Jumpers
Early B.
Early B. Posts: 7,900
What kind of metal are those stock jumpers made of?
Anyone ever conduct an A/B test of stock jumpers vs. DIY or a branded set of jumpers? Results?
"God grooves with tubes."
Post edited by Early B. on
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited May 2004
  • Willow
    Willow Posts: 11,284
    edited May 2004
    same here I actually find my DIY jumpers look better too !! and how can that thin piece of metal compare to 12awg jumpers
  • Early B.
    edited May 2004
    PW and Willow -- what were your results when you switched out the stock jumpers? Was it improved highs, better soundstage, more detail...??? Or did you notice any improvement at all?
  • PolkWannabie
    edited May 2004
    I've noticed the highs and to a lesser extent the mids seem to suffer somewhat when using the flat jumpers and plugging the speaker wires into the low terminals. The differences are less noticeable when the speaker wires are plugged into the upper terminals which is where I prefer to have them even with better jumpers.
  • Willow
    edited May 2004
    I noticed a cleaner detailed high, not sure about the sound stage but my tweets sound sweet !! specially the highhats in jazz...clean and not fuzzy and dirty sounding
  • gmorris
    gmorris Posts: 1,179
    edited May 2004
    I also swapped out the stock brass jumpers with some 12 AWG DIY jobbies on my RTi70's.
    I noticed a bit more "air" in the treble. That is a hard thing to explain, but the treble is more "trebley" if that makes sense. It does not mean the treble is just louder, but more clear & crisp.
    Bob Mayo, on the keyboards. Bob Mayo.
  • Early B.
    edited May 2004
    Thanks for your feedback. Looks like getting jumpers is worth pursuing once the Lsi7's arrive.
  • PolkWannabie
    edited May 2004
    It's very easy to make your own ... just get some banana's and/or spades from ratshack or monster and some 12 or 10 awg speaker wire.
  • gmorris
    edited May 2004
    And add some black & red heat shrink tubing for the finished look.
  • Early B.
    edited May 2004
    Not interested in making my own. I'll just buy 'em. They're inexpensive.
  • Willow
    edited May 2004
    you don't even need spades or plugs but as gmorris said add the heat shrink makes it look good !! thats what I did no spades or plugs bare wire and heat shrink!!
  • ezc
    ezc Posts: 426
    edited May 2004
    Early,
    Stock Jumper replacement is a very good upgrade. I have replaced all the jumpers on my lsi speakers that use single wire input. Noticable improvement over stock. My mains I went back to bi wire. We give the customers that purchase speakers from us the option of better jumpers. The jumpers we build is Monster Cable Z1 with M1000 spade ends. You can build good jumpers for a reasonable price! Great improvment little cost! Now waht improvment would I gain if I replaced the speaker cable in the speaker & the cable from the binding post to the xover with better wire? That will be the next tweak!
