Center Channel Level
tophatjohnny
I just added a TL3 Blackstone (only thing in the Polk line that would fit) and was wondering at what level to set it in comparison to the other speakers. Runnning a 5.1 Rt20001's FXi300's and an older sub. Just looking to see if other people set all the speakers at a certain level and if so what that is. The answer may be what sounds good to me, so fire away. If it matters I am using aTX NR707 and a Acurus 125x5 on this set up. I have the fronts set at 10.5 center at 7.5 rear R&L at 8.5 and sub at 6.5. Thanks and I hope this isn't too dumb of a question.
Every room is different, and distance plays a big role too. Can your receiver play test tones? If so, just set it by ear. I normally set the center just a hair quiter than the fronts, and the surrounds just a hair louder than the fronts. Good luck!2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Man, if all those speaker levels are on the + side, thats running them pretty hot. I don't think I ever had a speaker at anymore than a +3.....even a subwoofer.HT SYSTEM-
lsi 9's -
Thanks Tony.
I lowered them all."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
The only way anyone can tell you how to PROPERLY set this is with a sound pressure level meter. Worth the $35 you'll spend on one.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
kuntasensei wrote: »The only way anyone can tell you how to PROPERLY set this is with a sound pressure level meter. Worth the $35 you'll spend on one.
Where can you pick up a decent one in that price range? -
Equipment list:
Emotiva XPA-3 amp
Anthony Hinton wrote: »Where can you pick up a decent one in that price range?
Got a smartphone, ipod touch or tablet? SPL apps are anywhere from free to about 5 bucks. I wouldn't do professional setups with em, but they will certainly help you even out the levels. I use my phone more than my radio shack meter just because its always on me...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
