Jumpers
Early B.
What kind of metal are those stock jumpers made of?
Anyone ever conduct an A/B test of stock jumpers vs. DIY or a branded set of jumpers? Results?
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
DIY'ers imho can be made cheaply and have superior results.
same here I actually find my DIY jumpers look better too !! and how can that thin piece of metal compare to 12awg jumpers
PW and Willow -- what were your results when you switched out the stock jumpers? Was it improved highs, better soundstage, more detail...??? Or did you notice any improvement at all?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I've noticed the highs and to a lesser extent the mids seem to suffer somewhat when using the flat jumpers and plugging the speaker wires into the low terminals. The differences are less noticeable when the speaker wires are plugged into the upper terminals which is where I prefer to have them even with better jumpers.
I noticed a cleaner detailed high, not sure about the sound stage but my tweets sound sweet !! specially the highhats in jazz...clean and not fuzzy and dirty sounding
I also swapped out the stock brass jumpers with some 12 AWG DIY jobbies on my RTi70's.
I noticed a bit more "air" in the treble. That is a hard thing to explain, but the treble is more "trebley" if that makes sense. It does not mean the treble is just louder, but more clear & crisp.Bob Mayo, on the keyboards. Bob Mayo. -
Thanks for your feedback. Looks like getting jumpers is worth pursuing once the Lsi7's arrive.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
It's very easy to make your own ... just get some banana's and/or spades from ratshack or monster and some 12 or 10 awg speaker wire.
And add some black & red heat shrink tubing for the finished look.Bob Mayo, on the keyboards. Bob Mayo. -
Not interested in making my own. I'll just buy 'em. They're inexpensive.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
you don't even need spades or plugs but as gmorris said add the heat shrink makes it look good !! thats what I did no spades or plugs bare wire and heat shrink!!
Early,
Stock Jumper replacement is a very good upgrade. I have replaced all the jumpers on my lsi speakers that use single wire input. Noticable improvement over stock. My mains I went back to bi wire. We give the customers that purchase speakers from us the option of better jumpers. The jumpers we build is Monster Cable Z1 with M1000 spade ends. You can build good jumpers for a reasonable price! Great improvment little cost! Now waht improvment would I gain if I replaced the speaker cable in the speaker & the cable from the binding post to the xover with better wire? That will be the next tweak!
