Is there a "BEST" SRS speaker??
naturallight wrote: »
If they sell..well i can put some of the money at the furnace.....LOL
That's what my wife says I am doing every time I spend more money on any of this stuff!! lol"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Well not sure i "need" the RTi12's that much..the furnace..i do. they were not the right speaker choice for what i wanted...but at this point, may pay for some of the furnace...LOL
If i can sell them at all..which maybe, down here....not likely..... -
naturallight wrote: »Well not sure i "need" the RTi12's that much..the furnace..i do. they were not the right speaker choice for what i wanted...but at this point, may pay for some of the furnace...LOL
I think what tophatjohnny meant to say was, "Everytime I spend money on speakers, my wife says I'm putting money in the furnace... as in burning money". :rolleyes:
LMAO well i wish i had a furnace that was working.....
Believe what you want, they are 6 ohm nominal.Conradicles wrote: »Also page 26 of the SDA Handbook states Polk raised the imp from 6 to 8 ohms.
Pick something else to argue with Jesse about. Try "The economic impact of drugs from Bolivia to America", You might have a chance on that topic LOLToo much **** to list.... -
It is always better to ask for forgiveness than permission.....
Wiser words have never been spoken. -
You never did say what was wrong with it, mine was just a $200 circuit board.naturallight wrote: »LMAO well i wish i had a furnace that was working.....POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
if you want to sell you rti12s on CL. I think the realistic price is around 450. I bought mine for 400 and regularly see them for 450. sometimes A9s for 500 bucks too.
but if you want to go big, why not hunt for the SRT system? -
I knew that was a good deal on yesterday's local craigs; a pair of rti12's and a 7.1 jvc ht receiver for $199. I might have to take a look and see if they're still there.
The furnace is a really old gas unit. The burner box has just finally rusted to the point it has holes in it. Which is unfix-able and dangerous at this point. So the whole unit needs to be replaced.
To sell the 12's for 400, just doesn't seem worth it. Just because i don't like them, as compared to the SDA's doesn't mean there bad speakers. Guess i'll end up moving them upstairs, let the wife use them for her music, or stick them on the TV. -
michaeljhsda2 wrote: »My 1.2 TL's are on the 8 ohm taps of my tube amp. Should they be on the 4 ohm taps instead?
Anyone know the answer to this?SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »Anyone know the answer to this?
Yes, use the 8 ohm taps.Political Correctness'.........defined
President of Club Polk -
ThanksSDA SRS 2.3TL's
SDA 2B TL's -
Is this to say that you would use the next higher impedance if the exact one was not available? That is use 4 ohm for 3 ohm nominal and 8 ohm for 6 and so on?Too much **** to list.... -
The last series, the TL's, were made to make the the amp see as much of a 8 ohm load as possible, thus being easier to drive with out needing special lower impedance equipment. They were not true 8 ohm speakers in the sense of the word. All speakers exhibit an impedance curve just like they have high and low spots in there frequency response. But yes you go up not down use 4 for a 3 and 8 for a 6 but you use 6 for 6 if you have it of course.Is this to say that you would use the next higher impedance if the exact one was not available? That is use 4 ohm for 3 ohm nominal and 8 ohm for 6 and so on?POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Just curious, where did you get this information? -
naturallight wrote: »The furnace is a really old gas unit. The burner box has just finally rusted to the point it has holes in it. Which is unfix-able and dangerous at this point. So the whole unit needs to be replaced.
If you need a new furnace buy one online and install it yourself. Ingrams water and air is one company. The 2.3tl is the best in my opinion, the set in Colorado is a steal. -
Page 10 (pdf file page 17) of the Sda Handbook.Conradicles wrote: »Just curious, where did you get this information?POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
The best ones are the ones in front of you.Mcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Pro-ject Record Player
Sony 200 disc CD Changer
Basic Wiring
60" Samsung Series 8
SDA-1.2TL
SDA-3.1TL (unused at the moment) -
LMAO..well i know where to get the cheap price for the furnace, and whatever else.
Yes i could install it..if i was 40. Not like i don't know how to install it. But i'm 60 with a bad back.
Which means if i pick up a case of 24 bottles of water the wrong way..my back goes out.
The sad part of this is i just can't do what i used to...so i have to pay people to do it.
Believe me..not what i want..and i know i could get this done for 1K easy....but not going to happen -
@ OP. Yes there is. Hands down the best SDA SRS are the one's in MY living room.
I figured someone beat me to it but still.Too much **** to list.... -
Man I like that answer the best! So right!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Or love the ones your love and be glad you got ones to love
But I would like to get some 1.2Tls some dayPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
