How's this for sexy?
strider
strider Posts: 2,568
edited January 2013 in DIY, Mods & Tweaks
This is one dead sexy attenuator:
http://www.partsconnexion.com/prod_pdf/khozmo.pdf
Anybody heard of these? Looking for a steeped attenuator for a preamp I built, doesn't have to be this expensive.
Wristwatch--->Crisco
  • zingo
    zingo Posts: 11,258
    edited October 2012
    I've seen those too, and gave them consideration as they look fantastic. You would benefit from having a plexiglass front preamp to show it off. :) They're not cheap, but there are also a lot more expensive volume controls.
    http://www.partsconnexion.com/conrtols_attenuator_khozmo.html
  • gdb
    gdb Posts: 6,012
    edited October 2012
    I'd love to see a cross section/internals view but, they're probably way too expensive to destroy for illustrative purposes !!! :eek:
    F1nut Posts: 52,406
    edited October 2012
    strider wrote: »
    Indeed!!!
  • strider
    edited October 2012
    Meh, ended up with one not quite as alluring. Still a stepped attenuator, picked it up from a guy in Hong Kong. Here's a link. It did have some positive mentions on the internet, however, and at $18 it's about a tenth of the one from Parts Connexion!
    mhardy6647 Posts: 35,562
    edited October 2012
    yeah... but I think for best results one is better off with a transformer/autoformer volume control.
    http://www.intactaudio.com/
    (and, frankly, how it sounds is more important to me than what it looks like - YMMV, of course)/
  • strider
    edited October 2012
    Form definitely follows function. Both of which, though, are behind price. That autoformer would be out of my price range too, unfortunately.
  • decal
    decal Posts: 3,204
    edited October 2012
    How sad is one's life if you think an electronics part is sexy?
    Now this, on the other hand, is sexy.....................
  • hewlew1
    hewlew1 Posts: 154
    edited November 2012
    Amen brother you said it. Although I would prefer just a tad bit bigger hooters.
  • zingo
    zingo Posts: 11,258
    edited January 2013
    I just emailed the seller of the khozmo in Warsaw as he offers a remote controlled version as a passive preamp which looks interesting.
  • zingo
    zingo Posts: 11,258
    edited January 2013
  • strider
    edited January 2013
    Wow. How much is that puppy?
  • zingo
    zingo Posts: 11,258
    edited January 2013
    Attenuator
    Number of steps: 48
    Contact material: Hard silver 99,99% Ag
    Channel matching: +/-0.1 dB
    Resistance: 10, 20, 50 or 100 kOhm (other values on request)
    Resistors: INPUT - Caddock MK132; GND - military Vishay/Dale RN55 1% 100ppm , 1/10W, low noise, non-inductive, metal film
    Upgrade options:
    Remote control - $200
    Vishay Zfoil series resistor - $49
    Takman REX shunt resistors - $69
    CNC machined enclosure made of exotic wood and anodized aluminium
    Dimensions: W280 x H80 x D210 mm
    Weight: 2,8kg
    Shipping with EMS:
    Europe - $49
    USA, Canada - $55
    Asia, Africa - $69
    Australia, New Zeland - $79
