Is there a "BEST" SRS speaker??
  • tophatjohnny
    tophatjohnny Posts: 4,189
    edited February 2013
    If they sell..well i can put some of the money at the furnace.....LOL
    That's what my wife says I am doing every time I spend more money on any of this stuff!! lol
  • naturallight
    naturallight Posts: 689
    Well not sure i "need" the RTi12's that much..the furnace..i do. they were not the right speaker choice for what i wanted...but at this point, may pay for some of the furnace...LOL
    If i can sell them at all..which maybe, down here....not likely.....
  • Mystery
    Mystery Posts: 2,546
    I think what tophatjohnny meant to say was, "Everytime I spend money on speakers, my wife says I'm putting money in the furnace... as in burning money". :rolleyes:
  • naturallight
    LMAO well i wish i had a furnace that was working.....
  • SDA1C
    SDA1C Posts: 2,072
    Believe what you want, they are 6 ohm nominal.
    Also page 26 of the SDA Handbook states Polk raised the imp from 6 to 8 ohms.
    Pick something else to argue with Jesse about. Try "The economic impact of drugs from Bolivia to America", You might have a chance on that topic LOL
    Too much **** to list....
  • Anthony Hinton
    Anthony Hinton Posts: 107
    Bugstyvy wrote: »
    It is always better to ask for forgiveness than permission.....
    Wiser words have never been spoken.
  • PolkieMan
    PolkieMan Posts: 2,446
    You never did say what was wrong with it, mine was just a $200 circuit board.
  • nhhiep
    nhhiep Posts: 877
    if you want to sell you rti12s on CL. I think the realistic price is around 450. I bought mine for 400 and regularly see them for 450. sometimes A9s for 500 bucks too.
    but if you want to go big, why not hunt for the SRT system?
  • motorstereo
    motorstereo Posts: 2,367
    I knew that was a good deal on yesterday's local craigs; a pair of rti12's and a 7.1 jvc ht receiver for $199. I might have to take a look and see if they're still there.
  • naturallight
    The furnace is a really old gas unit. The burner box has just finally rusted to the point it has holes in it. Which is unfix-able and dangerous at this point. So the whole unit needs to be replaced.
    To sell the 12's for 400, just doesn't seem worth it. Just because i don't like them, as compared to the SDA's doesn't mean there bad speakers. Guess i'll end up moving them upstairs, let the wife use them for her music, or stick them on the TV.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    My 1.2 TL's are on the 8 ohm taps of my tube amp. Should they be on the 4 ohm taps instead?
    Anyone know the answer to this?
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 52,005
    Yes, use the 8 ohm taps.
  • michaeljhsda2
    SDA SRS 2.3TL's
    SDA 2B TL's
  • SDA1C
    SDA1C Posts: 2,072
    Is this to say that you would use the next higher impedance if the exact one was not available? That is use 4 ohm for 3 ohm nominal and 8 ohm for 6 and so on?
  • PolkieMan
    The last series, the TL's, were made to make the the amp see as much of a 8 ohm load as possible, thus being easier to drive with out needing special lower impedance equipment. They were not true 8 ohm speakers in the sense of the word. All speakers exhibit an impedance curve just like they have high and low spots in there frequency response. But yes you go up not down use 4 for a 3 and 8 for a 6 but you use 6 for 6 if you have it of course.
    SDA1C wrote: »
  • Conradicles
    Conradicles Posts: 6,377
    PolkieMan wrote: »
    Just curious, where did you get this information?
  • 4406bbl
    4406bbl Posts: 194
    If you need a new furnace buy one online and install it yourself. Ingrams water and air is one company. The 2.3tl is the best in my opinion, the set in Colorado is a steal.
  • PolkieMan
    Page 10 (pdf file page 17) of the Sda Handbook.
  • Bugstyvy
    Bugstyvy Posts: 119
    The best ones are the ones in front of you.
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Pro-ject Record Player
    Sony 200 disc CD Changer
    Basic Wiring
    60" Samsung Series 8
    SDA-1.2TL
    SDA-3.1TL (unused at the moment)
  • naturallight
    LMAO..well i know where to get the cheap price for the furnace, and whatever else.
    Yes i could install it..if i was 40. Not like i don't know how to install it. But i'm 60 with a bad back.
    Which means if i pick up a case of 24 bottles of water the wrong way..my back goes out.
    The sad part of this is i just can't do what i used to...so i have to pay people to do it.
    Believe me..not what i want..and i know i could get this done for 1K easy....but not going to happen
  • SDA1C
    SDA1C Posts: 2,072
    @ OP. Yes there is. Hands down the best SDA SRS are the one's in MY living room.
    I figured someone beat me to it but still.
  • tophatjohnny
    Bugstyvy wrote: »
    Man I like that answer the best! So right!
  • PolkieMan
    Or love the ones your love and be glad you got ones to love:lol:
    But I would like to get some 1.2Tls some day
