please talk me out of it
marvda1
i have the usher r 1.5 150 watt power amp and am thinking about the plinius sa-50 mk3 50 watt class a power.
the plinius is up for sale at $1600. should i go after it or be happy with what i have? speakers usher dancer mini 2 and usher cp-6381.
HELP
HELP
Puritan PSM156
Puritan PSM156
Post edited by marvda1 on
Get a grip on yourself marvda1. Don't you like your existing system ? Will you actually get $1600 more sound ? :eek:
Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
Jump....jump off that fence bro. Whats the worst that could happen ? You fall in a pile of dog do-do ? Then you re-sell,take a shower and start over.HT SYSTEM-
lsi 9's -
Get it so I could listen to it with using your money2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
sheesh... i thought i was being the big spender finally getting a Peachtree DAC-it to A/B with my Bifrost.
can you pay your bills and feed your family, and have wiggle room for the unforeseen? good... then get it and write a review here. think of the great service you will be doing for your fellow Polkies.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Speaking of which, did you post a review yet or did I miss it somewhere ?HT SYSTEM-
lsi 9's -
Jump, jump, jump...................If you can't hear a difference, don't waste your money.
i would sell the usher and try to make the cost a wash..........dskip:rolleyes: the plinius would still be my backup amp unless it just blows away the consonance cyber 800's
i am still burning in the dm2's and just upgraded my speaker cables to mg audio design planus 2. dskip, you can help me move the 6381's out
and set up the dm2. Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
You need to get a life if all you have to do with your time is endlessly spend thousands of dollars that you most likely will NOT make up in resale of gear that if you were put in a room blindfolded you wouldn't be able to tell the difference! But it's your life and your money so knock yourself out.
As someone above said, if all your other expenses are taken care of and you are not in debt up to your eyeballs enjoy.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
cfrizz, then why in the hell did you spend all that money on the gear that you have? there's lots of cheaper equipment out there since YOU can't hear the difference in the dark:idea:Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I believe that cfrizz is suggesting that maybe one should amass the cash from sales of whatever equipment first and then, with money in the bank, do "whatever" strikes one's fancy! And I'm almost certain that that is the way she put "her" system together! Otherwise, your thread "Please talk me out of IT!" Is meaningless, no?
I think Tony has it spot on.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
what do you seek to improve on from your current usher r1.5 amp?
Condescending much? What a rude comment. You need to get a life if all you're going to do is come in here, stir the pot and leave your negative .02 cents. If you made good money wouldn't you want to spend it on you or you're family?
You should also replace all of your gear with a budget of $500 for EVERYTHING and see how far you get and if you can "tell the difference". -
transparency and detail and maybe some more low end control with more mid range warmth.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
MORE,MORE MORE....Stop it will ya!..... Slap,Slap....Did I talk you out of it ? Isn't that what you wanted according to the Thread Title ? Or is there no Hope for ya ! :loneranger:Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
when you found that amp for the md2, let me know!transparency and detail and maybe some more low end control with more mid range warmth.
In fairness to cfrizz, the title of the thread is "please talk me out of it", so it seems like she was just following your suggestion. -
and set up the dm2.
Hmmm....quite a predicament. How are you gonna tell if the added "transparency and detail and maybe some more low end control with more mid range warmth" you're looking for, if realized, is from the new plinius or from the changes in the sound delivered by the dm2's as they continue to burn in, or from your new mg audio design planus 2 cables? I think you've got too many changes going on at once there to give an accurate appraisal of where any change in sound quality originated from.
If it were me, I'd first put those new mg audio design planus 2 cables on my cable cooker for a good long spell. Then, and only then, after I'd evaluated the overall system until it couldn't be evaluated anymore, would I proceed to stir things up more with the addition of a new plinius. At that point, I'd be reasonably certain that the addition of the new plinius sa-50 mk3 to my system could be properly evaluated as to whether it added $1600 worth of transparency and detail and maybe some more low end control with more mid range warmth...or not. -
the speaker cables should be burned in as they were trade ups. the problem is the usher is not my main amp, that goes to the cyber 800 (tube). the usher is more or less a backup amp and by selling the usher i could just about pay for the plinius. now whether the plinius can dethrone the consonance is another question. maybe my thinking is off and i should be trying to replace the main amps instead of the backup amp.
might have just talked myself out of it but now it's going to cost me more money
a never ending battle
Puritan PSM156 -
Usher md 2 takes at least 100 hrs for the tweeter to settle in
I had a 'class A' Pass Labs amp and like the sound much better than A/B amps I've owned. You should like what you hear from Plinius.
$1600 will buy one Shunyata Cobra Ztron power cord with $600 left over. I'm not sure what $1600 worth of sound is, but I love the end result of adding this cord from the wall to the power conditioner in the HT. It made the audio and the picture better. So, I say buy the gear. You get what you pay for.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
ok, ok, i see the light. it makes more sense to save up to replace my main amp with something better than to drain money by upgrading the backup amp. oh well that's it for audio nervosa.
Puritan PSM156 -
i forgot about that, cheaper too. you know how cheap i am:razz: saw you called twice, left the phone at home and went out to eat with the wifey and daugther. wish i could hear the Be and DMD side by side.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
