Center Channel Level
tophatjohnny
tophatjohnny Posts: 4,189
edited February 2013 in Speakers
I just added a TL3 Blackstone (only thing in the Polk line that would fit) and was wondering at what level to set it in comparison to the other speakers. Runnning a 5.1 Rt20001's FXi300's and an older sub. Just looking to see if other people set all the speakers at a certain level and if so what that is. The answer may be what sounds good to me, so fire away. If it matters I am using aTX NR707 and a Acurus 125x5 on this set up. I have the fronts set at 10.5 center at 7.5 rear R&L at 8.5 and sub at 6.5. Thanks and I hope this isn't too dumb of a question.
  • falconcry72
    falconcry72 Posts: 3,580
    Every room is different, and distance plays a big role too. Can your receiver play test tones? If so, just set it by ear. I normally set the center just a hair quiter than the fronts, and the surrounds just a hair louder than the fronts. Good luck!
    Man, if all those speaker levels are on the + side, thats running them pretty hot. I don't think I ever had a speaker at anymore than a +3.....even a subwoofer.
  • tophatjohnny
    tonyb wrote: »
    Thanks Tony.
    I lowered them all.
  • kuntasensei
    kuntasensei Posts: 3,263
    The only way anyone can tell you how to PROPERLY set this is with a sound pressure level meter. Worth the $35 you'll spend on one.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Anthony Hinton
    Anthony Hinton Posts: 107
    Where can you pick up a decent one in that price range?
  • kuntasensei
    Equipment list:
    Emotiva XPA-3 amp
  • rooftop59
    rooftop59 Posts: 8,120
    Got a smartphone, ipod touch or tablet? SPL apps are anywhere from free to about 5 bucks. I wouldn't do professional setups with em, but they will certainly help you even out the levels. I use my phone more than my radio shack meter just because its always on me...
    Game Room 5.1.4:
    Bedroom 2.1
