goes for anyone reading this.. as long as you have halfway decent credibility here at CP.
  • BlueFox
    BlueFox Posts: 15,250
    edited March 2013
    I don't know about the credibility part, but I will take you up on that offer. I was just looking at their web-site and am interested. It will replace my Bryston BDA1. However, it needs to have a balanced AES input since that is how the Bryston BDP1 digital file player is connected. It will have MIT Shotgun S1.3 balanced cables out, and a Shunyata Ztron Cobra power cable.
    Is it burned in?
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited March 2013
    My Anthem D2 has balanced inputs for 2 ch stereo so would this at least sound better than the preamp capabilities of a DAC in my price range ? Is also jriver the best music software to use? My laptop does not have a any disk drives and just used hdmi to the anthem D2 with music and it sounds horrible. I do have a gaming rig coming from ZLTFUL that may pair up with a DAC better than my laptop.
  • falconcry72
    edited March 2013
    BlueFox wrote: »
    Is it burned in?
    Good. They both do better via AES. I will send you deets via PM>.
  • BlueFox
    edited March 2013
    Okay. This should be interesting. Thanks.
    EndersShadow Posts: 17,722
    edited March 2013
    Crap, I have NO CRED here :smile:.... oh and no gear good enough to run these :biggrin:
    Carry on, felt like being a punk tonight :razz:
    SCompRacer Posts: 9,123
    edited March 2013
    FTGV wrote: »
    Right now I have a laptop connected to my Amanero USB to I2S adapter in DAC. Using foobar with a 1TB external USB hard drive loaded with flac files connected to laptop via USB. Works great, sounds great, no hick-ups.
    EDIT: Oh Fred, at long last...the Twisted Pear Asynchronous USB Audio class 2 module.:cool:
    http://www.diyaudio.com/forums/twisted-pear/231514-asynchronous-usb-audio-class-2-module.html
  • Thorton
    Thorton Posts: 1,324
    edited March 2013
    This is pretty cool. I can't wait to here the comparison results.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
    heiney9 Posts: 25,509
    edited March 2013
    I agree with you Fred and Rich, except I guess I envisioned PFB using iTunes out of the USB. Set-up properly it can be a great source. But not many take the time to acquire the knowledge and take the time to do it properly. That's where my comment came from.
    edited March 2013
    heiney9 wrote: »
    I didn't even think about it as I knew you knew a laptop can be used if set up proper cause you have. I just wanted to add you can hook up an external USB drive to the laptop.
    I was also gonna suggest black spray paint; you can make anything match.:cheesygrin:
  • FTGV
    FTGV Posts: 3,650
    edited March 2013
    SCompRacer wrote: »
    Wow finally!I don't really need it but I might have to if you know what I'm sayin.
  • FTGV
    FTGV Posts: 3,650
    edited March 2013
    SCompRacer wrote: »
    Lol ,any suggestions as to where to find suitable black paint?:lol:
    edited March 2013
    FTGV wrote: »
    Wasn't there a thread here aboot dat?:cheesygrin:
    I hear ya on the TP USB module. I'm thinkin' some OP influence in that design.
  • FTGV
    FTGV Posts: 3,650
    edited March 2013
    SCompRacer wrote: »
    Yarp.
    I can see why it took so long in development ,looks well thought out.
  • headrott
    headrott Posts: 5,496
    edited March 2013
    SCompRacer wrote: »
    Enders, you should check this out. The Twisted Pear USB module should be outstanding!
  • headrott
    edited March 2013
    I'd be interested in a shootout after BlueFox is done if you are looking for a follow up comparison. You can find the DAC I built that I will compare it to here: http://www.polkaudio.com/forums/showthread.php?119264-Fully-balanced-Buffalo-II-DAC-with-Tube-I-zator-tube-output.
    If you are not interested in sending the DAC to multiple people, it's no biggie though.:wink:
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2013
    You can run a TT preamp into the Benchmark DAC/PRE or HDR flavor thru it's analog input. I'd recommend either the DAC/PRE or HDR to get the upgraded op-amps. Been very satisfied with Benchmark DAC's for over 8 years.
  • Face
    Face Posts: 14,340
    edited March 2013
    I may have a DAC-2 available...
  • blairfrischx
    blairfrischx Posts: 259
    edited March 2013
    I'd recommend getting a USB->SPDIF converter instead of a dedicated DAC. The Stello U2 and U3 are both good. The KingRex UD384 is also pretty well-regarded.
    I'd be seriously interested in hearing how the more expensive Audio-GD products compare to my Stello DA100 Signature. They're pretty similar in price, both balanced, and both from Asian manufacturers.
    I don't know about credibility, though. I don't post much; I just hang around. :redface:
  • Lost240
    Lost240 Posts: 176
    edited March 2013
  • RamZet
    RamZet Posts: 792
    edited April 2013
    Bryston DAC.
    http://bryston.com/products/digital_audio/BDA-2.html
    or the BDA-1
    The Bryston preamp has the same DAC built in so you get the DAC and Preamp for a better deal.
    Why Bryston?
    http://www.stereophile.com/content/bryston-bda-1-da-converter-page-2
    B&W CM9Classé Sigma
  • polkfarmboy
    edited April 2013
    I went with the ps audio perfectwave dac
  • Ducati Guy
    Ducati Guy Posts: 160
    edited April 2013
    Any thoughts on the new Parasound Zdac?
    Just read a rave review in HiFi Choice about it and Parasound always seems to build high quality stuff.
    $475 is a reasonable real world price.
    Anyone on here recently bought one?
  • Habanero Monk
    Habanero Monk Posts: 715
    edited April 2013
    heiney9 wrote: »
    If all you have is a laptop for a source, don't waste $2K on a dac.
    What? For $2K the OP could get a Macbook and Apogee Duet 2.
