How's this for sexy?
strider
This is one dead sexy attenuator:
http://www.partsconnexion.com/prod_pdf/khozmo.pdf
Anybody heard of these? Looking for a steeped attenuator for a preamp I built, doesn't have to be this expensive.
Wristwatch--->Crisco
I've seen those too, and gave them consideration as they look fantastic. You would benefit from having a plexiglass front preamp to show it off.
They're not cheap, but there are also a lot more expensive volume controls.
http://www.partsconnexion.com/conrtols_attenuator_khozmo.html -
I'd love to see a cross section/internals view but, they're probably way too expensive to destroy for illustrative purposes !!! :eek:
Meh, ended up with one not quite as alluring. Still a stepped attenuator, picked it up from a guy in Hong Kong. Here's a link. It did have some positive mentions on the internet, however, and at $18 it's about a tenth of the one from Parts Connexion!Wristwatch--->Crisco
yeah... but I think for best results one is better off with a transformer/autoformer volume control.
http://www.intactaudio.com/
(and, frankly, how it sounds is more important to me than what it looks like - YMMV, of course)/ -
Form definitely follows function. Both of which, though, are behind price. That autoformer would be out of my price range too, unfortunately.Wristwatch--->Crisco
How sad is one's life if you think an electronics part is sexy?
Now this, on the other hand, is sexy.....................
nice butt.jpgIf you can't hear a difference, don't waste your money. -
Amen brother you said it. Although I would prefer just a tad bit bigger hooters.
I just emailed the seller of the khozmo in Warsaw as he offers a remote controlled version as a passive preamp which looks interesting.
Attenuator
Number of steps: 48
Contact material: Hard silver 99,99% Ag
Channel matching: +/-0.1 dB
Resistance: 10, 20, 50 or 100 kOhm (other values on request)
Resistors: INPUT - Caddock MK132; GND - military Vishay/Dale RN55 1% 100ppm , 1/10W, low noise, non-inductive, metal film
Upgrade options:
Remote control - $200
Vishay Zfoil series resistor - $49
Takman REX shunt resistors - $69
CNC machined enclosure made of exotic wood and anodized aluminium
Dimensions: W280 x H80 x D210 mm
Weight: 2,8kg
Shipping with EMS:
Europe - $49
USA, Canada - $55
Asia, Africa - $69
Australia, New Zeland - $79
